optics2rad
Hi folks,
I'm having trouble with an optics2rad conversion. When I run the conversion
script, it simply spits back the glass description instead of nice cleaned
up BRTDfunc. It works fine with other glass assemblies, so I think it's
specific to this description (copied below).
If the front and back reflectance values are close, as in this example,
does optics2rad simply say "don't worry about it, the RGB glass default is
close enough"?
Thanks for any insights - here's the export from Optics 6:
# FileName= GlzSys.usr
# Product Name=
# NFRC ID= 30000
# Manufacturer Name= User
# Glazing Type= Glazing system
# Coated Side= Neither
# Transmittance= 0.592
# Front Reflectance= 0.160
# Back Reflectance= 0.162
# Thickness(mm)= 23.715
# Appearance=
void glass CLEX_glass
3 0.571 0.677 0.628
void BRTDfunc CLEX_front
10
      0.134 0.168 0.174
      0.524 0.621 0.576
      0 0 0
9 0 0 0 0 0 0 0 0 0
void BRTDfunc CLEX_back
10
      0.136 0.168 0.206
      0.524 0.621 0.576
      0 0 0
9 0 0 0 0 0 0 0 0 0
Law of the universe - once you decide to email the list, you'll figure it
out, and it will likely be a rookie mistake.
The outside pane of glass was flipped in Optics, and the low-e coating was
on surface 1. optics2rad didn't like that, and thankfully refused to make a
bad material description.
*Mike Martinez* | LEED AP
Associate | Daylighting Group Lead
*Integral Group *| 427 13th Street | Oakland CA USA 94612
T 510.663.2070 x207
integralgroup.com <http://www.integralgroup.com/> |
mmartinez*@integralgroup.com
<[email protected]>*
*Trust* | *Nurture* | *Inspire*
On Fri, Aug 1, 2014 at 2:19 PM, Mike Martinez <[email protected]> wrote:
Hi folks,
conversion script, it simply spits back the glass description instead of
nice cleaned up BRTDfunc. It works fine with other glass assemblies, so I
think it's specific to this description (copied below).
close enough"?
# Product Name=
# NFRC ID= 30000
# Appearance=
3 0.571 0.677 0.628
10
      0.134 0.168 0.174
      0.524 0.621 0.576
      0 0 0
9 0 0 0 0 0 0 0 0 0
10
      0.136 0.168 0.206
      0.524 0.621 0.576
      0 0 0
9 0 0 0 0 0 0 0 0 0
