ies2rad calculation
I try to understand how the ies2rad programm works, but I don't get it. The calculation of the three color channels in the description of material light is unclear.
the lamp color (fluorescent ) is .373 .385 .85
http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/cv/lamp.tab?revision=2.3&view=markup
lamp radiance for every channel = lumens/area/(WHTEFFICACY*PI) * lampcolor
area = 4*PI*r^2
WHTEFFICACY = 179
http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/cv/lampcolor.c?revision=2.10&view=markup
This value 1.27324e+06 from my example is the inverse projected area of the sphere (1/(PI*r^2))
But where are this 0.907945 0.863233 0.476189 values from? This calculation (lumens/area/(WHTEFFICACY*PI) * lampcolor) doesn't match.
This is my example:
ies2rad -dm -t fluorescent Test.ies
IES-file
IESNA91
[MANUFAC]
[LUMCAT] 2010_02
[LUMINAIRE]
[LAMP] Testlamp 1.000 lm 100W lamp*ballast factor = 1
TILT=NONE
1 1000 1 131 360 1 2 0 0 0
1 1 100 ....
Output Data
void brightdata Test_br
5 corr Test.dat source.cal src_phi src_theta
1 1.27324e+06
Test_br light Test_light
3 0.907945 0.863233 0.476189
Test_light sphere Test.s
4 0 0 0 0.0005
Rob
Hi Rob,
The color values in the lamp.tab file are in CIE x & y plus depreciation factor (Y). You can't just multiply this as if it is RGB. You would have to convert to Radiance RGB first using src/cal/cal/xyz_rgb.cal like so:
rcalc -f xyz_rgb.cal -e 'myX=myx/myy*myY;myZ=(1-myx-myy)/myy*myY' -e 'myx=$1;myy=$2;myY=$3' \
  -e '$1=R(myX,myY,myZ);$2=G(myX,myY,myZ);$3=B(myX,myY,myZ)'
You would then input the xyY values from the lamp.tab file on stdin. When I do this for your example, I get:
0.907836401 0.863244138 0.476356636
As you can see, these are exactly the RGB values that appear in the file.
Date: July 25, 2012 4:50:09 PM PDT
area = 4*PI*r^2
WHTEFFICACY = 179
This is my example:
IES-file
IESNA91
[MANUFAC]
[LUMCAT] 2010_02
[LUMINAIRE]
TILT=NONE
1 1 100 ....
Output Data
1 1.27324e+06
4 0 0 0 0.0005
Rob
