Panther Shell questions
I just installed Panther... woohoo!
I recall Rob G saying bash is the default shell in 10.3
my terminal says tcsh - could that be because I chose to keep my previous
Users and prefs?
I know you can change the shell in Terminal Preferences, but what's the
difference anyway?
Also, in X11 when I use rad -o x11 nov15.rif, I get
rview -vf qtvr.vp -ps 3 -pt .04 -dp 4096 -ar 112 -ms 0.85 -ds .2 -dt .05
-dc .75 -dr 3 -sj 1 -st .01 -ab 3 -af Nov15.amb -aa .08 -ad 1024 -as 512
-av 0.
5 0.5 0.5 -lr 12 -lw .0005 -av .1 .1 .1 -ad 2048 -as 1024 -ar 105 -aa .05
-ps 1
-R nov15.rif -o x11 -pe 1 nov15.oct
I get an error:
Unknown option: "-ps"
yet when I run rview directly it works
rview -vf qtvr.vp -ab 2 -ps 2 -af Nov15.amb nov15.oct
I'm a little slow, but I'm asuming this is the conflict with rview and vi?
Greg says to run radcollisions.csh - which is supposed to look for conflicts
with rview?
don't know how... tried
robfitzs% ./radcollisions.csh
tcsh: ./radcollisions.csh: Permission denied.
Ok. so I try
sudo ./radcollisions.csh
Password: *****
sudo: ./radcollisions.csh: command not found
Still a Unix newbie!
Rob F
my terminal says tcsh - could that be because I chose to keep my previous Users and prefs?
Yep, exactly. I believe any *new* user accounts you create will default to bash, though.
I know you can change the shell in Terminal Preferences, but what's the difference anyway?
Lots of little differences between all the various shells, but bash seems to have the most useful doodads for interractive use. It's the default shell on most Linux distros too. Here's a nice little summary comparing the most popular shells I just found:
http://www.ee.ucla.edu/~brucker/howto/shells.html
-dc .75 -dr 3 -sj 1 -st .01 -ab 3 -af Nov15.amb -aa .08 -ad 1024 -as 512 -av 0.
5 0.5 0.5 -lr 12 -lw .0005 -av .1 .1 .1 -ad 2048 -as 1024 -ar 105 -aa .05 -ps 1
I get an error:
Hmmm. Dunno.
Greg says to run radcollisions.csh - which is supposed to look for conflicts with rview?
Ok. so I try
Password: *****
Try making the file executable, by running chmod on it:
robfitzs% chmod 755 radcollisions.csh
Then you should be able to run it typing:
Not sure if this conflict is your problem, though. Are you saying this error started appearing only after you upgraded to Panther?
      Rob Guglielmetti
e. [email protected]
w. www.rumblestrip.org
The second time Greg sent the script, it had DOS carriage
returns, and I couldn't run it on Linux. SO, I more'd it and
copied and pasted it into a new file, chmod 755'd it, and
that new one ran.
Mark
> Ok. so I try
> Password: *****
that new one ran.
Hi Mark,
Hey, most Linuxes have a little util called 'dos2unix' installed, which removes the returns too. Usually there's a 'dos2unix' and a 'unix2dos'.
-Rob
I get an error:
Possibly, although it would be strange for rad to call a different
rview binary than you do manually.
with rview?
Ok. so I try
Password: *****
% tcsh ./radcollisions.csh
Your file doesn't have execute rights. You could use "chmod"
to change that, but feeding it directly to the interpreter
is more straightforward.
-schorsch
Heh, yeah, I forgot what those were called, believe it or not.
Sometimes, I just want the dumb solution,. =0)
Mark
> that new one ran.
Hi Mark,
-Rob
> that new one ran.
Hi Mark,
Alternatively, ask everybody's favourite enemy to help you:
% vim -e '+set fileformat=unix' +wq ./radcollisions.csh
-schorsch
Thanks
I get an error:
vi?
Georg M says
that made me wonder too
Hmmm. Dunno.
Thanks Mark and Rob - had to do both chmod and re-do the line breaks
Yes - had no problem when using rad in 10.1.5 with the X11 I got from
XFree86
Rob Fitz
Rob F. and I exchanged a couple of e-mails. I think his problem is that he has rview "aliased" to /usr/local/bin/rview, but does not have /usr/local/bin in his path before /usr/bin, where the vim link lives. That's why running from rad, which doesn't get aliases, gets /usr/bin/rview (i.e., vim) instead of /usr/local/bin/rview. The solution is to put /usr/local/bin in the path before /usr/bin. Next release, we'll rename rview so this won't happen again.
Date: December 12, 2003 10:34:18 AM PST
my terminal says tcsh - could that be because I chose to keep� my previous Users and prefs?
�rview -vf qtvr.vp -ps 3 -pt .04 -dp 4096 -ar 112 -ms 0.85 -ds .2 -dt .05
�-dc .75 -dr 3 -sj 1 -st .01 -ab 3 -af Nov15.amb -aa .08 -ad 1024 -as 512 -av 0.
I get an error:
Ok. so I try
Password: *****
Rob F
Date: December 12, 2003 3:49:46 PM PST
X11
robfitzs% which rview
rview: aliased to /usr/local/bin/rview
Terminal
My Path
robfitzs% echo $path
/usr/bin /bin /usr/sbin /sbin /Users/robfitzs /usr/X11R6/bin /usr/X11R6/bin
/usr/local/bin
Guess I have /usr/X11R6/bin in there twice - a problem?
I have a .tcshrc in my home with this:
setenv PATH "${PATH}:/usr/X11R6/bin:/usr/local/bin"
setenv RAYPATH .:${HOME}:/usr/local/lib/ray
alias myrad 'cd ~/documents/radiance_stuff'
alias smith 'cd ~/documents/radiance_stuff/smith'
alias rview '/usr/local/bin/rview'
setenv DISPLAY localhost:0 ; setenv DYLD_LIBRARY_PATH
I put the alias rview last night thinking it might help
When rview is called from rad is the only time I get the error
Thanks again
Rob
To: Fitzsimmons, Rob
Sent: 12/12/2003 3:11 PM
Subject: Re: Panther Shell questions
Hi Rob,
Sounds like truly bizarre behavior. What do you get when you enter
"which rview" in X11 versus the Terminal?
-G
Date: December 12, 2003 2:37:18 PM PST
thanks
this works ok from the terminal, but not in X11
Sent: 12/12/2003 1:23 PM
Hi Rob,
It's hard to tell from something pasted into an e-mail if there was a
weird character or not, since cut-and-paste as well as e-mail will
strip clear text of any offending characters.� Send your .rif file in a
tar'red attachment, instead.
-G
I am not an expert at all in unix but after turning around for a while to configure radiance in
panther, I use this configuration that is working fine for tcsh shell. I have radiance bin and lib
directories into /usr/local/radiance and the manuals in /AppUnix/ray/doc/man.
- I create a .cshrc in my home with:
source /usr/share/tcsh/examples/rc
- and the file ~/Library/init/tcsh/rc.mine with these lines.
setenv MANPATH "/AppUnix/ray/doc/man:${HOME}/man:/usr/local/share/man:/usr/share
/man"
setenv RAYPATH ".:/usr/local/radiance/lib"
setenv PATH "/usr/local/radiance/bin:~/bin:/usr/local/bin:/usr/bin:/bin:/usr/loc
al/sbin:/usr/sbin:/sbin"
- the last line allows the use of xterm within terminal application (Pillo's idea)
genevieve lucet
universidad nacional autonoma de mexico
Obt�n tu correo en www.correo.unam.mx
UNAMonos Comunic�ndonos
