We have run Radiance/rpiece again, making sure that we are, in fact, running
the version incorporating Greg's suggested correction in ambient.c but ended
up with the same error:
"rpict inconsistency
address not found in avlemi
rpiece error reading from rpict"
Message: 1
Date: Thu, 30 Jan 2003 07:16:41 -0800
To: [email protected]
Subject: [Radiance-general] Re: multi-processing on SGI Onyx
Reply-To: [email protected]The magic word to change is in src/rt/ambient.c, in the function
aposcmp(avp1, avp2), which should be corrected to read:/* GW NOTE 2002/10/3:
* I used to compare AMBVAL pointers, but found that this was the
* cause of a serious consistency error with gcc, since the optimizer
* uses some dangerous trick in pointer subtraction that
* assumes pointers differ by exact struct size increments.
static int
aposcmp(avp1, avp2) /* compare ambient value
positions */
char **avp1, **avp2;
return(*avp1 - *avp2);
On another note, I have been following with interest the discussion on
parallel rendering solutions and alternatives to a working NFS lock
manager. I haven't responded because I haven't had anything
intelligent to add... It's sounding like the consensus is headed the
direction of a socket-based client/server solution. A dreadful pain to
implement from all I've seen, but perhaps it's best in the long run.-Greg
