Hi All,
We’ve had a strange problem with objview which I’m not sure if it’s been discussed before (Radiance 5.1a in OSX 10.11.6).
When the rad model file name includes a command line option (e.g. “this-Name.rad” includes “-N”) then the script hangs as it cannot find its parameter.
Looking in objview, it seems the problem is in the lines like:
if (m/-g/)
elsif (m/-u/)
Replacing with:
if (m/\b-g\b/)
seems to have solved the problem.
Santiago
Thanks, Santiago. I hadn't noticed this problem before. I checked in a version that should fix it, using a variant on your suggestion.
Date: August 19, 2016 10:30:36 AM PDT
Hi All,
if (m/-g/)
elsif (m/-u/)
Replacing with:
if (m/\b-g\b/)
Santiago
Thank you Greg. Credit is due to Nicola Rigoni, who found the problem.
Santiago
Sent: 19 August 2016 18:52
To: code development
Subject: Re: [Radiance-dev] objview
From: Santiago Torres <[email protected]<mailto:[email protected]>>
Hi All,
if (m/-g/)
elsif (m/-u/)
Replacing with:
if (m/\b-g\b/)
Santiago
