Hi Lars,
lamp.tab provides information to adjust the lamp chromaticity and apply a lamp lumen depreciation factor based on the source type. Up until now, I always thought using -t white for all sources in the scene was safer (OK, easier) because I like to roll in my lamp lumen depreciation factor with all the other things that go into a total light loss factor (LLF). I consider lamp lumen depreciation, luminaire dirt depreciation and room surface dirt depreciation, maintenance factor, and the product of all those is the LLF, which I apply all at once with the -m option of ies2rad. This was my main rationale for using -t white for all sources, but also the distinct coloration of the different sources was a problem. I forgot that you could white balance the image after the fact with pfilt, though, which leads me to my next rabbit hole:
Given that one can do a final white balancing after the fact, it does seem that we should be striving for maximum accuracy with our electric light source descriptions and specifying the lamp type/color. Just playing with the lampcolor script, I get some different luminances by changing the lamp type. I used white, incandescent, and fluorescent, and spread 200 lumens over a 1 meter polygon, and ended up with 63.7, 60.5, and 54.1 cd/m^2 respectively. Since lampcolor uses the same lamp.tab data file as ies2rad does, we can expect similar variation in light sources created using ies2rad and using different lamp types. Seems like a potential for error to me, but then again obtaining accurate CIExy data and lumen maintenance values for all the new lamps coming out seems a bit daunting too. Is this splitting hairs? I'm curious what others in the community are doing in this regard.
Robert Guglielmetti IES, LEED AP
Building Energy Efficiency Engineer
1617 Cole Blvd, MS-5202
Golden, CO 80401
303.275.4319
Reply-To: Radiance general discussion <[email protected]>
Date: Thu, 8 Oct 2009 05:52:00 -0600
Subject: Re: [Radiance-general] getting irradiance from source defined in photometric units
Jack de Valpine wrote:
No problem! I just wanted to make sure that I had not missed some
critical change somewhere along the way....
I hope not
Still, I am not really sure whether I am doing right...
Does anyone know whether the lamp,tab-lookup done by ies2rad also
accounts for the luminous efficacy of a source? This would be required
to get correct radiance values for rgb from the candela-distribution of
a source. I would e.g. assume an efficacy of 100lm/W for my source, and
if ies2rad would use 179 instead, the radiance values in my simulation
would be by far too low...
