Illums Causing Shadows
Dear Group
I am attempting to use illums in conjunction with translucent light fixtures in order to produce smoother renderings. One problem that I am having is that the illums themselves are causing shadows (see here)
For the wall fixture, you can see the shadow of the spherical illum. I am using a void material for the illum so it's invisible to the eye but obviously not invisible to shadow rays. Is there any work around for this?
Thanks
Marcus
Hi Marcus,
I attempt to explain why illum's cast shadows on page 573 of "Rendering with Radiance" (Figure 13.5). The best workaround in your case is to use a combination of direct subsampling (-ds) and direct jitter (-dj) to make the shadows less noticeable. In fact, they should be there, but they shouldn't be so sharp. Turning on PENUMBRAS in rad will accomplish the same thing.
Date: July 30, 2006 11:28:25 AM EDT
Dear Group
http://i35.photobucket.com/albums/d178/marcdevon/room7a_day_Camera07_day_pcyl_tr3.jpg
Thanks
Marcus
