Oconv: system - out of object space: Not enough space error
Are you using a Radince triangle mesh? If not, try obj2mesh to convert it. (Gensurf has a -o option to couple with it.)
Sent from my iPad
On Feb 9, 2015, at 12:24 PM, Mostapha Sadeghipour <sadeghipour@gmail.com> wrote:
Hi Radiance community,
I'm trying to generate a BSDF file from a very dense mesh.
The Radiance file is around 8 GB and when I try to generate the .xml file using gebBSDF it gives me the "out of object space error"
Could not compile scene
I found an old discussion about the same warning which suggests some changes to source code (http://radsite.lbl.gov/radiance/digests_html/v1n1.html). I wonder if there is an easier way to address this issue?
A smarter solution is probably to create a smaller part of the panel and copy it around (which is what I'm going to do next) but I wanted to make sure that I need to do so.
Mostapha
Radiance triangle meshes cut down memory requirements by a factor of three or so. If you can get your mesh into Wavefront OBJ formant, obj2mesh can take it from there.
-G
Sent from my iPad
On Feb 9, 2015, at 1:15 PM, Mostapha Sadeghipour <sadeghipour@gmail.com> wrote:
Thanks Rob and Greg,
I use a triangulated mesh which is not generated by Radiance. Is this something special about Radiance's triangle mesh?
I will try to break down the geometry. I was trying to avoid the edge effect by modeling it all at once.
Mostapha
Sent from my iPad
Mostapha
Mostapha,
You may have to simplify your mesh or output it at lower resolution and/or tile it as Rob Guglielmetti suggested.
You can also try increasing some #define's in common/object.h, such as MAXOBJBLK then rebuilding everything using makeall.
Sent from my iPad
On Feb 9, 2015, at 2:02 PM, Germán Molina Larrain <germolinal@gmail.com> wrote:
Just to let you guys know, I faced a similar issue a few days ago, in a very small project. Not sure how I solved it, though. I work on OSX Yosemite.
It.is all I can say right now... hope it helps!
El feb 9, 2015 6:39 PM, "Mostapha Sadeghipour" <sadeghipour@gmail.com> escribió:
obj2mesh also gives me a similar error:
system - out of memory in newvn: Not enough space
Mostapha
On Mon, Feb 9, 2015 at 4:22 PM, Mostapha Sadeghipour <sadeghipour@gmail.com> wrote:
Great! I have it as an .obj file. I will give it a try then.
- Mostapha
-G
Sent from my iPad
Mostapha
Sent from my iPad
Mostapha
