Hi Vera,
They are a bit dated at this point, but some older Radiance models may be found from the original Download page under "models":
which gets you to:
You generally need to use "make" to build the octrees, etc., so hope you're OK with that. If you don't have the make program, you can do it by hand following what is written in the included Makefile's.
Best,
-Greg
Subject: Re: [Radiance-general] Models for radiance scenes
Date: May 16, 2014 1:01:59 PM PDTVera,
Just in case you do not find the answer (it would be good to find models with well-defined materials and parameters); I guess what you can do is to use any CAD program with an exporter. This should work in case working with triangles (not continous spheres, cones or cylinders) is OK for you.
There is one called Groundhog project, which you can use to create your own Radiance models in SketchUp. Also, you should be able to use models from the 3D Warehouse; so you will have cars and/or furniture available for download.
The project is still in development, but I used it and developed it during my 2 year MSc. Thesis; and I guess it is already "OK" for others to use it... It is free and Open Source.
http://groundhoglabs.github.io/Groundhog/
There are also other CAD programs/extentions that you can use with the same purpose... SU2RAD, Ecotect, blender, OpenStudio, etc.
Any doubt, do not hesitate in contact me.
Germán
2014-05-16 15:46 GMT-04:00 Vera Liu <[email protected]>:
Hi Radiance experts,
I'm conducting an experiment on evaluation of different algorithms to light and colour analysis on materials. Previously we've only analyzed on real-world scenes. And we're looking for to do some experiments on simulation scenes and we figured pictures generated by radiance using light simulation would be perfect. Currently the scenes I'm using are from the tutorials of Rendering with Radiance. I'm wondering if there are any public available datasets of built radiance models such as tables, windows, chairs... that I could use? Thank you very much for taking a look!Best,
Vera
