the colour picker can be a little flaky in browsers other than Firefox.
It sounds as if the selector (XYZ/xyY/CMYK/Lab) is not working for you?
Please be aware that the Lab conversion only has an amber traffic light,
which means it kind of works, but might not 100% reliable, or hasn't been
tested very thoroughly.
Thanks!
Any idea if the X, Y and Z options there are, actually, the L, *a, *b?
Still courious about the gloss... I read, somewhere I havent been able
to find again, that they did not really work.
Bye!
2014-03-27 17:47 GMT-03:00 Michael Martinez <michael@coolshadow.com
<mailto:michael@coolshadow.com>>:
Hi German,
Axel Jacobs' colour picker has a CIELab to Radiance RBG converter
under the Import tab:
http://www.jaloxa.eu/resources/radiance/colour_picker/index.shtml
Also curious to hear if/how folks have used a gloss meter for
specular measurements...
Mike
On Mar 27, 2014, at 6:17 AM, CHI-German Molina wrote:
Dear Gurus,
I am working in a company that sells and manufactures Shading
Devices and some other things. I will probably have to measure and
make a library of materials and products.
We have a Spectrophotometer that returns CIELab color... and also
a Gloss meter. Is it possible to use those two devices to get
materials?
Is there any .cal file that converts from CIELab to Radiance RGB?
is GLoss a way of cuantifying real "Radiance specularity"?
THANKS IN ADVANCE
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445 <tel:%2B569%2089224445>
*Nota de Confidencialidad:* Este mensaje incluído los archivos
adjuntos son confidenciales y pueden contener informacion
privilegiada protegida por ley. Si Ud. no es el destinatario,
deberia abstenerse de copiarlo, distribuirlo, divulgarlo o usar la
informacion contenida. Por favor, avise inmediatamente al emisor y
borre este mensaje de su sistema. Los mensajes electronicos son
susceptibles de ser cambiados, infectados o adulterados sin
autorizacion. No asumimos responsabilidad alguna por ninguna clase
de cambios o sus consecuencias. Usted debe estar informado que la
compania puede hacer un seguimiento de sus mensajes electronicos y
su contenido, gracias.
*Confidentiality Notice:* The information contained in this email
message, including any attachment, is confidential and is intended
only for the person or entity to which it is addressed. If you are
neither the intended recipient nor the employee or agent
responsible for delivering this message to the intended recipient,
you are hereby notified that you may not review, retransmit,
convert to hard copy, copy, use or distribute this email message
or any attachments to it. If you have received this email in
error, please contact the sender immediately and delete this
message from any computer or other data bank, Thank you.
A informação transmitida é confidencial e para conhecimento
exclusivo do destinatário. Sua utilização, não autorizada,
constitui crime passível de prisão. Todas as precauções possíveis
foram tomadas para garantir que este e-mail não contenha vírus.
Uma vez que nossa empresa não pode assumir responsabilidade por
nenhuma perda ou dano causado por este e-mail ou de seus anexos,
recomendamos que o destinatário utilize seus procedimentos de
<mailto:Radiance-general@radiance-online.org>
*Germán Molina L.*
Ingeniero Trainee
*Nota de Confidencialidad:* Este mensaje incluído los archivos adjuntos
son confidenciales y pueden contener informacion privilegiada protegida
por ley. Si Ud. no es el destinatario, deberia abstenerse de copiarlo,
distribuirlo, divulgarlo o usar la informacion contenida. Por favor,
avise inmediatamente al emisor y borre este mensaje de su sistema. Los
mensajes electronicos son susceptibles de ser cambiados, infectados o
adulterados sin autorizacion. No asumimos responsabilidad alguna por
ninguna clase de cambios o sus consecuencias. Usted debe estar informado
que la compania puede hacer un seguimiento de sus mensajes electronicos
y su contenido, gracias.
message, including any attachment, is confidential and is intended only
for the person or entity to which it is addressed. If you are neither
the intended recipient nor the employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that you may not review, retransmit, convert to hard copy,
copy, use or distribute this email message or any attachments to it. If
you have received this email in error, please contact the sender
immediately and delete this message from any computer or other data
bank, Thank you.
destinatário. Sua utilização, não autorizada, constitui crime passível
de prisão. Todas as precauções possíveis foram tomadas para garantir que
este e-mail não contenha vírus. Uma vez que nossa empresa não pode
assumir responsabilidade por nenhuma perda ou dano causado por este
e-mail ou de seus anexos, recomendamos que o destinatário utilize seus
procedimentos de antivírus antes de qualquer uso.
