Dear Everyone,
I have been playing with pkgBSDF and that kind of stuff, and something
weird is happening (I think).
This is my scene (of course the references are present in the respective
directories).
##### CASE
!xform Geometry/Layer0.rad
#East Shading
!pkgBSDF -s system.xml | xform -t 0 0 .02 -rx 90 -rz 90 -t 5.02 1.02 2.27
-a 5 -t 0 1.5 0
#South Shading
!pkgBSDF -s blind0.xml | xform -rx -90 -t 2.54 0 1.869
!xform Skies/sky.rad
Anyway, when I try to render, it only works without ambient calculations
(-ab 0), and only with one pkgBSDF declaration (the BSDFs are in my
RAYPATH).
When I try to render with -ab 1, it returns:
4018 Abort trap: 6 rpict -vf Views/view.vf -ab 1 octree >
Images/south_only_AB1.hdr
When I try both together with -ab 0:
043 Abort trap: 6 rpict -vf Views/view.vf -ab 0 octree > Images/both_AB0.hdr
And, when I try both together with -ab 1:
4075 Abort trap: 6 rpict -vf Views/view.vf -ab 1 octree >
Images/both_AB1.hdr
Here you can check the images "just generated".
https://www.dropbox.com/sh/fqedoyd7jdbn0uv/rNniz9rqoI
Might this be a bug? I am using the HEAD version from about yesterday...
THANKS
Germán
Hi Germán,
This is an unusual error, and not very informative. I will attempt to reproduce it if you can send me all of your files off-list in a compressed tar file attachment (if it's not too big to mail).
Date: September 12, 2013 1:03:47 PM PDT
Dear Everyone,
I have been playing with pkgBSDF and that kind of stuff, and something weird is happening (I think).
This is my scene (of course the references are present in the respective directories).
##### CASE
#East Shading
!pkgBSDF -s system.xml | xform -t 0 0 .02 -rx 90 -rz 90 -t 5.02 1.02 2.27 -a 5 -t 0 1.5 0
#South Shading
Anyway, when I try to render, it only works without ambient calculations (-ab 0), and only with one pkgBSDF declaration (the BSDFs are in my RAYPATH).
4018 Abort trap: 6 rpict -vf Views/view.vf -ab 1 octree > Images/south_only_AB1.hdr
4075 Abort trap: 6 rpict -vf Views/view.vf -ab 1 octree > Images/both_AB1.hdr
THANKS
Germán
Thanks Greg,
I uploaded a file called "SunliteExport.zip" to the same folder.
Bye!
German
2013/9/12 Greg Ward <gregoryjward@gmail.com>
Hi Germán,
*Date: *September 12, 2013 1:03:47 PM PDT
Dear Everyone,
directories).
##### CASE
#East Shading
-a 5 -t 0 1.5 0
#South Shading
RAYPATH).
Images/both_AB0.hdr
Images/both_AB1.hdr
THANKS
Germán
Hi Germán,
I tried it, and I don't get an error. What -O setting are you using when compiling Radiance? Anything above -O2 has been known to generate incorrect code with gcc. Even -O2 sometimes causes runtime errors.
If you recompile and get an error using -O1, try without -O, just using -g, and run it in the debugger. This is the only way to find out where it is going wrong.
Date: September 12, 2013 3:04:29 PM PDT
Thanks Greg,
Bye!
German
Hi Germán,
Dear Everyone,
##### CASE
#East Shading
#South Shading
THANKS
Germán
mmm, that is weird.
I actually did not understand anything you said, haha... I just use the
"sudo ./makeall install" command. How do I choose different -O and -g
options?
THANKS AGAIN
German
Hi Germán,
is going wrong.
*Date: *September 12, 2013 3:04:29 PM PDT
Thanks Greg,
Bye!
German
Hi Germán,
Dear Everyone,
directories).
##### CASE
#East Shading
-a 5 -t 0 1.5 0
#South Shading
RAYPATH).
Images/both_AB0.hdr
Images/both_AB1.hdr
THANKS
Germán
It is working now!...
I erased and reinstalled Radiance with no -O option.
THANKS VERY MUCH GREG AND JACK
German
2013/9/13 Germán Molina Larrain <gmolina1@uc.cl>
mmm, that is weird.
options?
THANKS AGAIN
German
Hi Germán,
is going wrong.
Thanks Greg,
Bye!
German
Hi Germán,
Dear Everyone,
directories).
##### CASE
#East Shading
#South Shading
RAYPATH).
Images/both_AB0.hdr
Images/both_AB1.hdr
THANKS
Germán
Hi German,
When you run makeall install, after you are asked for the location for the location of the executables, you will get something like the following:
Current rmake command is:
#!/bin/sh
exec make "SPECIAL=" \
"OPT=-O2" \
"MACH=-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" \
ARCH=IBMPC "COMPAT=erf.o" \
INSTDIR=/Rlib/bin \
LIBDIR=/Rlib/lib \
ESUFFIX= \
CC=gcc "$@" -f Rmakefile
Do you want to change it?
If you type "Y," this will be opened up in an editor (vi is default unless you specify otherwise when you first run makeall). The "OPT=" line is the one that you should edit according to Greg's suggestions. So I think that you could first try:
"OPT=-01"
and then if that does not help, you could try:
"OPT="
This will turn of optimizations.
I think that -g gives debugging output. I think that you could do the following to compile with this:
change
to
CC=gcc -g "$@" -f Rmakefile
Hope this helps,
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
channeling technology for superior design and construction
On 9/13/2013 8:30 AM, Germán Molina Larrain wrote:
mmm, that is weird.
I actually did not understand anything you said, haha... I just use the "sudo ./makeall install" command. How do I choose different -O and -g options?
THANKS AGAIN
German
2013/9/12 Greg Ward <gregoryjward@gmail.com <mailto:gregoryjward@gmail.com>>
Hi Germán,
runtime errors.
<mailto:gmolina1@uc.cl>>
Thanks Greg,
Bye!
German
Hi Germán,
big to mail).
Dear Everyone,
##### CASE
#East Shading
#South Shading
Images/both_AB0.hdr
Images/both_AB1.hdr
yesterday...
THANKS
Germán
<mailto:Radiance-general@radiance-online.org>
