partly covered source
I just encountered a strange different behavior between rtrace and rpict:
If the sun ( using "source") is covered in large parts (in that case more than half) I can still "see" the uncovered parts in the image (=>this is what I expect). In case I calculate at the same point and in the same direction the illuminance with rtrace -I, I get zero contribution. Is just the center of the source description tested in that case? Any solution for this for rtrace?
I just look for the sun, no sky description and use only direct calculation (-ab 0) .
Jan
Dr.-Ing. Jan Wienold
Head of Team Passive Systems and Daylighting
Fraunhofer-Institut für Solare Energiesysteme
Thermal Systems and Buildings
Phone: +49(0)761 4588 5133 Fax:+49(0)761 4588 9133
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Jan,
maybe you can fix it with -dj and oversampling?
G
On 24 Jul 2012, at 00:03, Jan Wienold wrote:
Jan
http://www.ise.fraunhofer.de
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
hi giulio,
Yes!
The use of -dj helped, but only if I use also the -u option. Otherwise I still get randomized zero values, also if I change -ds.
thanks!
jan
On 07/24/2012 01:35 AM, giulio antonutto wrote:
Jan,
G
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Hi Giulio, hi all,
unfortunately it doesn't work out safely. In total I have many, many cases to look at (in total 40000 timesteps x 33 points x 2geometries) and there are still many cases, when rtrace doesn't catch the sun.
Since these are calculations for an expertise, which is used for a trial, I have to be absolutely sure not to miss any case...
Is there any idea except calculating images ? Source subdivisions are unfortunately not possible when "source" is used...
Thanks!
Jan
On 07/24/2012 02:13 AM, Jan Wienold wrote:
hi giulio,
Yes!
thanks!
jan
Jan,
G
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
but did you try to oversample?
let's say run 100 times and get the average at each point…
On 24 Jul 2012, at 20:50, Jan Wienold wrote:
Hi Giulio, hi all,
Thanks!
Jan
hi giulio,
Yes!
thanks!
jan
Jan,
G
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Alternatively there is another option.
derive illuminance from a standard image.
so:
render what a calculation point sees in view -h mode
then write a script to process the luminance data and the angular location alongside the solid angle of a single pixel.
the total contribution, the sum, would be the total illuminance, regardless of any subdivision etc.
but it takes 1 image for each point and you may need to investigate the resolution required to capture all sources (if small)…
we have done this before (Andy,remember?) and it works quite well.
In fact the method can be extended to calculate reflections and caustics...
Good luck with the judge!
G
Hi Giulio, hi all,
Thanks!
Jan
hi giulio,
Yes!
thanks!
jan
Jan,
G
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Hi Giulio,
thanks!
Both solutions are a question of calculation time... but I use the second way now to be on the safe side (calculation of image) - even it takes me much longer...For the evaluation I use evalglare, is pretty simple to use for such cases.
For reflections I already did it in that way and I used a modified version of evalglare (will put it online soon) to calculate the angle between different glare sources (in that case between reflection and sun), too. The only disadvantage is the long calculation time of several days (1 image (ab0)+evaluation takes 6 sec -> 2.5 days on a single core for one point..and I have 33 points and two geometries...).
Jan
so:
G
Hi Giulio, hi all,
Thanks!
Jan
hi giulio,
Yes!
thanks!
jan
Jan,
G
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Jan
You could get the direction of the sun from your sky description and point
rtrace in that direction and only get the material (-om). You can add your
own variations to sample the whole disc to calculate the visible part of
the sun if that's what you need.
On Tue, Jul 24, 2012 at 9:50 PM, Jan Wienold <[email protected]>wrote:
Hi Giulio, hi all,
Thanks!
Jan
hi giulio,
Yes!
thanks!
jan
Jan,
G
rpict:
this for rtrace?
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Radiance-general@radiance-**online.org<[email protected]>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general>
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
