alex Summerfield wrote:
Hi
Ok sorry if this is a stupid question but here goes...
Got a new HD and decided to do a clean install of 10.3 and to reinstall Radiance.
(I'd been using it without xwindows).Initially just did radiance-rad3R5.tgz
- didn't worry about the auxilary files because apparently that's just 'images' (a major understatement).
well, mate. It says "e.g. images" not "just images" . Quote:
Steps to install Radiance from source:
1. download one CVS tar ball (stable or pre-release version)
2. download tar ball of auxilary files
3. unpack both tar balls (unpacks to directory /ray/) : |gunzip <
/file/ | tar xf -|
4. |cd ray; makeall install|
Let me know how the clearity of that could be enhanced and I add it.
The reason to split is that the "aux" files don't change as frequently as some parts of the source do. So, to be updated, folks just need the nightly "HEAD" version and not the whole bunch. (In fact only the diff patches are needed for those still behind a slow modem line).
Radiance installs and works fine - except.. missing all the useful stuff such as 'pfilt' 'pcond', and a zillion other goodies all in the rad3R5supp.tar.gz - but this doesn't have an install program.
OK so when the 2 downloads are unpacked i have 2 directories 'ray' and ' ray1' (auxilary files).
They both unpack into a subdir 'ray' . Your "ray1" is generated by your download/unpack program, presumably to intelligently avoid cluttering the already existing subdir 'ray' .
Almost seems as though I need to go through ray1 and shift the various programs across to their corresponding directory in ray. (can't be right, can it?).
I resorted to the LBNL download (which isn't split) but then hit a whole bunch of compilation errors (the installer is pretty different there too - for instance it doesn't ask for the users system or where library files should go). Spent a long time on trying to solve possible causes without much luck...
I don't know if and how the packages at LBNL are updated.
-Peter
