Multi spectral rendering
Greg,
In your paper to the 2002 Eutographics Workshop on Rendering, you compare sRGB and Sharp RGB renderings against a multi-spectral rendering at 69 evenly-spaced spectral samples from 380 to 720 nm. I am curious how you made that multi-spectral rendering. Did you divide the 69 wavelengths into groups of three and run rpict(1) 23 times? Or did you run rpict(1) 69 times with proportional R, G, and B values? Or did you hack rpict(1) from a 3-band renderer to a 69-band one?
In the first case, wouldn�t there have been issues with gradient interpolation, which is calculated using the CIE definition of brightness from R, G, and B? Also adaptive shadow testing? I am currently wrestling with these issues as I have to perform multi-spectral renderings of many more than 69 bands from 380 nm to 14 microns, so the CIE definition of brightness won't do.
Andrew Bettison
Acacia Research Pty Ltd
Hi Andrew,
Since we needed to make exact comparisons between rendered images by pixel subtraction, I gave up on my efforts to run Radiance many times for spectral sampling, and we used my coauthor's (Elena's) Monte Carlo ray-tracer, instead. If regenerating the exact samples isn't an issue for you, you probably can run Radiance many times, however, and others have done this.
The best way to do it for non-human consumption is to defined many materials files, one for every three samples, and render from these in a for loop. The only place RGB is assumed in the code is when it's combining primaries to get brightness for a weight test or somesuch, and it shouldn't affect the result much for adjacent samples, which should be fairly similar.
Good luck!
Date: Thu Jun 19, 2003 12:50:14 AM US/Pacific
Greg,
Andrew Bettison
