Glare Index script
command (115 Bytes)
Desk1.rad (1.7 KB)
Desk2.rad (1.71 KB)
finalmultiplesim1.csh (527 Bytes)
Mainblinds.rad (23.7 KB)
mainsamples.inp (84 Bytes)
newglares.csh (265 Bytes)
outside1.rad (168 Bytes)
sky.rad (353 Bytes)
window.rad (141 Bytes)
simulation.oct (15.9 KB)
room.rad (1.94 KB)
---------- Forwarded message ----------
Date: Tue, Dec 2, 2008 at 2:52 PM
Subject: glare Index script
To: deepak gv [email protected]
Hello Everyone,
I am involved in the simulations of interior Venetian blinds in a 10’ wide, 18’ long and 10’ high
office room with one 6 ’ by 6 ’ window placed on the south oriented wall. The window sill height is 3’.
Below are the illuminance values that i obtained for the four reference(sensor) points at 1, 2 ,3 and 4 meters from the window.
For open blinds
January/01/11
5916.72709
2568.53375
1531.22413
909.419329
For closed blinds (90 degrees)
January/01/13
1082.86743
292.161874
86.7607539
63.5116316
For 45 degrees
January/01/08
1504.07099
1149.59007
1005.63413
673.372198
June/21/10
1136.58734
352.061108
83.6323623
37.3588736
From above we can observe that the illuminance value is 1000 lux + for the sensor point closest to the window, when the blinds are closed. Are these realistic values…?
There seems to be problem with glare Index. When the blinds are totally open(0 degrees) the glare index was observed to be
zero. As the blinds were closed, the Glare Index seems to Increasing. the glare index is highest for closed blinds 22. For
45 degrees the glare Index is around 14 for 45 degrees. These results seem to be strange.
I am attaching all the files along with the script for Illuminance calculations and glare Index calculations. newglares.csh is the file name for the glare script and finalmultiplesim1.csh is the shell script used for illuminance calculations.
I just want to make sure that the scripts used are correct … ?
Thank you
deepak gv
