manipulate rtrace for desired outcome
Currently I'm using the ray tracing engine of radiance, trying to figure
out the ray paths connecting designated view points and light resources (in
cylinder and polygon type). In this process, I've encountered some
difficulties that I'd appreciate your assistance.
I'm mainly using light as primitive type, since I want to figure out the
possible ray paths between receiver point and artificial light sources.
However the ray paths is not what I’ve expected.
In the testing condition where there is one receiver and one polygon light
sources directly exposed to each other. The polygon light source is the
only light in this scene. The source and receiver are placed in the middle
of two building blocks. I’m controlling rtrace function with the parameters
‘ –ab’ ‘ –ad’ ‘–dj’ ‘– ds’ ‘-st’ ‘-ss’.
1. No matter what parameters I’ve set for rtrace function, there’s
only one ray in the output. Yet, I’m expecting multiple rays emitted from
the receiver points to the light source, as described in radiance manual.
2. I’d also like to know what parameters can control reflections
characters of rays. For instance, I want the rays to partly diffuse after
reflecting on the surface. The desirable condition is: for a bundle of rays
hitting the surface, 1) 70% of the rays will follow specular reflection,
30% will be scattered after reflection. 2) for the scattered part, I want
them to be reflected within an angle (e.g. 30 degree) to the specular
reflected ray.
Could you suggest me how to achieve the condition of 1 and 2 with radiance?
Is there any other suggestions on the setting of model or scene?
3. Another question is: acknowledged that the emitted rays are not
evenly distributed for hemispherical sampling. I'm still wondering if it's
possible to evenly send rays with radiance.
Thank you very much with best regards,
Mengdi Guo
Mengdi,
Answers inline below...
By default rtrace outputs the accumulated value of the input ray. If you
want it to output information for rays traced to arrive at the reported
value you should use -o with either t or T. See the rtrace manual page for
more output options:
reflected ray.
The relative weight of specular vs. diffuse rays is a result of the
material applied to the surface. if you use a plastic material such as
below (with 15% diffuse reflectance, 35% specular reflectance, and 0.05
roughness):
void plastic test70-30
5 0.15 0.15 0.15 0.35 0.05
then the specular rays will account for 30% of the final ray value and the
diffuse rays will account for 70% of the final ray value. However the
actual number of rays spawned are controlled by the -ad parameter for
diffuse rays and -ss parameter for specular rays, with the caveat that only
one ray is traced for the specular reflections if the roughness is 0,
otherwise you'd be tracing the same ray several times.
It seems to me that you want pure specular and scattered specular rays
together, so you'll probably need want to use a plasdata material
definition. The reference manual provides info on materials:
http://radsite.lbl.gov/radiance/refer/refman.pdf
The spawned rays are random, but are distributed such that each ray as
equal influence on the result. This produces a non-biased estimate. If by
even you mean that you don't want a cosine factor on the distribution of
rays, you should look at plasdata. If however by evenly distributed you
don't want them to be randomized, I'm not sure that's possible without
going into the Radiance code, and doing this will result in a biased
estimate.
John Mardaljevic gives a good presentation on how radiance spawns rays in
order to find a result:
And chapter 12 in Rendering with Radiance gives a detailed overview of how
this all works:
http://radiance-online.org/learning/documentation/book/rwrcontents
Andy
On Mon, Jun 13, 2016 at 10:56 PM, Mengdi Guo <[email protected]> wrote:
reflected ray.
radiance? Is there any other suggestions on the setting of model or scene?
Mengdi Guo
Dear Andy,
Well received. Thank you very much for your kind help.
Mengdi
On 23 June 2016 at 05:53, Andy McNeil <[email protected]> wrote:
Mengdi,
http://radiance-online.org/learning/documentation/manual-pages/pdfs/rtrace.pdf
reflected ray.
roughness):
estimate.
http://radiance-online.org/community/workshops/2014-london/presentations/day1/Mardaljevic_AmbientCrash.pdf
this all works:
Andy
On Mon, Jun 13, 2016 at 10:56 PM, Mengdi Guo <[email protected]> > wrote:
light sources directly exposed to each other. The polygon light source is
the only light in this scene. The source and receiver are placed in the
middle of two building blocks. I’m controlling rtrace function with the
parameters ‘ –ab’ ‘ –ad’ ‘–dj’ ‘– ds’ ‘-st’ ‘-ss’.
reflected ray.
Mengdi Guo
Mengdi GUO
PhD Candidate
the University of Hong Kong
Dear Andy,
I have one more question about this part of your reply:
*The relative weight of specular vs. diffuse rays is a result of the
roughness):*
How do you get the value: '*5% diffuse reflectance, 35% specular
reflectance, and 0.05 roughness' *from the setting of 'specular weight 30%
and diffuse weight 70% after reflection'.
*void plastic test70-30*
*0*
*0*
*5 0.15 0.15 0.15 0.35 0.05*
*then the specular rays will account for 30% of the final ray value and the
diffuse rays will account for 70% of the final ray value.*
Thanks a lot.
Mengdi
Mengdi,
reflected ray.
roughness):
estimate.
this all works:
Andy
reflected ray.
Mengdi Guo
Mengdi GUO
PhD Candidate
I assumed a total surface reflectance of 50%, with a split of 30:70 ratio
of diffuse to specular ratio. The roughness was a wild guess. Though I see
now that I flipped your diffuse - specular ratio, but you get the point.
Andy
On Mon, Jun 27, 2016 at 7:21 AM, Mengdi Guo <[email protected]> wrote:
Dear Andy,
roughness):*
30% and diffuse weight 70% after reflection'.
*0*
*0*
the diffuse rays will account for 70% of the final ray value.*
Thanks a lot.
Mengdi
Mengdi,
reflected ray.
roughness):
the diffuse rays will account for 70% of the final ray value. However the
not evenly distributed for hemispherical sampling. I'm still wondering if
it's possible to evenly send rays with radiance.
estimate.
how this all works:
Andy
On Mon, Jun 13, 2016 at 10:56 PM, Mengdi Guo <[email protected]> >> wrote:
there’s only one ray in the output. Yet, I’m expecting multiple rays
emitted from the receiver points to the light source, as described in
radiance manual.
reflected ray.
Mengdi Guo
Mengdi GUO
PhD Candidate
Dear Andy,
I've got two more questions about Radiance.
1) I'm using only 'light' type of source for rtrace operation, the output
of which contains a lot of rays that didn't hit the source in the end.
Loading the ray information of such output takes a long time. I'm curious
if it's possible to export only valid rays that connects receivers with
sources through radiance operation?
2) Another question is about the specular rays and diffuse rays. Is it
possible to specify specular ray from diffuse ones via Radiance operation?
Or have you already counted the energy distribution of these two types of
rays via cosine law in Radiance?
Thank you very much for your help.
Mengdi
Andy
On Mon, Jun 27, 2016 at 7:21 AM, Mengdi Guo <[email protected]> > wrote:
Dear Andy,
roughness):*
*0*
*0*
Thanks a lot.
Mengdi
Mengdi,
radiance manual.
more output options: http://radiance-online.org/learning/
reflected ray.
roughness):
estimate.
in order to find a result:
how this all works: http://radiance-online.org/learning/documentation/
book/rwrcontents
Andy
On Mon, Jun 13, 2016 at 10:56 PM, Mengdi Guo <[email protected]> >>> wrote:
figure out the ray paths connecting designated view points and light
resources (in cylinder and polygon type). In this process, I've encountered
some difficulties that I'd appreciate your assistance.
the possible ray paths between receiver point and artificial light sources.
radiance manual.
reflected ray.
Mengdi Guo
Mengdi GUO
PhD Candidate
Mengdi GUO
PhD Candidate
Hi Mengdi,
Did you try using the 'T' option of rtrace, e.g., "-oTMv" will report materials and values for each ray traced. The lower case 't' leaves out rays to light sources specifically, since there are so many of them in general. To filter out just the source rays, you need to check the deepest-level (most tabbed) reports in the output and check that the material matches one in your scene description that is the "light" type.
There is no easy way in Radiance to differentiate "specular" from "diffuse" rays in the calculation. Within the code itself, you can get clues from the ray type, but this isn't one of the things reported by rtrace. You can of course hack the C code if you like. That's what it's there for....
Date: September 26, 2016 6:28:21 AM PDT
Dear Andy,
1) I'm using only 'light' type of source for rtrace operation, the output of which contains a lot of rays that didn't hit the source in the end. Loading the ray information of such output takes a long time. I'm curious if it's possible to export only valid rays that connects receivers with sources through radiance operation?
2) Another question is about the specular rays and diffuse rays. Is it possible to specify specular ray from diffuse ones via Radiance operation? Or have you already counted the energy distribution of these two types of rays via cosine law in Radiance?
Mengdi
I assumed a total surface reflectance of 50%, with a split of 30:70 ratio of diffuse to specular ratio. The roughness was a wild guess. Though I see now that I flipped your diffuse - specular ratio, but you get the point.
Andy
Dear Andy,
The relative weight of specular vs. diffuse rays is a result of the material applied to the surface. if you use a plastic material such as below (with 15% diffuse reflectance, 35% specular reflectance, and 0.05 roughness):
How do you get the value: '5% diffuse reflectance, 35% specular reflectance, and 0.05 roughness' from the setting of 'specular weight 30% and diffuse weight 70% after reflection'.
then the specular rays will account for 30% of the final ray value and the diffuse rays will account for 70% of the final ray value.
Thanks a lot.
Mengdi
Mengdi,
1. No matter what parameters I’ve set for rtrace function, there’s only one ray in the output. Yet, I’m expecting multiple rays emitted from the receiver points to the light source, as described in radiance manual.
By default rtrace outputs the accumulated value of the input ray. If you want it to output information for rays traced to arrive at the reported value you should use -o with either t or T. See the rtrace manual page for more output options: http://radiance-online.org/learning/documentation/manual-pages/pdfs/rtrace.pdf
2. I’d also like to know what parameters can control reflections characters of rays. For instance, I want the rays to partly diffuse after reflecting on the surface. The desirable condition is: for a bundle of rays hitting the surface, 1) 70% of the rays will follow specular reflection, 30% will be scattered after reflection. 2) for the scattered part, I want them to be reflected within an angle (e.g. 30 degree) to the specular reflected ray.
then the specular rays will account for 30% of the final ray value and the diffuse rays will account for 70% of the final ray value. However the actual number of rays spawned are controlled by the -ad parameter for diffuse rays and -ss parameter for specular rays, with the caveat that only one ray is traced for the specular reflections if the roughness is 0, otherwise you'd be tracing the same ray several times.
It seems to me that you want pure specular and scattered specular rays together, so you'll probably need want to use a plasdata material definition. The reference manual provides info on materials: http://radsite.lbl.gov/radiance/refer/refman.pdf
3. Another question is: acknowledged that the emitted rays are not evenly distributed for hemispherical sampling. I'm still wondering if it's possible to evenly send rays with radiance.
The spawned rays are random, but are distributed such that each ray as equal influence on the result. This produces a non-biased estimate. If by even you mean that you don't want a cosine factor on the distribution of rays, you should look at plasdata. If however by evenly distributed you don't want them to be randomized, I'm not sure that's possible without going into the Radiance code, and doing this will result in a biased estimate.
John Mardaljevic gives a good presentation on how radiance spawns rays in order to find a result:
And chapter 12 in Rendering with Radiance gives a detailed overview of how this all works: http://radiance-online.org/learning/documentation/book/rwrcontents
Andy
