Dear all,
I have a question regarding the luminance prediction (cd/m2) on the plane for certain points. and any help would really be appreciated.
I have measured certain points with an luminance meter. I have used also image-based for the same points to extract the luminance and I have very similar results. I need to use also simulation-based luminance values for the same points and compare the results with the measured and image based ones.
Before, I have simulated only Illuminances. How can I measure the Luminances?
Here is the code I use to predict the illuminance:
# commands to run
commands = ["rm -f /tmp/bpi.amb",
"oconv env.rad lab_surfaces_corrected_moved.rad lab_windows_and_doors.rad strato_sokol2.rad> lab.oct",
"echo '4.52 0.85 0.74 0 0 1 " +
"3.74 1.13 0.74 0 0 1 " +
"4.52 1.13 0.74 0 0 1 " +
"5.30 1.13 0.74 0 0 1 " +
"3.74 2.13 0.74 0 0 1 " +
"4.52 2.13 0.74 0 0 1 " +
"5.30 2.13 0.74 0 0 1 " +
"3.74 3.13 0.74 0 0 1 " +
"4.52 3.13 0.74 0 0 1 " +
"5.30 3.13 0.74 0 0 1 " +
"' | rtrace -w -af /tmp/bpi.amb -as 512 -ar 64 -aa 0.15 -ab 2 -I+ -h lab.oct | rcalc -e '$1=($1*0.265+$2*0.670+$3*0.065)* 179'",
Any help would be really appreciated,
Thank you very much
Best regards,
Sokol Dervishi
Dear all,
# commands to run
Thank you very much
Best regards,
Sokol Dervishi
To calculate Luminance instead of Illuminance just remove "-I+" flag
from your rtace command:
rtrace -w -af /tmp/bpi.amb -as 512 -ar 64 -aa 0.15 -ab 2 -h lab.oct |
I also propose you to set higher ambient parameters ( for example -as
1024 -ar 200 -aa 0.1 -ab 5), since you only have calculation in few
points.
Hope this helps,
Marija.
2008/5/19 sokol dervishi <dervishi_sokol@yahoo.com>:
Dear all,
ones.
Luminances?
# commands to run
Thank you very much
Best regards,
Sokol Dervishi
This seems to be a repeat posting of something sent out on Saturday. There is no need to post things twice -- we did get it the first time. If you are unsure if a posting has made it to the list, you can always go online to check:
http://www.radiance-online.org/pipermail/radiance-general/
I did not reply to this right away, since it is really a basic question, and I figured any number of people could handle it. In any case, a careful reading of the rtrace man page should give the answer. Quoting from the first paragraph of:
http://radsite.lbl.gov/radiance/man_html/rtrace.1.html
"Input for each ray is:
xorg yorg zorg xdir ydir zdir
You simply start the ray an arbitrary distance from your surface and give it a vector corresponding to the desired luminance measurement. The returned values (when you run rtrace without the -I+ option) will be in SI radiance units (watts/sr/meter^2),which may be converted to luminance (in candelas/meter^2) using the formula specified under the "Examples" section:
rtrace -h scene.oct <lum_meas.pts | rcalc -e '$1=47.4*$1+120*$2+11.6*$3'
I hope this helps.
Date: May 19, 2008 7:31:27 AM PDT
Dear all,
# commands to run
Thank you very much
Best regards,
Sokol Dervishi
Thank you very much for your replies. Actually I thought my e_mail was not sent and I apologize for sending it twice.
Best Regards,
Sokol
