gloss specifications to roughness/specularity
Hi All,
I am curious if there is a way to estimate material roughness/specularity based on gloss specifications. PPG provides a gloss range for its factory applied metal coatings (such as DURANAR). The way they indicate this is as a range at a given measurement angle, for example:
    25% to 35% at 60 degrees
This is according to the ASTM-D523 - Specular Gloss.
Is there some way to make this meaningful as a part of a radiance material specification?
# Jack de Valpine
Hi Jack,
I know of no way to take standard gloss measurements and convert them into something that is physically meaningful, since they combine specularity with roughness to obtain a single value at a specific angle.
Date: February 6, 2006 8:49:29 AM PST
Hi All,
Well I was pretty sure it was wishful thinking. I guess I had been hoping that with some understanding of the gloss appearance metric there might be a way back into at least some meaningful ballpark for roughness and specularity.
Ok, well on a related note, other than a full BRTD what would be the best way to simulate a so-called metalic paint, that is a paint that includes metal flakes...? Is this still best qualified as a plastic or should it in fact be a metal?
Gregory J. Ward wrote:
Hi Jack,
Hi All,
# Jack de Valpine
Jack-
There is a paper in the SIGGRAPH 2000 proceedings called "Towards a
Psychophisically-Based Light Reflection Model for Image Synthesis" by
Pellacini, Ferwerda, and Greenberg that looks at using visually
evaluated measurements to formulate a model for gloss.
They relate their visually measured parameters to the phyically based
parameters used in Radiance. I'm not sure how it relates to other gloss
parameters or how it would actually work if you tried to use it (I
haven't), but it might be worth a look.
Let me know if you can't get hold of the paper...
-Matt
[mailto:[email protected]] On Behalf Of Jack
de Valpine
Sent: Tuesday, February 07, 2006 11:24 AM
Subject: Re: [Radiance-general] gloss specifications to
and specularity.
Hi Jack,
angle.
Hi All,
angle, for example:
# Jack de Valpine
Gloss measurement is described in
http://www.farbmessung.com/html/glanzmessung.html
See also
http://www.farbmessung.com/assets/applets/WhitenessFormulas.pdf
there are some German glossmeters available, especially for car lacquers.
Martin
Sent: Tue 2/7/2006 11:39 AM
Subject: RE: [Radiance-general] gloss specifications to roughness/specularity
Jack-
-Matt
de Valpine
and specularity.
Hi Jack,
angle.
Hi All,
angle, for example:
# Jack de Valpine
Hi Matt,
Thanks for the reference. I was able to get a copy from the graphics.cornell.edu website.
I will take a look and see what I can make of it.
Matt Franks wrote:
Jack-
-Matt
de Valpine
and specularity.
Hi Jack,
angle.
Hi All,
# Jack de Valpine
# Jack de Valpine
Hi Jack,
I don't want to discourage you from reading this paper, because it's really nice, but I don't think it will help in getting meaningful values from gloss measurements. I almost mentioned it myself in my reply, but was too rushed to go look up the reference.
As for material type, you are better off using "metal" if the metallic paint has a strong color to it, as they usually do. If you want to see the clear coat as well, you can try a mixfunc between metal and plastic.
Date: February 7, 2006 8:58:52 AM PST
Hi Matt,
