no output from optics2rad
Dear list,
I have tried to run the optics2rad script, but the only output I get
is the information behind the # in the file from optics, implying that
rcalc in the optics2rad script, do not get any information...Have
anyone experience with this?
My approach is simply to write
optics2rad followed by the name of the file from optics.
Do I need further commands to run the optics2rad script?
Br
Anne Iversen
Hi Anne,
Thanks for sharing the file. For some reason, Optics dropped a critical line from its output, making the actual scene description illegal and breaking the optics2rad translator. Both BRTDfunc descriptors were missing a critical '.' in their description. Yours look like this:
void BRTDfunc ANTELIOSILVER6mm_front
10
       0.267 0.321 0.395
       0.678 0.655 0.576
       0 0 0
9 0 0 0 0 0 0 0 0 0
when they should look like this:
10
       0.267 0.321 0.395
       0.678 0.655 0.576
       0 0 0
9 0 0 0 0 0 0 0 0 0
I don't actually know what happened to the period, but reinserting it, optics2rad works again, producing:
10
         rR_clear rG_clear rB_clear
         0.678*tR_clear 0.655*tG_clear 0.576*tB_clear
      0 0 0
      window.cal
15 0 0 0 0 0 0 0 0 0
         0.267 0.321 0.395
         0.24 0.306 0.368
Date: May 9, 2009 12:52:44 PM PDT
The optics-file is attached. I have also attached the output piped to a file from running optics2rad with -xv added to the first line of the script. The file contains the output from both stdout and stderr.
The csh is the standard version(from July 13 2007) supplied with Ubuntu.
/Anne
On Sat, May 9, 2009 at 4:01 PM, Greg Ward <[email protected]> wrote:
Can you send me your Optics file?
Date: May 9, 2009 7:01:43 AM PDT
I seem to have run into a similar issue as reported by Anne where optics2rad only sends out the header information of the optics file. I've checked the optics file and it has the "." you describe in the correct location:
void BRTDfunc SB60 Starphire_8_front
10
       0.050 0.057 0.073
       0.795 0.815 0.777
       0 0 0
9 0 0 0 0 0 0 0 0 0
void BRTDfunc SB60 Starphire_8_back
10
       0.044 0.051 0.037
       0.795 0.815 0.777
       0 0 0
9 0 0 0 0 0 0 0 0 0
Anyone else having the same results?
Thanks!
Best regards,
Chris Humann
On May 9, 2009, at 2:21 PM, Greg Ward wrote:
Hi Anne,
10
     0.267 0.321 0.395
     0.678 0.655 0.576
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.267 0.321 0.395
     0.678 0.655 0.576
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
    0 0 0
    window.cal
       0.267 0.321 0.395
       0.24 0.306 0.368
/Anne
Hi Chris,
One problem that I see is the name of the two materials contains a space after SB60. This would need to be fixed for a valid radiance material name.
Chris Humann wrote:
10
      0.050 0.057 0.073
      0.795 0.815 0.777
      0 0 0
9 0 0 0 0 0 0 0 0 0
10
      0.044 0.051 0.037
      0.795 0.815 0.777
      0 0 0
9 0 0 0 0 0 0 0 0 0
Thanks!
Best regards,
Chris Humann
Hi Anne,
10
     0.267 0.321 0.395
     0.678 0.655 0.576
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.267 0.321 0.395
     0.678 0.655 0.576
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
    0 0 0
    window.cal
       0.267 0.321 0.395
       0.24 0.306 0.368
/Anne
# Jack de Valpine
Hi Jack,
Thanks, good eye. Unfortunately even with the material name fixed I'm still not getting output beyond the header.
Chris
On May 11, 2009, at 1:03 PM, Jack de Valpine wrote:
Hi Chris,
Chris Humann wrote:
10
     0.050 0.057 0.073
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.044 0.051 0.037
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
Thanks!
Best regards,
Chris Humann
Hi Anne,
10
    0.267 0.321 0.395
    0.678 0.655 0.576
    0 0 0
9 0 0 0 0 0 0 0 0 0
10
    0.267 0.321 0.395
    0.678 0.655 0.576
    0 0 0
9 0 0 0 0 0 0 0 0 0
10
   0 0 0
   window.cal
      0.267 0.321 0.395
      0.24 0.306 0.368
/Anne
# Jack de Valpine
Hi Chris,
Why is your description missing the "glass" descriptor Optics usually produces? The optics2rad script is a bit fragile to such oversights. Maybe you just took it out for brevity.
In any case, the optics2rad script doesn't like underscores in names any better than it likes Spaces. The only underscore you can have is before the final "_glass", "_front" or "_back". The issue is not with Radiance but with the rcalc program, which looks for the end of the name by searching for an underscore. Not much way around it, I'm afraid. All three names need to be identical as well, e.g.:
void glass SB60-Starphire-8_glass
3 .95 .95 .95
void BRTDfunc SB60-Starphire-8_front
10
       0.050 0.057 0.073
       0.795 0.815 0.777
       0 0 0
9 0 0 0 0 0 0 0 0 0
void BRTDfunc SB60-Starphire-8_back
10
       0.044 0.051 0.037
       0.795 0.815 0.777
       0 0 0
9 0 0 0 0 0 0 0 0 0
Date: May 11, 2009 12:54:01 PM PDT
10
      0.050 0.057 0.073
      0.795 0.815 0.777
      0 0 0
9 0 0 0 0 0 0 0 0 0
10
      0.044 0.051 0.037
      0.795 0.815 0.777
      0 0 0
9 0 0 0 0 0 0 0 0 0
Thanks!
Best regards,
Chris Humann
Thanks for the response. I did take out the glass descriptor for brevity. I may have corrupted my optics2rad script somehow as it's still a no go even with the name changes you suggested.
Chris
3 .95 .95 .95
10
     0.050 0.057 0.073
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.044 0.051 0.037
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
Hi Chris,
Try doing the following. Take the radiance output from optics5 and run it through xform. For example:
    xform optics_output_filename > my_glass.rad
    optics2rad my_glass.rad
Chris Humann wrote:
Chris
3 .95 .95 .95
10
     0.050 0.057 0.073
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.044 0.051 0.037
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
# Jack de Valpine
Thanks Jack,
That was the silver bullet! Despite reinstalling Greg's script I was still getting no where. I use Textmate for all my radiance scripting and perhaps it was adding a hidden character somewhere that the c-shell didn't like.
This is great, thanks again!
Chris
On May 11, 2009, at 2:50 PM, Jack de Valpine wrote:
Hi Chris,
Chris Humann wrote:
Chris
3 .95 .95 .95
10
     0.050 0.057 0.073
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.044 0.051 0.037
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
# Jack de Valpine
Hi Chris,
Good glad it worked. It actually only just occurred to me that this might be a way to get a well formated radiance description that rcalc would be happy with. As Greg mentioned optics2rad calls on rcalc to do most of the work. Rcalc is very sensitive to the input format that it expects, unfortunately this can be a bit difficult to track down. Note I did also do an export of some dummy data from optics5 and this went into optics2rad without any problem. So it may be that if you are using some intermediate script in your process that it is somehow munging the format along the way. One simple thing to check for is if you have a carriage return at the last line of the input file that your script is generating or outputing for optics2rad processing.
Chris Humann wrote:
Thanks Jack,
Chris
Hi Chris,
Chris Humann wrote:
Chris
3 .95 .95 .95
10
     0.050 0.057 0.073
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
10
     0.044 0.051 0.037
     0.795 0.815 0.777
     0 0 0
9 0 0 0 0 0 0 0 0 0
# Jack de Valpine
[email protected] <mailto:[email protected]>
# Jack de Valpine
