Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
Hello Brian,
  Thank you for the fast response. I will give it a try.
  How do I deinstall Radiance to set it a new? I see only the unpacked folder. Is it just by deleting the folder - i guess that would be too easy to be true//
-------- Оригинално писмо --------
От: "Brian Karr" [email protected]
Относно: Re: [Radiance-general] Installing Radiance on OS Yosemite_make:
До: "'Radiance general discussion'"
Изпратено на: 20.01.2015 17:46
   .abv-omExternalClass p.MsoNormal, .abv-omExternalClass li.MsoNormal, .abv-omExternalClass div.MsoNormal { margin: 0.0in; margin-bottom: 1.0E-4pt; font-size: 12.0pt; font-family: 'Times New Roman', 'serif'; } .abv-omExternalClass a:link, .abv-omExternalClass span.MsoHyperlink { mso-style-priority: 99.0; color: #0000ff; text-decoration: underline; } .abv-omExternalClass a:visited, .abv-omExternalClass span.MsoHyperlinkFollowed { mso-style-priority: 99.0; color: #800080; text-decoration: underline; } .abv-omExternalClass p.p1, .abv-omExternalClass li.p1, .abv-omExternalClass div.p1 { mso-style-name: p1; mso-margin-top-alt: auto; margin-right: 0.0in; mso-margin-bottom-alt: auto; margin-left: 0.0in; font-size: 12.0pt; font-family: 'Times New Roman', 'serif'; } .abv-omExternalClass span.s1 { mso-style-name: s1; } .abv-omExternalClass span.EmailStyle19 { mso-style-type: personal-reply; font-family: 'Calibri', 'sans-serif'; color: #1f497d; } .abv-omExternalClass .MsoChpDefault { m
so-style-type: export-only; font-size: 10.0pt; } .abv-omExternalClass div.WordSection1 { page: WordSection1; }
     Not sure if this applies, when I installed on Mac this thread helped:
      http://www.radiance-online.org/pipermail/radiance-dev/2003-October/000221.html
     >> P.S.
For some reason, the source auxiliary files are not included in
     >> the HEAD distribution.
The following files are missing:
     >> ray/src/common/tmesh.cal
     >> ray/src/cv/lamp.tab
     >> ray/src/cv/source.cal
     >> ray/src/cv/tilt.cal
     >> ray/src/gen/clockface.hex
     >> ray/src/gen/glaze1.cal
     >> ray/src/gen/glaze2.cal
     >> ray/src/gen/illum.cal
     >> ray/src/gen/rev.cal
     >> ray/src/gen/skybright.cal
     >> ray/src/gen/surf.cal
     >> ray/src/rt/rayinit.cal
Sent: Tuesday, January 20, 2015 10:02 AM
Subject: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
     Dear all,
     I wanted to install on Mac/Yosemite/ Radiance
     rad4R2supp.tar.gz
     Xcode is installed and updated for compatibility with OS Yosemite*
     following the instruction :https://www.youtube.com/watch?v=ptTmdKSfK68#t=137
     I believe I have done something wrong installing it:
     #after setting the Raypath , Path and Manpath as in the video
     #I have unpacked benchmark
     #typed
:make (command)// "i have one processor"
     and experienced the following error
      CHANGES
      2010-12-01
MJS
reworked Makefile and options so that same code will
work on any version of Radiance going back ~5 years
      2011-03-24
MJS
removed "-pm 0.0" from optionsbase because rpiece throws
an error in 4R1
      Niyas-iMac:bench4 niya$ make
      /bin/sh: rpict: command not found
      rm -f serial.unf
      time rpict @viewpoint @options -x 2048 -y 2048 -t 60 -o serial.unf scene.oct
      rpict: No such file or directory
0.00 real
0.00 user
0.00 sys
     How do you solve such problem in order to proceed with installing Radiance on Mac?
Best Regards,
     Niya
One of the first messages I was getting before error 127 was:
   ---------------- x11image.c:26:11: fatal error: 'X11/Xlib.h' file not found
  #include
      --------------- eventhough i I had checked before installing the compatibility btw OS system and Xcode
     >> P.S.
     Dear all,
     rad4R2supp.tar.gz
     #typed
      CHANGES
      2010-12-01
MJS
      2011-03-24
MJS
an error in 4R1
      rm -f serial.unf
0.00 real
0.00 user
0.00 sys
Best Regards,
     Niya
