New Radiance Website
Hi Everyone,
We're slowly working on a new Radiance website. The website will replace the existing radiance-online.org and will absorb radsite.lbl.gov.
The beta version of the new site is http://radiance-online.lbl.gov:82/ (this is a non-standard port, so it may be blocked by your company's firewall - if so try accessing it from home).
LBNL has no funding for this activity, it is officially a community generated site. We've worked on our own time to get a decent framework. To speed things up I ask for your help to add content and develop the site further. The site uses Plone, users can register themselves. If you are interested in adding content let me know and I will promote you to contributor.
Also, I appreciate recommendations for platforms that allow sharing files (ie models, scripts etc.) with comments and ratings. I'm not satisfied with Plone's capability in this area.
Andy
Hi Andy, hi list!
This is a nice framework for an appealing site! I especially like the
fact that the design of the "good old" site could be adopted.
I started setting up something related recently. Not based on Plone but
Drupal, not a complete "Radiance Website" but a concept focussing on
just having a working FAQ one day. You may get an idea here:
http://radiance.larsgrobe.de
The only part of interest on the site is the FAQ for now. I have spent
some time on thinking how to organize a FAQ, and abandoned the idea of
having single categories per question. I believe a tag-system being much
more appropriate, e.g. a question/answer pair on mkillum might be
related to "commands", "diffuse indirect calculation", "complex glazing"
and "optimizations". One day one might decide to also tag the content on
user levels, so a tag "advanced user" might be added. Browsing the
mailing lists, there is such a vast amount of information that I tend to
pay a lot of attention on the topic of marking it. Once a certain amount
of content is available, tag clouds (which may occur in alphabetical
order - I do not rely like the fancy cloud displays typically rendered
with lots of formatting) may be of more help then a fixed hierarchy.
One feature that I spent some time on was to integrate tex notation into
the content management. I added a test on the start page. You can embed
any Latex code in the content, which will be rendered into inline
images, but also be available as pdf downloads. The need to display
formulas and algorithms seams to be of importance. I am going to add
support for describing geometry in the content management, too -
basically I want to keep content descriptive and avoid bitmap images as
far as possible, so that content can be reused (e.g. for copying the
Latex source into a formula editor when writing an article), reformatted
and extended at any time.
On sharing: I think that sharing models is an interesting part of a
community website, though I am not sure that much model content will
become available. Most Radiance models are case-studies - buildings,
rooms, facades. Objects to be shared are more like furniture and other
decorative stuff, not bound to a specific use case - which is already
available on the internat. Similar is true for textures.
I see a need for sharing of cal-files. This would require an interface
where I could check the parameters and get a preview of the results -
downloading the cal-file is easy, using it makes things difficult.
The gallery is a must....
A Radiance material library would be great and is a topic on its own. I
started a concept of holding material data in a database, with several
interfaces to access it. I would prefer the data to be independent of
the software using it, so e.g. I would want spectral resolutions
supported beyond the three RGB channels natively supported by Radiance.
Extracting a Radiance material from this could be implemented in the
interface - combining the measured data from the database with the
assumptions to be made when using it in Radiance (e.g. I would need to
know that the data from the spectrometer are to be used with a plastic
modifier). So a material record could contain a table "models", where I
could add proposed models for various software tools. So querying the
model-table for "Radiance" for this material would return "plastic",
while querying for "MyOtherRenderer" could return "lambertianReflection".
I decided not to publicly announce this project so far, as there is
little content right now. Maybe there is some potential for combining
efforts, so I add this to the discussion.
Wow Lars, this looks awesome. This is exciting to see that you have put so
much thought into this, and that Andy's getting an effort at LBNL to buff
up the Radiance web offerings there. This topic has come up before, and as
I recall it was discussed at length at the 2003 workshop. It always seems
to die off. I'm not sure how much time I could devote to this effort, but
I'm happy to contribute what I can.
1617 Cole Blvd MS:RSF202
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
E. [email protected]
On 3/5/12 4:56 PM, "Lars O. Grobe" <[email protected]> wrote:
Hi Andy, hi list!
HI Lars,
I think your comments regarding FAQ's are spot on. I don't want to duplicate effort, so I'd like to let you continue to develop your FAQ and will replace the stub on with a redirection to your site. It would be nice to integrate the two, at least using the same login/passwords.
I agree that models are generally less useful than objects, but I would contend that in the research community there are desires to share and use standard models. I have some Radiance models for DOE prototype buildings that others might like to use. And HMG has 61 models of existing buildings that many have already asked for them to share.
But regardless, we can let users decide which is worth sharing. And taking the lead from your FAQ, we could get rid of the formal categories and instead using tags. If you want to simulate a daylight redirecting system you would probably want to see results for both a cal file and a model of the system.
I'll end by saying - please help!
Andy
On Mar 5, 2012, at 3:56 PM, Lars O. Grobe wrote:
Hi Andy, hi list!
I'd also like to point out that NREL is developing the Building Component
Library (BCL), initially conceived as a repository for vetted energy model
components, but there is no reason why Radiance data/models couldn't be
added to the schema. The idea is there will be a place to go to search for
energy model bits -- everything from HVAC, windows, materials, lights,
weather files -- and these can be downloaded, or pulled directly into an
OpenStudio model. I definitely envision us adding Radiance-ready data to
these database members.
We've got it mocked up here: https://bcl.nrel.gov/
So, another place to link to.
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
On 3/6/12 10:22 AM, "Andy McNeil" <[email protected]> wrote:
HI Lars,
Andy
Hi Andy, hi list!
Hi Andy,
I agree that there is a demand for sharing models. Besides what you mentioned, it is great for educational purpose and for validation. It may even reduce the downloads - if we could remove example scenes from the auxiliary files (errr are they still in there?) and have a makefile not only running oconv and rpict, but fetch model data when needed from a known URL.
For integrating my FAQ-start, I'd be happy to support this. Maybe the formatting would need to be sent through your CSS. Sharing accounts should be rather easy, there are lots of interfaces available in times of social networks (opened? Huuuuh big brother Radiance ;)...). I think we can discuss this off-list (with everyone included who is interested).
For those starting to play around now - please forgive the user-unfriendliness (you may also call it rudeness) of the site in its current stage. I did not plan to make it public yet and posted the address more as a contribution to the discussion. I will do some polishing in the coming days, until then expect it to behave as what it is - still experimental :wink:
Dipl.-Ing. Architect Lars O. Grobe
On Mar 6, 2012, at 19:22, Andy McNeil <[email protected]> wrote:
HI Lars,
Andy
Hi Andy, hi list!
Absolutely! Let me know when it contains Radiance components and I will link to it. Or better yet, register, I'll promote you, and you can add the link when it is time.
Andy
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
HI Lars,
Andy
Hi Andy, hi list!
Yes those example models are still in there, and we rely on them being
there for testing our builds, so I'd hate to see those ones get moved...
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
On 3/6/12 3:03 PM, "Lars O. Grobe" <[email protected]> wrote:
Hi Andy,
known URL.
HI Lars,
Andy
Hi Andy, hi list!
much
glazing"
on
to
amount
into
reformatted
Hi Michael,
I would argue that the NREL Building Component Library seeks to fill this need for a vetted, trackable database of energy model components, where one can track QC, provenance, ratings, etc. The BCL will store weather data, materials data, schedules, systems descriptions, and more. In much the same way that the OpenStudio model is being extended to support not only energy modeling but also daylight modeling, so too will these components contain the data required for whatever the destination simulation tool is. In the case of a luminaire, we plan to store photometric distribution, along with specs and basic energy use that EnergyPlus cares about. Likewise for windows, we plan to store window constructions for EnergyPlus but also a set of BSDFs that can be used by Radiance in a 3-phase daylight coefficient simulation. Like many projects around here, EnergyPlus is the initial focus of support, and Radiance support will be added as we have time and funding. But I would encourage you to check out what is there to get a sense of what the plan is, and I would love to hear feedback from the community as to what else is needed to make this useful to us all.
I have pinged my co-workers to see if there is any more background on the BCL that I can share, because they know the project much better than I do at this point, but I do think it may fill one of the gaps that we have been discussing today.
On Mar 6, 2012, at 6:46 PM, Michael Donn wrote:
Hi Andy, Rob, Lars
I'd like to endorse the concept of an FAQ for Radiance, but ask for a slightly broader view of the material definitions. They might initially be listed in the Radiance FAQ listing, but preferably they would also be listed in a more general materials database. There is an increasingly intense need for this: http://www.ibpsa.org/proceedings/BS2005/BS05_0373_380.pdf
We regularly export from SketchUp today to Daysim/Radiance - EnergyPlus and CATT Acoustic. I would love to be able to be sure that what we do with an 'acoustic tile' and its manufacturer's data for our acoustic analysis carries reliable light properties to the Lighting simulation - and that it can be tracked back to its source: http://www.ibpsa.org/proceedings/BS2009/BS09_1405_1412.pdf Our role as users could well be to rank / rate via social media style techniques the reliability of the data.
If we get these basic steps right then http://www.ibpsa.org/proceedings/BS2001/BS01_0731_738.pdf we have the basis for quality assurance - believable - simulations in an increasingly integrated (BIM or not) world...
M
PS: XML formatting is an example of how the approach could be implemented. XML /IFC or other formatting is not the issue; associated annotation and internet services based serving of data and associated rating of quality level of the data is.
Michael Donn
Director Centre for Building Performance Research
School of Architecture
Victoria University +64 4 463 6221 work
PO Box 600 +64 21 611 280 mobile
Wellington +64 4 463 6204 work fax
New Zealand +64 21 611 594 mobilefax
Sent: Wednesday, 7 March 2012 11:55 AM
Subject: Radiance-general Digest, Vol 97, Issue 4
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
  1. the disk of the sun (Michael Martinez)
  2. Re: New Radiance Website (Lars O. Grobe)
  3. Re: New Radiance Website (Andy McNeil)
  4. Re: the disk of the sun (John Mardaljevic)
  5. Re: New Radiance Website (Guglielmetti, Robert)
Message: 1
Date: Tue, 6 Mar 2012 13:00:36 -0800
Subject: [Radiance-general] the disk of the sun
Content-Type: text/plain; charset=us-ascii
Hi All -
I'm working on a project in which the brightness of the disk of the sun has become a discussion topic.
Using gendaylit set for California's central valley, a view toward clear (smoggy-ish) sunny skies at 8am on September 1 reveals a disk luminance of 987,365,074 cd/m2.
This seems perfectly reasonable, although when I find myself commenting "oh yes, it's about a billion..." I can't help but pause.
Does anyone know of a handy reference for disk luminance based on location and climate? Or better yet, anyone out there with greater math skills than I know how to derive disk luminance from direct normal radiation found in a weather file?
Thanks!
Mike
Message: 2
Date: Wed, 7 Mar 2012 00:03:06 +0200
Subject: Re: [Radiance-general] New Radiance Website
Hi Andy,
HI Lars,
Andy
Hi Andy, hi list!
but Drupal, not a complete "Radiance Website" but a concept focussing
on just having a working FAQ one day. You may get an idea here:
spent some time on thinking how to organize a FAQ, and abandoned the
idea of having single categories per question. I believe a tag-system
being much more appropriate, e.g. a question/answer pair on mkillum
might be related to "commands", "diffuse indirect calculation", "complex glazing"
on user levels, so a tag "advanced user" might be added. Browsing the
to pay a lot of attention on the topic of marking it. Once a certain
amount of content is available, tag clouds (which may occur in
alphabetical order - I do not rely like the fancy cloud displays
typically rendered with lots of formatting) may be of more help then a fixed hierarchy.
into the content management. I added a test on the start page. You
can embed any Latex code in the content, which will be rendered into
inline images, but also be available as pdf downloads. The need to
display formulas and algorithms seams to be of importance. I am going
to add support for describing geometry in the content management, too
- basically I want to keep content descriptive and avoid bitmap
images as far as possible, so that content can be reused (e.g. for
copying the Latex source into a formula editor when writing an
article), reformatted and extended at any time.
other decorative stuff, not bound to a specific use case - which is
already available on the internat. Similar is true for textures.
interface where I could check the parameters and get a preview of the
results - downloading the cal-file is easy, using it makes things difficult.
I started a concept of holding material data in a database, with
several interfaces to access it. I would prefer the data to be
independent of the software using it, so e.g. I would want spectral
resolutions supported beyond the three RGB channels natively supported by Radiance.
to know that the data from the spectrometer are to be used with a
plastic modifier). So a material record could contain a table
"models", where I could add proposed models for various software
tools. So querying the model-table for "Radiance" for this material
would return "plastic", while querying for "MyOtherRenderer" could return "lambertianReflection".
Message: 3
Date: Tue, 6 Mar 2012 14:17:14 -0800
Andy
Component Library (BCL), initially conceived as a repository for
vetted energy model components, but there is no reason why Radiance
data/models couldn't be added to the schema. The idea is there will be
a place to go to search for energy model bits -- everything from HVAC,
windows, materials, lights, weather files -- and these can be
downloaded, or pulled directly into an OpenStudio model. I definitely
envision us adding Radiance-ready data to these database members.
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
HI Lars,
Andy
Hi Andy, hi list!
the fact that the design of the "good old" site could be adopted.
focussing on just having a working FAQ one day. You may get an idea here:
tag-system being much more appropriate, e.g. a question/answer pair
on mkillum might be related to "commands", "diffuse indirect calculation", "complex glazing"
content on user levels, so a tag "advanced user" might be added.
Browsing the mailing lists, there is such a vast amount of
information that I tend to pay a lot of attention on the topic of
marking it. Once a certain amount of content is available, tag
clouds (which may occur in alphabetical order - I do not rely like
the fancy cloud displays typically rendered with lots of formatting) may be of more help then a fixed hierarchy.
going to add support for describing geometry in the content
management, too - basically I want to keep content descriptive and
avoid bitmap images as far as possible, so that content can be
reused (e.g. for copying the Latex source into a formula editor when
writing an article), reformatted and extended at any time.
the results - downloading the cal-file is easy, using it makes things difficult.
own. I started a concept of holding material data in a database,
with several interfaces to access it. I would prefer the data to be
combining efforts, so I add this to the discussion.
Message: 4
Date: Tue, 6 Mar 2012 22:41:02 +0000
Subject: Re: [Radiance-general] the disk of the sun
Hi Mike,
See page (number) 60 in chapter 3 here for a description how to derive the luminance of the sun from direct normal illuminance:
http://www.iesd.dmu.ac.uk/~jm/doku.php?id=resources:thesis
Includes a little discussion re: the inconsistency of applying a measurement taken with an acceptance angle of, say, 6 degrees to a source - the sun - that has an angle 0.5 degrees. Note that the discussion is couched in terms of predicting illuminance.
Best
John Mardaljevic
Reader in Daylight Modelling
Institute of Energy and Sustainable Development De Montfort University, The Gateway, Leicester, LE1 9BH, UK
Tel: +44 (0) 116 257 7972
http://dmu.academia.edu/JohnMardaljevic
Message: 5
Date: Tue, 6 Mar 2012 15:54:44 -0700
Message-ID: <CB7BE33F.EAB0%[email protected]>
Yes those example models are still in there, and we rely on them being there for testing our builds, so I'd hate to see those ones get moved...
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
Hi Andy,
a known URL.
HI Lars,
Andy
Hi Andy, hi list!
End of Radiance-general Digest, Vol 97, Issue 4
As a follow-up to my earlier post, here's a link to a paper on the BCL we presented in Sydney last fall:
Sent: Tuesday, March 06, 2012 7:14 PM
Hi Michael,
Hi Andy, Rob, Lars
M
Michael Donn
Today's Topics:
Message: 1
Hi All -
Thanks!
Mike
Message: 2
Hi Andy,
HI Lars,
Andy
Hi Andy, hi list!
Message: 3
Andy
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
HI Lars,
Andy
Hi Andy, hi list!
Message: 4
Hi Mike,
Best
John Mardaljevic
Message: 5
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
Hi Andy,
a known URL.
HI Lars,
Andy
Hi Andy, hi list!
Hello Radiance community.
I'd like to mention this page
    http://radiance-online.lbl.gov:82/community/plone-tips/plone-notes
for anyone who is interested in contributing to the new radiance-online.org site. If you have any technical issues related to posting content please direct them to me - Daniel Fuller [email protected].
Plones distinct advantage - apart from its fine-grained community permissions approach, is the the fact that it recognizes normal text files and simple html pages - which means output from utilities like man2html etc can directly be imported and exported unaltered as long as the html is purely structural (no css pop-ups divs etc). Also large media files like ISO can go directly into the system. For example, if mounted via webdav (see the link above) and entire folder hierarchy of html pages with associated files and images can drag and dropped directly into the cms.
The html files take the most time to upload since they are computed into the zodb - plone's database - but the best thing is that is does not alter the formatting of the original files and the can be retrieved via the webdav mount in the same drag and drop manner the way the went in. Other non text / html files are forwarded directly on the the webservers filesystem.
Edits in my opinion are best done using the "external editor" feature which can be clunky to setup (requires firefox - safari is prohibitive and I have not tried it with chrome) but once done updating the information can get quite compulsive since its so easy (we want it to be easy to encourage all you content providers to keep your pages fresh). Getting up to speed using LibreOffice can be a little tricky (ie same page links / anchors are called bookmarks) but I think those of you who have not used it before will find it consistent with its own behavior - anyone with ms word experience will know what that means :wink:
In any case one can start off by copying and pasting the template.html page from the Plone-Tips "Contents" (directory) view (must be logged in)
    https://radiance-online.lbl.gov:447/community/plone-tips/folder_contents
to the directory view of where your new page is going to go - for example in your home folder
   https://radiance-online.lbl.gov:447/Members/<your login name here>/folder_contents
Then rename the page and use the "Edit with external" application function or just the edit tab to update the page.
I know this sounds long winded - but in the long run it becomes quite automatic.
In in any case you can also start off by creating an html page and dragging and dropping to the plone site via webdav - again see the http://radiance-online.lbl.gov:82/archived/development/plone-notes page.
Thanks all for your patience with this new site and enjoy - if possible :wink:
Dan - 510-486-6496
On Mar 5, 2012, at 2:28 PM, Andy McNeil wrote:
Hi Everyone,
Andy
Dan - 510-486-6496
Hi Everyone,
Andy
Hi Everybody again -
Please excuse the typos in my previous post! I just wanted to get it out the door.
Regards !
Dan
Dan - 510-486-6496
Hi Everyone,
Andy
