Dear experts, (particularly Andy),
First of all: I do not have any experience using all that java stuff.
Honestly I do hope, that you won't tell me to get used to it
And I hope you can reproduce my problems to a certain extend.
Thank you for any hint, or a description of the installation procedure.
------- Problem statement -----
I'm running into dozens of error messages using the install.sh bash in the
BSDFViewer Download from
http://www.radiance-online.org/download-install/bsdf-viewer/BSDFViewer1.3_ubuntu_64.tar
See these messages at the end of that email.
Anyway, the BSDFViewer starts up. But it doesn't work properly (I can click
on the incoming patch which gets yellow, but there is no output displayed -
in terminal following error message is displayed as soon as I load any xml.
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError:
Can't load library: /usr/local/lib/BSDFViewer/libBSDF.jnilib
or if any reload of another testBSDF is started:
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError:
Could not initialize class libBSDF
I'm well aware of the *mailing list* discussion on that topic. Back then,
Andy's question to Serge about his JAVA installation did not yield to any
conclusion as Serge's problem disappeared:
http://radiance-online.org/pipermail/radiance-general/2015-February/010783.html
------ Platform description ------------
platform: ubuntu 14.04 64bit on VMware(R)Player 7.0.0; Windows 7 host
Java -version gives:
java version "1.7.0_91"
OpenJDK Runtime Environment (IcedTea 2.6.3) (7u91-2.6.3-0ubuntu0.14.04.1)
OpenJDK 64-Bit Server VM (build 24.91-b01, mixed mode)
Please apologize for my poor debugging capabilities:
1. line 14 in Rmakefile defines LIBDIR = /usr/local/lib/ray . That's not
the place my radiane libs are located /usr/local/radiance/lib or whatever
is the users choice.
2. line 28 in install.sh asks for libBSDF.so, which is no located in that
place. instead: ./lib/libBSDF.so
3. the libBSDF.jnilib is not existing at all - so there is something
broken.
4. An error message about something called: ELFClass32 I tried to solve by
apt-getting different java platforms - as different forums told me.
THANK You,
br Robert
------------------ERRORS after sudo install.sh--------------
vm:/usr/local/radiance/BSDFViewer1.3_ubuntu_64$ sudo bash install.sh
rm -f *.o librtrad.a libmgf.a
cc -DBSD -O -c -o cone.o cone.c
cc -DBSD -O -c -o face.o face.c
cc -DBSD -O -c -o free_os.o free_os.c
cc -DBSD -O -c -o instance.o instance.c
cc -DBSD -O -c -o readobj.o readobj.c
readobj.c: In function ‘readobj’:
readobj.c:53:9: warning: ignoring return value of ‘fgets’, declared with
attribute warn_unused_result [-Wunused-result]
fgets(buf, sizeof(buf), infp);
cc -DBSD -O -c -o readoct.o readoct.c
cc -DBSD -O -c -o otypes.o otypes.c
cc -DBSD -O -c -o objset.o objset.c
cc -DBSD -O -c -o octree.o octree.c
cc -DBSD -O -c -o readfargs.o readfargs.c
cc -DBSD -O -c -o modobject.o modobject.c
cc -DBSD -O -DDEFPATH=\":/usr/local/lib/ray\" -c getlibpath.c
cc -DBSD -O -c -o addobjnotify.o addobjnotify.c
cc -DBSD -O -c -o zeroes.o zeroes.c
cc -DBSD -O -c -o mesh.o mesh.c
cc -DBSD -O -c -o readmesh.o readmesh.c
cc -DBSD -O -c -o tmesh.o tmesh.c
cc -DBSD -O -c -o sceneio.o sceneio.c
cc -DBSD -O -c -o color.o color.c
cc -DBSD -O -c -o header.o header.c
cc -DBSD -O -c -o image.o image.c
cc -DBSD -O -c -o lamps.o lamps.c
cc -DBSD -O -c -o resolu.o resolu.c
cc -DBSD -O -c -o rexpr.o rexpr.c
cc -DBSD -O -c -o spec_rgb.o spec_rgb.c
cc -DBSD -O -c -o colrops.o colrops.c
cc -DBSD -O -c -o font.o font.c
cc -DBSD -O -c -o tonemap.o tonemap.c
In file included from tonemap.c:17:0:
tmprivat.h:62:1: warning: variably modified ‘tmMesofact’ at file scope
[enabled by default]
extern uby8 tmMesofact[BMESUPPER-BMESLOWER];
tonemap.c:654:1: warning: variably modified ‘tmMesofact’ at file scope
cc -DBSD -O -DPCOND=\"pcond\" -c tmapcolrs.c
In file included from tmapcolrs.c:21:0:
cc -DBSD -O -c -o tmapluv.o tmapluv.c
In file included from tmapluv.c:19:0:
cc -DBSD -O -c -o tmaptiff.o tmaptiff.c
In file included from tmaptiff.c:15:0:
cc -DBSD -O -c -o tmap16bit.o tmap16bit.c
In file included from tmap16bit.c:14:0:
cc -DBSD -O -c -o bmpfile.o bmpfile.c
cc -DBSD -O -c -o falsecolor.o falsecolor.c
In file included from falsecolor.c:16:0:
cc -DBSD -O -c -o ezxml.o ezxml.c
cc -DBSD -O -c -o ccolor.o ccolor.c
cc -DBSD -O -c -o ccyrgb.o ccyrgb.c
cc -DBSD -O -c -o bsdf.o bsdf.c
bsdf.c: In function ‘SDloadFile’:
bsdf.c:182:2: warning: null argument where non-null required (argument 1)
[-Wnonnull]
if (strcmp(ezxml_name(fl), "WindowElement")) {
[-Wnonnull]
[-Wnonnull]
[-Wnonnull]
[-Wnonnull]
[-Wnonnull]
cc -DBSD -O -c -o bsdf_m.o bsdf_m.c
cc -DBSD -O -c -o bsdf_t.o bsdf_t.c
cc -DBSD -O -c -o loadbsdf.o loadbsdf.c
cc -DBSD -O -c -o disk2square.o disk2square.c
cc -DBSD -O -c -o hilbert.o hilbert.c
cc -DBSD -O -c -o fgetline.o fgetline.c
cc -DBSD -O -c -o fropen.o fropen.c
cc -DBSD -O -c -o linregr.o linregr.c
cc -DBSD -O -c -o xf.o xf.c
cc -DBSD -O -c -o mat4.o mat4.c
cc -DBSD -O -c -o invmat4.o invmat4.c
cc -DBSD -O -c -o fvect.o fvect.c
cc -DBSD -O -c -o urand.o urand.c
cc -DBSD -O -c -o urind.o urind.c
cc -DBSD -O -c -o calexpr.o calexpr.c
cc -DBSD -O -c -o caldefn.o caldefn.c
cc -DBSD -O -c -o calfunc.o calfunc.c
cc -DBSD -O -c -o calprnt.o calprnt.c
cc -DBSD -O -c -o biggerlib.o biggerlib.c
cc -DBSD -O -c -o multisamp.o multisamp.c
cc -DBSD -O -c -o unix_process.o unix_process.c
cc -DBSD -O -c -o process.o process.c
cc -DBSD -O -c -o gethomedir.o gethomedir.c
cc -DBSD -O -c -o getpath.o getpath.c
cc -DBSD -O -c -o error.o error.c
cc -DBSD -O -c -o savestr.o savestr.c
cc -DBSD -O -c -o savqstr.o savqstr.c
cc -DBSD -O -c -o badarg.o badarg.c
cc -DBSD -O -c -o fgetword.o fgetword.c
cc -DBSD -O -c -o words.o words.c
cc -DBSD -O -c -o expandarg.o expandarg.c
cc -DBSD -O -c -o wordfile.o wordfile.c
cc -DBSD -O -c -o fgetval.o fgetval.c
cc -DBSD -O -c -o clip.o clip.c
cc -DBSD -O -c -o plocate.o plocate.c
cc -DBSD -O -c -o eputs.o eputs.c
cc -DBSD -O -c -o wputs.o wputs.c
cc -DBSD -O -c -o quit.o quit.c
cc -DBSD -O -c -o lookup.o lookup.c
cc -DBSD -O -c -o bmalloc.o bmalloc.c
cc -DBSD -O -c -o loadvars.o loadvars.c
cc -DBSD -O -c -o tcos.o tcos.c
cc -DBSD -O -c -o fputword.o fputword.c
cc -DBSD -O -c -o chanvalue.o chanvalue.c
cc -DBSD -O -c -o dircode.o dircode.c
cc -DBSD -O -c -o paths.o paths.c
cc -DBSD -O -c -o byteswap.o byteswap.c
cc -DBSD -O -c -o ealloc.o ealloc.c
cc -DBSD -O -c -o fdate.o fdate.c
cc -DBSD -O -c -o portio.o portio.c
cc -DBSD -O -c -o myhostname.o myhostname.c
cc -DBSD -O -c -o erf.o erf.c
cc -DBSD -O -c -o strcmp.o strcmp.c
strcmp.c: In function ‘strcmp’:
strcmp.c:13:17: warning: argument ‘s1’ doesn’t match built-in prototype
register char *s1, *s2;
strcmp.c:13:22: warning: argument ‘s2’ doesn’t match built-in prototype
rm -f librtrad.a
ar rc librtrad.a cone.o face.o free_os.o instance.o readobj.o readoct.o
otypes.o objset.o octree.o readfargs.o modobject.o getlibpath.o
addobjnotify.o zeroes.o mesh.o readmesh.o tmesh.o sceneio.o color.o
header.o image.o lamps.o resolu.o rexpr.o spec_rgb.o colrops.o font.o
tonemap.o tmapcolrs.o tmapluv.o tmaptiff.o tmap16bit.o bmpfile.o
falsecolor.o ezxml.o ccolor.o ccyrgb.o bsdf.o bsdf_m.o bsdf_t.o loadbsdf.o
disk2square.o hilbert.o fgetline.o fropen.o linregr.o xf.o mat4.o invmat4.o
fvect.o urand.o urind.o calexpr.o caldefn.o calfunc.o calprnt.o biggerlib.o
multisamp.o unix_process.o process.o gethomedir.o getpath.o error.o
savestr.o savqstr.o badarg.o fgetword.o words.o expandarg.o wordfile.o
fgetval.o clip.o plocate.o eputs.o wputs.o quit.o lookup.o bmalloc.o
loadvars.o tcos.o fputword.o chanvalue.o dircode.o paths.o byteswap.o
ealloc.o fdate.o portio.o myhostname.o erf.o strcmp.o
ranlib librtrad.a
cc -DBSD -O -c -o mgf_parser.o mgf_parser.c
cc -DBSD -O -c -o mgf_object.o mgf_object.c
cc -DBSD -O -c -o mgf_xf.o mgf_xf.c
cc -DBSD -O -c -o mgf_context.o mgf_context.c
rm -f libmgf.a
ar rc libmgf.a mgf_parser.o mgf_object.o mgf_xf.o mgf_context.o
ranlib libmgf.a
/usr/bin/ld: badarg.o: Die Umlagerung von
badarg.o: error adding symbols: Ungültiger Wert -- unvalid data
collect2: error: ld returned 1 exit status
install.sh: Zeile 19: javac: Befehl nicht gefunden --- command not found
install.sh: Zeile 21: javah: Befehl nicht gefunden --- command not found
In file included from libBSDF.cpp:13:0:
libBSDF.h:2:17: fatal error: jni.h: Datei oder Verzeichnis nicht gefunden
-- not found
#include <jni.h>
compilation terminated.
g++: error: libBSDF.o: Datei oder Verzeichnis nicht gefunden -- not found
g++: error: libBSDF.so: Datei oder Verzeichnis nicht gefunden --- not found
g++: fatal error: no input files
cp: der Aufruf von stat für »BSDFViewer/libBSDF.so“ ist nicht möglich:
