IES file manipulation
Hi everyone,
I have a situation where I'm using ies2rad to bring files into
radiance. Only I want to attach the photometric info to illum surfaces
surrounding my detailed fixture geometry rather than to the default
geometry... (pretty typical I think) However in order to do so, I have
to add rectangles in order to "seal" my fixture. I am concerned that
the addition of these rectangles will affect the magnitude of the
photometric information.
I guess one way to not even deal with boxing the luminaire with illums
is to attach a negative value to the lamp's glow material. Then rays
won't "sneak out". Of course the lamps won't add internal illumination
in that case.
Any thoughts would be appreciated. I will try and run some tests when
I get a chance.
Thanks.
Mark
Hi Mark,
Did you try the -i option to ies2rad?
Date: June 24, 2004 12:08:51 AM CEST
Hi everyone,
I have a situation where I'm using ies2rad to bring files into radiance. Only I want to attach the photometric info to illum surfaces surrounding my detailed fixture geometry rather than to the default geometry... (pretty typical I think) However in order to do so, I have to add rectangles in order to "seal" my fixture. I am concerned that the addition of these rectangles will affect the magnitude of the photometric information.
I guess one way to not even deal with boxing the luminaire with illums is to attach a negative value to the lamp's glow material. Then rays won't "sneak out". Of course the lamps won't add internal illumination in that case.
Any thoughts would be appreciated. I will try and run some tests when I get a chance.
Thanks.
Mark
Greg, in this case I'm looking at a 20' linear fluorescent
Indirect/Direct pendant. The IES file is for a 4' section and I would
array it 5 times. A sphere with 2' diameter would probably not work if
the suspension length were less than 2' since this is a partially
indirect pendant.. Also, not sure if having the pendant poking through
the illum sphere would work.
I thought of a different way of handling this. Since the ies2rad
program creates the top and bottom rectangles in this case, why not just
use an illum material with a void modifier to create the edges of the
box?
Thanks for the response. It would certainly be faster to use the -i
option.
Mark
Hi Mark,
From: "Mark de la Fuente" <MdelaFuente at wmtao.com>
Hi everyone,
illums
when
I get a chance.
Thanks.
Mark
Mark de la Fuente wrote:
Greg, in this case I'm looking at a 20' linear fluorescent Indirect/Direct pendant. The IES file is for a 4' section and I would array it 5 times. A sphere with 2' diameter would probably not work if the suspension length were less than 2' since this is a partially indirect pendant.. Also, not sure if having the pendant poking through the illum sphere would work.
I thought of a different way of handling this. Since the ies2rad program creates the top and bottom rectangles in this case, why not just use an illum material with a void modifier to create the edges of the box?
Hiya Mark,
Do you have the Rendering with Radiance book? there's a detailed example of using lboxcorr to create a rectangular shaped illum container for your IES distro. I think that's what you need. (?)
      Rob Guglielmetti
e. [email protected]
w. www.rumblestrip.org
Hi Mark,
That should work -- set the three real illum arguments to zero, though, so it won't try to contribute to the output.
Date: June 24, 2004 2:23:37 PM GMT+01:00
Thanks for the response. It would certainly be faster to use the -i option.
Mark
> Hi Mark,
> -Greg
> Hi everyone,
  > concerned that the addition of these rectangles will affect the
  > magnitude of the photometric information.
> I get a chance.
> Thanks.
> Mark
