obj2rad splitting planar surfaces?
Am I missing something? It looks like obj2rad is splitting a planar rectangle into two triangles.
I think this OBJ file describes a single vertical rectangle:
# Rhino
mtllib one_plane.mtl
g IllumSrc__Center
o FirstIllum
usemtl Default
v 81.44685363769531 1 42
v 81.44685363769531 1 90
v 35.44684982299805 1 42
v 35.44684982299805 1 90
vt 0 0
vt 0 1
vt 1 0
vt 1 1
vn 0 1 0
f 4/4/4 2/2/2 1/1/1 3/3/3
And this obj2rad file describes two triangles:
# obj2rad one_plane.obj
# Rhino
Default polygon FirstIllum.1
9
      35.446849823 1 90
     81.4468536377 1 90
     81.4468536377 1 42
9
     81.4468536377 1 42
      35.446849823 1 42
      35.446849823 1 90
# Done processing file: one_plane.obj
# 19 lines, 18 statements, 1 unrecognized
Meantime, I'd better come up with a script that produces the proper output.
Randolph M. Fritz
Hi Randolph,
Seems obj2rad has an initial test to determine if a polygon has specified normals. If it does, then it breaks it into triangles. Once it looks at the triangles, it then sees if the normals actually require interpolation or not. If they don't, then it doesn't specify a texture, but they still get output as triangles.
Is it a problem? Just take off the normals if it is.
Date: March 22, 2012 11:14:31 AM PDT
# Rhino
g IllumSrc__Center
o FirstIllum
usemtl Default
vt 0 0
vt 0 1
vt 1 0
vt 1 1
vn 0 1 0
vn 0 1 0
vn 0 1 0
vn 0 1 0
# Rhino
9
    35.446849823 1 90
   81.4468536377 1 90
   81.4468536377 1 42
9
   81.4468536377 1 42
    35.446849823 1 42
    35.446849823 1 90
Randolph M. Fritz
Thank you very much. It does matter--these surfaces are going to be used by mkillum. Using -f fixes the problem, and here I am embarassed that I didn't figure it out in the first place.
Oh, well. At least I learned a bit more about debugging Radiance.
Randolph
On 2012-03-22 19:12:49 +0000, Greg Ward said:
Hi Randolph,
# Rhino
g IllumSrc__Center
o FirstIllum
usemtl Default
vt 0 0
vt 0 1
vt 1 0
vt 1 1
vn 0 1 0
# Rhino
9
35.446849823 1 90
81.4468536377 1 90
81.4468536377 1 42
9
81.4468536377 1 42
35.446849823 1 42
35.446849823 1 90
Randolph M. Fritz
Randolph M. Fritz
