Metal roofing
Can someone point me to a cal file, or a method to make a metal roof?
Something with a profile like this ASCII art
        __ __
_______| |_________| |____ etc...
Even a brightdata (without the ridge geometry) that would indicate the
ridges.
I thought there was one in the sample Radiance files (cabin, etc) but I
can't find it.
Thanks
BTW - progress renders are here...
http://www.rastermon.com/Remodel.htm
Rob
From: Fitzsimmons, Rob [mailto:rob.fitzsimmons@summit.fiserv.com]
Sent: Friday, May 26, 2006 11:24 AM
To: 'Radiance-general@radiance-online.org'
Subject: RE: RE: [Radiance-general] Art work surface
Here is version 1 of our remodel
http://www.geocities.com/rastermon/Version1.html
The designer is using Sketchup and I'm rendering with - of course -
Radiance. Composite done in photosop. Radiance view did not match pic, so I
did a little skewing in PS.
Thanks for all the input on art lighting - I'll post pics as it comes
along.
Rob
Sent: 5/26/2006 2:05 AM
Subject: Re: RE: [Radiance-general] Art work surface
Hi Thomas!
They were directed to north because they had to be huge and you had to
avoid direct sunlight. Northern light also varies not much over the
day.
Ok... that is what I wanted to describe as continous ;-)))
Only directional light would indeed be irritating but you need a
certain directional component to render the shape.
Well, if you have no clear window at all you also might get mad.
No! Don't use that stuff! We had an exhibition pavillion in my
university built with honeycomb insulation between two glass profiles.
The profiles alone might have worked well but the building inspector
insisted in an insulation of the wall. The honeycombs diffuse the
light so much that there is hardly a directional component left. It
looks odd and the sculptures and architectural modells are shaded
poorly even if the interior is rather bright.
That sounds interesting, as I actually do not have experienced such a room.
Were the panels used on all sides or to one direction only? My idea was to
have a big diffuse-translucent wall (only) to north. Also Ithink that for an
exhibition pavillion, especially for architectural models, a diffuse
environment is a terrific idea. All those I know use spots to take fotos of
their models and to show them (of course with a diffuse environment around).
But I really wonder on the impact of these panels on color, did you
experience any noticable effect? It would also interesting to know what
happens after some years, at least with those based on plastics (I would not
worry about the glass-based products, but I am also not sure here).
Christopher has done validation work on such panels, maybe he has more to
say about it.
This e-mail, (and any attachments) is confidential and may be
privileged.
It may be read, copied and used by the intended addressee only. If
you
have received this in error please contact BDP immediately.
If you have any queries, please contact the sender.
Building Design Partnership
Registered in England No 2207415:
Registered Office: Building Design Partnership Ltd, Sunlight House, PO
Box
85, Quay Street, Manchester, M60 3JA, http://www.bdp.co.uk
Radiance-general mailing list Radiance-general@radiance-online.org
Hi Rob,
One thing to try would be to use the corrug.cal which simulates corrugations. I know this is not exactly the same but it would give you the linear effect of such a roofing material. One could probably modify this with a step function to great a sharp cutoff versus what the smooth funtion in corrug.cal. Perhaps another option would be to engineer a simple repetitive cal with with perhaps three different value (color at top of metal rib, color at bottom and shadow). Yet another alternative could be to make an image map in Gimp (or photoshop) that can be tiled to create the effect you want.
        __ __
ridges.
can't find it.
Thanks
Rob
From: Fitzsimmons, Rob [mailto:rob.fitzsimmons@summit.fiserv.com] Sent: Friday, May 26, 2006 11:24 AM
along.
Rob
Hi Thomas!
They were directed to north because they had to be huge and you had to avoid direct sunlight. Northern light also varies not much over the day.
Only directional light would indeed be irritating but you need a certain directional component to render the shape.
No! Don't use that stuff! We had an exhibition pavillion in my university built with honeycomb insulation between two glass profiles. The profiles alone might have worked well but the building inspector insisted in an insulation of the wall. The honeycombs diffuse the light so much that there is hardly a directional component left. It looks odd and the sculptures and architectural modells are shaded poorly even if the interior is rather bright.
say about it.
privileged.
you
Box
# Jack de Valpine
