perforate.cal
Hi group,
I use a file called perforate.cal (from Georg).
Is it possible to change this file in such way that use it on surfaces which various normal directions ( not only through x, y or z plane) ?
-Iebele
perforate.cal:
        perforate.cal
        Perforation function for approximately horizontal sufaces,
        for use in a mixfunc. Foreground is solid, background the holes.
        Set background to empty for a true perforation, or to a different
        material for polka dots.
        Relative hole size is determined by A1.
        Size of single circle is 1 - scale as required (eg. 0.05m).
        x_hole cuts holes in x-direction (through the y-z plane)
        y_hole cuts holes in y-direction (through the x-z plane)
        z_hole cuts holes in z-direction (through the x-y plane)
    Georg Mischler 30. 04. 1993
`xn = mod(Px, 1) - 0.5;
`yn = mod(Py, 1) - 0.5;
`zn = mod(Pz, 1) - 0.5;
`outofcirc(x, y, r) = if(sqrt(x*x + y*y) - r, 1, 0);
z_hole = `outofcirc(`xn, `yn, A1);
x_hole = `outofcirc(`yn, `zn, A1);
y_hole = `outofcirc(`zn, `xn, A1);
I would suggest to follow this route:
-1- use obj to export your model with an UV mapping defined (Maxon Bodypaint
is what I use to create the UV, works fine... but I am pretty sure that even
Blender has something similar)
-2- edit the cal file substituting Lu and Lv with Px Py, no need of Pz since
we are on a surface
-3-
Define a mesh primitive
Define the material as usual
-4- import the file with a mesh primitive and attach the material while
importing:
Obj2mesh -a materials model.obj > model.mesh
Open you file wit objview, just a quick check,
Hopefully all should be ok....
I found this new feature really useful... all the old parametric textures
are now UV... really cool!
Hope it works,
giulio
[mailto:[email protected]] On Behalf Of atelier
iebele abel
Sent: 13 April 2005 15:18
Subject: [Radiance-general] perforate.cal
Hi group,
-Iebele
perforate.cal:
        perforate.cal
Hi Giulio,
Thanks for your quick reply. I will give Bodypaint a try, but I doubt if it does generate surface normals from a file that doesn't have them.
Anyways, I wonder if the perforate.cal could be changed to work at once on surfaces without UV coordinates.
When mapping pictures it goed well, since I (not really me:) changed a few lines in picture.cal :
pic_u = U; //was: pic_u = Px;
pic_v = V; //was: pic_v = Py;
I don't know why this works, but it does....
If something like this could be done in the perforate.cal file, that would be nice,
-Iebele
we are on a surface
-3-
importing:
Hope it works,
giulio
iebele abel
Hi group,
-Iebele
perforate.cal:
       perforate.cal
As you say you need to define UV first.
If you have a mesh and not UV values I cannot help you.
Sorry,
giulio
iebele abel
Sent: 13 April 2005 15:56
Subject: Re: [Radiance-general] perforate.cal
Hi Giulio,
would be nice,
-Iebele
Bodypaint
even
since
we are on a surface
-3-
importing:
Hope it works,
giulio
iebele abel
Hi group,
-Iebele
perforate.cal:
       perforate.cal
Hi Iebele,
You could try the following additions to the cal file. I am not sure if this will work as I am not in a location to try it out right now. See inline below...
atelier iebele abel wrote:
Hi group,
-Iebele
perforate.cal:
       perforate.cal
{uv coordinate mapping}
`un = mod(U, 1) - 0.5;
`vn = mod(V, 1) - 0.5;
{uv mesh coordinate mapping}
`lun = mod(Lu, 1) - 0.5;
`lvn = mod(Lv, 1) - 0.5;
uv_hole = `outofcirc(`un, `vn, A1);
luv_hole = `outofcirc(`lun, `lvn, A1);
# John E. de Valpine
The U and V values defined in rayinit.cal will work for planar surfaces of any orientation, but will not work for curved surfaces or meshes. For these, you need to define a local (u,v) mapping and apply Lu and Lv on a mesh surface as Guilio suggests, or else come up with an approximation plane that will work and use that by rotating your function. You can always rotate any .cal function to another orientation by adding transform arguments (-rx, -ry, -rz) to the mixfunc primitive that references it.
Date: April 13, 2005 7:17:56 AM PDT
Hi group,
-Iebele
Hi Jack,
It works perfect! Great, thanks!
-Iebele
Jack de Valpine wrote:
Hi Iebele,
Hi group,
-Iebele
perforate.cal:
       perforate.cal
