Peter,
I am trying to build a trans material file or trans data file
Tim Metcalfe
Kalwall Corporation
Daylight Modeling Group
1111 Candia Road
Manchester, N.H. 03105
1(800)258-9777 X4483
P Please consider your environmental responsibility before printing this e-mail
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Hi Tim!
Peter is trying to find out the level of detail (and thus the depth of
information on the optical properties and its model) you will need. What
is your application?
Are you looking at solid, structured, hollow samples?
I am using structures panels, the application is 40mm thick Wall panels
Hi Tim,
40mm probably means hollow, not solid panels. The internal structure
would lead to transmission and reflection distributions which, depending
on your application, are probably not sufficiently described by trans
(which allows only one transmissive and one reflective peak), prism or
prism2. It would also be a good idea to know about the actual
performance of these panels, which requires measurements (Peter is
running one of those labs able to do such measurements, others are at
LBNL and SERIS). The topic BSDF has been discussed in detail on the
recent Radiance workshops, with the presentations available on the
Radiance websites. Peter already replied to your initial message, and he
is probably one of the most experienced when it comes to the
characterization of the transmissive characteristics of such panels.
