On 1/20/15, 10:55 AM, "Todor Syarov" <thodor@abv.bg<mailto:thodor@abv.bg>> wrote:
Thank you , Robert!
for bearing with my dotting qestions!, especially since i was triggering already since a week linking through forums.
It works and I can start.
It was a great help - thank you again!
best Regards,
Niya
-------- Оригинално писмо --------
От: "Guglielmetti, Robert" Robert.Guglielmetti@nrel.gov<mailto:Robert.Guglielmetti@nrel.gov>
Относно: Re: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
До: Radiance general discussion <radiance-general@radiance-online.org<mailto:radiance-general@radiance-online.org>>
Изпратено на: 20.01.2015 19:29
The makeall step is not required if you are using the pre-compiled binaries. If you ran the installer and changed the patches, you are all set to… "begin". =)
First things first, you might now wanna try running the benchmark, or at least checking the basic installation is sound by typing "which rpict" at the command line. Should return "/usr/local/radiance/bin/rpict".
What you have now is Radiance installed on your Mac. Actually using it is the next exciting step, unfortunately it's a little more complicated than just running an executable and poking around in some menus. I recommend checking out some tutorials on the main site, and browsing the radiance-online listserv archives (http://www.radiance-online.org/community/mailing-lists/archives/radiance-general).
Wheeeeee!
On 1/20/15, 10:10 AM, "Todor Syarov" <thodor@abv.bg<javascript:%20internSendMess('thodor@abv.bg')><mailto:thodor@abv.bg>> wrote:
!good- i have changed the paths
can I proceed from the line:
sudo ./makeall install
or how shall I go on?
От: "Guglielmetti, Robert" Robert.Guglielmetti@nrel.gov<javascript:%20internSendMess('Robert.Guglielmetti@nrel.gov')><mailto:Robert.Guglielmetti@nrel.gov>
До: Radiance general discussion <radiance-general@radiance-online.org<javascript:%20internSendMess('radiance-general@radiance-online.org')><mailto:radiance-general@radiance-online.org>>
Изпратено на: 20.01.2015 18:59
Yeah, grab radiance 4.2.2-darwin.dmg and double-click that, then dbl-click on the installer package and follow the directions. Afterward, you still need to do the path setting step detailed by Andy in his video, just substituting the paths from my last email. If you use that installer, you don't need the source code (well, it's still useful for general interest, but you don't need it to run Radiance on your computer).
P.S. You can also browse the source code on the GitHub mirror, and see the entire revision history, here:
https://github.com/NREL/Radiance/tree/combined (make sure you're on the "combined" branch, which is the one we keep up to date with Greg's changes (hourly).) It's pretty awesome to see every change through time!
On 1/20/15, 9:51 AM, "Todor Syarov" <thodor@abv.bg<javascript:%20internSendMess('thodor@abv.bg')><javascript:%20internSendMess('thodor@abv.bg<mailto:'thodor@abv.bg>')><mailto:thodor@abv.bg>> wrote:
Thank you Rob, for the fast reply and the link provided!!!
ok, so I would need now only to the radiance 4.2.2-darwin.dmg to unpack, no?
what do I need the source code for? -is it the non-compiled version of radiance 4.2.2-darwin.dmg?
От: "Guglielmetti, Robert" Robert.Guglielmetti@nrel.gov<javascript:%20internSendMess('Robert.Guglielmetti@nrel.gov')><javascript:%20internSendMess('Robert.Guglielmetti@nrel.gov<mailto:'Robert.Guglielmetti@nrel.gov>')><mailto:Robert.Guglielmetti@nrel.gov>
До: Radiance general discussion <radiance-general@radiance-online.org<javascript:%20internSendMess('radiance-general@radiance-online.org')><javascript:%20internSendMess('radiance-general@radiance-online.org<mailto:'radiance-general@radiance-online.org>')><mailto:radiance-general@radiance-online.org>>
Изпратено на: 20.01.2015 18:35
OK this one means you don't have the X11 libraries installed. This is something you need to have on your system in addition to XCode in order to build a few of the Radiance programs (rvu, image, etc.). Your build probably failed and you have a somewhat busted installation of Radiance, here.
(Bias alert) may I suggest you try the Mac Radiance installer we have available?
These have everything built already, and the installer puts everything in:
/usr/local/radiance/lib
/usr/local/radiance/man
…and you can follow Andy's path setting tricks in that video you posted to get this all dialed in and working for ya.
On 1/20/15, 9:25 AM, "Todor Syarov" <thodor@abv.bg<javascript:%20internSendMess('thodor@abv.bg')><javascript:%20internSendMess('thodor@abv.bg<mailto:'thodor@abv.bg>')><javascript:%20internSendMess('thodor@abv.bg<mailto:'thodor@abv.bg><mailto:'thodor@abv.bg>')><mailto:thodor@abv.bg>> wrote:
One of the first messages I was getting before error 127
was:
x11image.c:26:11: fatal error: 'X11/Xlib.h' file not found
#include <X11/Xlib.h>
eventhough i I had checked before installing the compatibility btw OS system and Xcode
От: "Brian Karr" brianakarr@yahoo.com<javascript:%20internSendMess('brianakarr@yahoo.com')><javascript:%20internSendMess('brianakarr@yahoo.com<mailto:'brianakarr@yahoo.com>')><javascript:%20internSendMess('brianakarr@yahoo.com<mailto:'brianakarr@yahoo.com><mailto:'brianakarr@yahoo.com>')><mailto:brianakarr@yahoo.com>
До: "'Radiance general discussion'" <radiance-general@radiance-online.org<javascript:%20internSendMess('radiance-general@radiance-online.org')><javascript:%20internSendMess('radiance-general@radiance-online.org<mailto:'radiance-general@radiance-online.org>')><javascript:%20internSendMess('radiance-general@radiance-online.org<mailto:'radiance-general@radiance-online.org><mailto:'radiance-general@radiance-online.org>')><mailto:radiance-general@radiance-online.org>>
Изпратено на: 20.01.2015 17:46
Not sure if this applies, when I installed on Mac this thread helped:
http://www.radiance-online.org/pipermail/radiance-dev/2003-October/000221.html
P.S. For some reason, the source auxiliary files are not included in
the HEAD distribution. The following files are missing:
ray/src/common/tmesh.cal
ray/src/cv/lamp.tab
ray/src/cv/source.cal
ray/src/cv/tilt.cal
ray/src/gen/clockface.hex
ray/src/gen/glaze1.cal
ray/src/gen/glaze2.cal
ray/src/gen/illum.cal
ray/src/gen/rev.cal
ray/src/gen/skybright.cal
ray/src/gen/surf.cal
ray/src/rt/rayinit.cal
Sent: Tuesday, January 20, 2015 10:02 AM
Subject: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
Dear all,
I wanted to install on Mac/Yosemite/ Radiance
rad4R2supp.tar.gz
Xcode is installed and updated for compatibility with OS Yosemite*
following the instruction :https://www.youtube.com/watch?v=ptTmdKSfK68#t=137
I believe I have done something wrong installing it:
#after setting the Raypath , Path and Manpath as in the video
#I have unpacked benchmark
#typed :make (command)// "i have one processor"
and experienced the following error
CHANGES
2010-12-01 MJS reworked Makefile and options so that same code will
work on any version of Radiance going back ~5 years
2011-03-24 MJS removed "-pm 0.0" from optionsbase because rpiece throws
an error in 4R1
Niyas-iMac:bench4 niya$ make
/bin/sh: rpict: command not found
rm -f serial.unf
time rpict @viewpoint @options -x 2048 -y 2048 -t 60 -o serial.unf scene.oct
rpict: No such file or directory
0.00 real 0.00 user 0.00 sys
How do you solve such problem in order to proceed with installing Radiance on Mac?
Best Regards,
Niya
Radiance-general@radiance-online.org<javascript:%20internSendMess('Radiance-general@radiance-online.org')><javascript:%20internSendMess('Radiance-general@radiance-online.org<mailto:'Radiance-general@radiance-online.org>')><javascript:%20internSendMess('Radiance-general@radiance-online.org<mailto:'Radiance-general@radiance-online.org><mailto:'Radiance-general@radiance-online.org>')>
