Glare analysis of BSDF representation of light redirecting glass
Dear group,
I have a BSDF description of a light redirecting glass generated with the following command:
genBSDF -n 8 -c 20000 -r -ab 6 -ad 1 +f +b -g- millimeter -dim 12.49 12.51 12.47449 12.52551 -3.158 0
We are using this file to understand the effective light distribution of a particular product as well as calculating DGP. We are wondering if the number of samples (20000) used per each of the 145 klems directions would be sufficient to give an accurate representation of glare when looking at the scene description from inside the space? I've looked for published studies of comparative glare analysis using DGP and BSDF files but have come up short.
Thanks as always,
Chris
Christian Humann ~ Associate
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
On Jan 7, 2013, at 3:38 PM, Jacob Dunn wrote:
Radiance Users -
The University of Idaho Integrated Design Lab will be offering a week-long training on EnergyPlus and Radiance at the end of February of this year. See below for details and email [email protected] with inquiries:
February 25 – Energy Plus + Radiance Workshop: Modeling Energy Efficient Buildings
· Full 5-day workshop, check out the flyer here: http://www.idlboise.com/pdf/uiidl_eplus_radiance_training.pdf
· Learn the technical skills required to perform whole building energy and daylight simulation, using both EnergyPlus and Radiance, and understand their application within the Integrated Design Process.
· Learn how to use OpenStudio as a graphic user interface throughout both energy and daylight simulation
· 3 days of EnergyPlus training followed by 2 days of Radiance Training
· The workshop is designed for beginners and intermediate users of both programs
· For more information on the workshop’s syllabus and price, check out our website (http://idlboise.com/energyplus-radiance-workshop-2013)
When: February 25 – March 1, 8:00am to 5:00pm (MST).
Where: Integrated Design Lab, 306 S. 6th St in downtown Boise.
Cost: 500$-1000$ per person
Jacob Dunn - LEED AP
Architectural Simulation Specialist
p_208.401.0645
a_306 S 6th Street, Boise ID 83702
"Building services today are essentially mechanical compensations for the fact that buildings are bad for what they are designed for--human life" - Bjarke Ingels
Hi Chris,
Changing the -c setting in genBSDF may result in a more accurate BSDF estimate, but it will not increase the resolution of the recorded distribution, which is defined by the 145x145 Klems basis. Near normal incidence, the resolution is about 5 degrees, but increases to 15 or 20 degrees towards grazing angles.
To obtain a higher-resolution BSDF, you will need to switch to the tensor tree representation, which means using the -t4 option, probably '-t4 5' or '-t4 6' in your case. The '-t4 5' setting will yield a BSDF with 1024 incoming and 1024 outgoing directions, which corresponds roughly to 2-degree resolution near normal incidence. The higher setting of '-t4 6' gives you about twice the resolution, or 1-degree accuracy. However, it does take about 4 times as long to calculate, and any tensor tree BSDF will take much longer to compute with genBSDF than the Klems basis. Final rendering times should be similar, however.
Hope this helps!
Date: January 14, 2013 11:26:16 AM PST
Dear group,
Thanks as always,
Chris
Thank you for the response. Do you think the BSDF estimate used would give a fair approximation of glare were it to be an issue?
Cheers!
Chris
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
On Jan 14, 2013, at 11:41 AM, Greg Ward wrote:
Hi Chris,
Hope this helps!
Dear group,
Thanks as always,
Chris
