modeling an insulating glass with an integrated capillary slab
Hi Valeria,
Trans is a quick and easy way to model this type of glazing.
You can use this widget to generate a trans material definition by entering your transmission and reflection parameters: http://gaia.lbl.gov/people/andy/public/transwidget/
However trans does not account for Fresnel effects that reduce transmission of glass at non-normal incidence angles (http://en.wikipedia.org/wiki/File:Amptitude_Ratios_air_to_glass.JPG). So treat trans results with some degree of caution.
If you want to include fresnell effects and diffusion, you might consider use a glass surface and a trans surface one in front of the other. Or you could generate a BSDF and use the new BSDF material.
Hope this helps,
Andy
On Apr 27, 2012, at 1:34 PM, Valeria De Giuli wrote:
Dear all,
I have to model a two-pane glass make up with a selective 6mm outer pane with an integrated capillary slab (it is called kapilux), white tinted. The obtained effect is a uniform and diffuse light transmittance. The only technical data that I have are: 30% of direct visible transmittance and 15% of diffuse visible transmittance. I think I should model it with "trans" material, but I don't know which parameters I have to use. Does anybody has an idea?
Thanks in advance. Best regards,
Valeria
Thank you Andy, this is a quick and useful widget, however in this case I have only direct and diffuse visible transmission, therefore I can only assign the diffuse transmission. Am I right?
Valeria
Il giorno 27/apr/2012, alle ore 23:31, Andy McNeil ha scritto:
Hi Valeria,
Hope this helps,
Andy
Dear all,
Valeria
Thanks Zack. you're right. I just switched the labels.
I should also mention that this widget only works on browsers that support web kit: safari & chrome. not firefox. I don't know about IE.
If you're on a mac, you can get it as a dashboard widget here: http://software.mcneilorama.com/Gen_Trans_Widget.html
On Apr 27, 2012, at 3:17 PM, Zack Rogers wrote:
Hi Andy,
I think your roughness and absorption input labels are switched in this widget. This is a nice little tool - thanks!
Zack
On Fri, Apr 27, 2012 at 3:31 PM, Andy McNeil <[email protected]> wrote:
Hi Valeria,
Hope this helps,
Andy
> Dear all,
> Valeria
> [email protected]
Zack Rogers, P.E., LEED AP BD+C
Daylighting Innovations, LLC
211 North Public Road, Suite 220
Lafayette, CO 80026
(303)946-2310
It's really tough to say without knowing what they mean by direct and diffuse transmission. From their website I understand that by "direct" they mean normal incidence direct-hemispherical transmission and by "diffuse" they mean hemispherical-hemispherical transmission. I would suggest setting Td to 30% and know that for non-normal incidence angles you will over estimate overall transmission.
This product, with it's capillary tubes and diffusing papers, is a perfect example of a system that should be modeled with a BSDF. Unfortunately your options for BSDF characterization are murky at best right now.
Andy
Valeria
Hi Valeria,
Hope this helps,
Andy
Dear all,
Valeria
Is this similar to the translucent panel modeled by Christoph Reinhart and Marilyne Andersen in the following paper?
  http://www.nrc-cnrc.gc.ca/obj/irc/doc/pubs/nrcc48165/nrcc48165.pdf
I believe they developed a Radiance description for it.
Date: April 27, 2012 3:42:25 PM PDT
Andy
Valeria
Hi Valeria,
Hope this helps,
Andy
Dear all,
Valeria
Thank you all! Yes, the product I have to model is the Kapilux. I'm going through the report of Christoph and Marilyne: I think that product is very similar to the one I have to simulate. I have decided to model it following the second option (trans 16%), using the diffuse-diffuse transmittance instead of the direct normal hemispherical (30% in my case). I then put the same values for the other parameters. Do you think it is correct?
Thanks a lot,
Valeria
Andy
Valeria
Hi Valeria,
Hope this helps,
Andy
Dear all,
Valeria
