gensky
I have a question on gensky. It is stated in the manual that "If the
time is preceded by a plus sign ('+'), then it is interpreted as local
solar time instead." However, I use the following command:
gensky 3 21 +10.00EST -a 40.77 -o 73.967
The program echoes:
gensky: bad time format: +10.00EST
I look into gensky.c and find out that
if ( (tsolar = *cp == '+') ) cp++;
if (tsolar || !isalpha(*cp)) {
    fprintf(stderr, "%s: bad time format: %s\n", progname, hs);
    exit(1);
If tsolar is 1, then the program will exit. Does it mean that the
local solar time is not supported? Thanks.
Yu Sheng
I think you need to drop the EST
Timezones won't apply to local solar time
gensky 3 21 +10.00 -a 40.77 -o 73.967
Works for me
Rob F
[mailto:[email protected]] On Behalf Of Sheng
Yu
Sent: Wednesday, September 12, 2007 1:51 PM
Subject: [Radiance-general] gensky
gensky 3 21 +10.00EST -a 40.77 -o 73.967 The program echoes:
hs);
    exit(1);
If tsolar is 1, then the program will exit. Does it mean that the local
Yu Sheng
Hello all:
I have some questions relating to gensky command.
(1) The book of "Rendering with radiance" says luminous efficacy is set to
179 for all CIE sky models. Is that true for current version?
(2) If I know Solar direct radiation and diffuse radiation, I hope to use
Perez's (source: Modeling daylight availability and irradiance components
from direct and global irradiance, 1990 solar energy) models (that is,
interpolate two CIE sky model according to radiation), is that possible to
generate a new sky luminance distribution model by interpolation of two
standard CIE model in Radiance in order to calculate the interior
illuminance more accurately?
Thank you,.
Jia
Hi Jia,
(1) The book of "Rendering with radiance" says luminous efficacy is set to 179 for all CIE sky models. Is that true for current version?
The 179 lm/watt is the standard luminous efficacy conversion for Radiance, and yes it's still the same for the current version.
(2) If I know Solar direct radiation and diffuse radiation, I hope to use Perez's (source: Modeling daylight availability and irradiance components from direct and global irradiance, 1990 solar energy) models (that is, interpolate two CIE sky model according to radiation), is that possible to generate a new sky luminance distribution model by interpolation of two standard CIE model in Radiance in order to calculate the interior illuminance more accurately?
If you know direct and diffuse radiation, you can use gendaylit (recently added to the default Radiance distro) to generate a Perez sky model directly. Check the manpage for gendaylit. I have been using it lately for some studies based on TMY weather file info and it works well!
On Mar 25, 2010, at 7:20 PM, Jia Hu wrote:
Thank you very much, Rob.
Do you mean I should download the latest version to use that? My OP is
Ubuntu and I am not sure whether the latest one is compatible with this OP.
Jia
On Fri, Mar 26, 2010 at 12:46 AM, Rob Guglielmetti <[email protected]>wrote:
Hi Jia,
Hi Rob:
I saw it was developed in 1994 from manual page. My version should contain
that. Thanks,
Jia
Hi Jia,
Hi Jia,
gendaylit was only included in the source distribution for the last couple months (maybe even less than that, the days are blurring together lately). Not sure what you mean by "it" was developed in 1994. Are you using pre-compiled binaries, or some kind of rpm distribution? If so, I doubt you have gendaylit installed, as this was included in the Radiance source distribution only recently. Gendaylit has been around a while, but prior to the new Radiance release, you had to go get it and compile it yourself. If you are compiling from source, then you could grab the latest official release (announced very recently) and compile, and you'd have it.
At any rate, it's worth seeking it out one way or another because you can use it for precisely what you're talking about.
On Mar 25, 2010, at 10:56 PM, Jia Hu wrote:
Hi Rob:
I saw it was developed in 1994 from manual page. My version should contain that. Thanks,
Jia
On Fri, Mar 26, 2010 at 12:46 AM, Rob Guglielmetti <[email protected]> wrote:
Hi Jia,
Hi Rob:
You are right.The lastest version notes it includes the Gendaylit
finally. I can not install Radiance through Makeall because there is an
error indicating that some directory can not be copied (because of existing
file). I followed the instruction at
http://www.radiance-online.org/pipermail/radiance-general/2007-August/004398.html
to install new Radiance version download from
http://radsite.lbl.gov/radiance/framed.html. Is that right?
Jia
On Fri, Mar 26, 2010 at 1:05 AM, Rob Guglielmetti <[email protected]>wrote:
Hi Jia,
Hi Rob:
that. Thanks,
Jia
Hi Jia,
Could you be more specific on the error you're getting? Sounds like it's probably a permissions error, but I'm not sure. Are you running the makeall script as root (using the sudo command)?
On Mar 26, 2010, at 3:22 PM, Jia Hu wrote:
Hi Rob:
You are right.The lastest version notes it includes the Gendaylit finally. I can not install Radiance through Makeall because there is an error indicating that some directory can not be copied (because of existing file). I followed the instruction at http://www.radiance-online.org/pipermail/radiance-general/2007-August/004398.html to install new Radiance version download from http://radsite.lbl.gov/radiance/framed.html. Is that right?
Jia
On Fri, Mar 26, 2010 at 1:05 AM, Rob Guglielmetti <[email protected]> wrote:
Hi Jia,
Hi Rob:
Jia
Hi Jia,
Hi, I forgot to use sudo command. it is a permission error. It is installed
now by using: sudo ./makeall install. In the end, the Gnome terminal
indicates there are some errors. But it seems that it is running without
problems.
Thank you.
Hi Rob:
Jia
Hi Jia,
Hi Rob:
that. Thanks,
Jia
Hi Jia,
If you did not download and install the "rad3R9supp" package you are
probably missing libtiff and the makeall script complains about errors
related to that. ra_tiff has not been created and other converters
have not been installed to the ../bin directory. Those were the
problems I remember; it's worth checking.
problems.
Thank you, I will install it again to see if the errors still exist.
installed
> problems.
Hi, I am new for ubuntu and confused with different kinds of files for
Radiance. I used the following command to install Radiance, is that right?
navigate to the directory"rad3R9pp"
run: ./makeall install (nearly all options in this process are yes
(default). it says there are some error at this step)
Then, ./makeall library
navigate to the directory "ray" (unpack the package downloaded from
http://radsite.lbl.gov/radiance/framed.html)
run: ./makeall install (still there are some error)
then, ./makeall library
then, ./makeall clean
Anyone know what is the difference between main distribution (from
http://radsite.lbl.gov/radiance/framed.html) and "rad3R9all" (from
http://www.radiance-online.org/)?
Thank you,
Jia
On Sat, Mar 27, 2010 at 1:31 PM, Thomas Bleicher <[email protected] > > wrote:
installed
> problems.
Jia.
The current official release is 4.0 from radsite.lbl.gov. This package
contains all files for the core tools. It does not contain source
files for libtiff which is only required if you want to compile the
tool ra_tiff which allows conversion from and to TIF images. However,
there is a small bug in the makeall script: if it can't compile
ra_tiff it will not install any of the other converters. It will
report errors instead.
To avoid these errors you need to download an additional package,
rad3R9supp.tar.gz (or any other archive). This file contains the
libtiff sources and a lot of other material (example scenes, images,
mesh objects). It's a pretty big file and because it's not essential
for the core Radiance tools it was spit out in a separate package.
Don't worry about the version number. The "supp" file should work with
the new 4.0 Radiance from radsite.lbl.gov. All other files on
radiance-online.org need to be updated. The official 4.0 release of
Radiance is only a couple of days old so there was no time yet to
update that site, too.
The best way to compile is:
1) Download and unpack rad4R0all.tar.gz. This will create a "ray" directory
2) Download and unpack rad3R9supp.tar.gz. Unpack this in the same
directory. This will extract its files in the same "ray" directory
that was created before.
3) cd into "ray"
4) compile with "sudo ./makeall install | tee makeall.output"
This will create a file called "makeall.output" with all the stuff
that's scrolling by on your terminal during the process. You can check
it for errors later. If you see the message about errors again send
this file and we can see what was going wrong.
A small correction to this. The "rad4R0all.tar.gz" download does contain the TIFF library and all the example files and directories.
Date: March 27, 2010 1:13:54 PM PDT
Jia.
3) cd into "ray"
Hello Thomas:
Thank you very much for your help.
I downloaded and installed it following your instruction. The last line in
makeall.output says "there are some error".
I attach this file in the email and wish you could help me check whether it
is serious or not.
Jia
makeall.output (62.7 KB)
On Sat, Mar 27, 2010 at 4:13 PM, Thomas Bleicher <[email protected]>wrote:
Jia.
3) cd into "ray"
Hi Jia,
Your compile results are strange. It seems like all the binary files are being compiled, but the final copy to your executable destination is usually skipped. This may be due to a false error being reported by the linker or some other configuration problem. I would try rerunning "makeall install" a second time to see if that doesn't fix it. It shouldn't be necessary, but something is wrong with your build system.
Date: March 27, 2010 1:53:24 PM PDT
Hello Thomas:
I downloaded and installed it following your instruction. The last line in makeall.output says "there are some error".
I attach this file in the email and wish you could help me check whether it is serious or not.
Jia
Hi Greg:
Does these errors affect running Radiance? or do you know if there is any
possible way to check problems of my build system? I once installed Radiance
3.9 using an approach from
Thank you.
Jia
On Sat, Mar 27, 2010 at 5:09 PM, Greg Ward <[email protected]> wrote:
Hi Jia,
Hello Thomas:
Jia
Upon completion, your executable directory should contain the following compiled programs and scripts:
3ds2mgf
arch2rad
bgraph
cnt
compamb
cv
dayfact
dctimestep
debugcal
dev
dgraph
ev
falsecolor
fieldcomb
findglare
gcomp
genambpos
genblinds
genbox
genclock
gendaylit
genklemsamp
genprism
genrev
genrhgrid
gensky
genskyvec
gensurf
genworm
getbbox
getinfo
glare
glarendx
glaze
glrad
histo
icalc
ies2rad
igraph
lampcolor
lookamb
macbethcal
meta2bmp
meta2tga
mgf2inv
mgf2meta
mgf2rad
mgfilt
mkillum
mksource
neaten
nff2rad
normpat
normtiff
obj2mesh
obj2rad
objline
objpict
objview
oconv
optics2rad
pbilat
pcomb
pcompos
pcond
pcwarp
pdelta
pdfblur
pexpand
pextrem
pfilt
pflip
pgblur
phisto
pinterp
plot4
plotin
pmblur
pmdblur
protate
psign
psmeta
psort
pvalue
ra_bmp
ra_gif
ra_hexbit
ra_pfm
ra_pict
ra_ppm
ra_ps
ra_rgbe
ra_t16
ra_t8
ra_tiff
ra_xyze
rad
rad2mgf
raddepend
ran2tiff
ranimate
ranimove
rcalc
replmarks
rhcopy
rhinfo
rholo
rhoptimize
rhpict
rlam
rlux
rmake
rpict
rpiece
rsensor
rtcontrib
rtrace
rview
rvu
tabfunc
tmesh2rad
total
trad
ttyimage
vinfo
vwrays
vwright
x11meta
xform
xglaresrc
ximage
xshowtrace
xyzimage
If anything is missing, then the build was only partially successful.
Date: March 27, 2010 2:31:38 PM PDT
Hi Greg:
Does these errors affect running Radiance? or do you know if there is any possible way to check problems of my build system? I once installed Radiance 3.9 using an approach from http://www.radiance-online.org/pipermail/radiance-general/2007-August/004398.html.
Thank you.
Jia
On Sat, Mar 27, 2010 at 5:09 PM, Greg Ward <[email protected]> > wrote:
Hi Jia,
Hello Thomas:
Jia
Hi, Greg:
Thank you very much. I will check it to see which is missing.
Jia
3ds2mgf
arch2rad
bgraph
cnt
compamb
cv
dayfact
dctimestep
debugcal
dev
dgraph
ev
falsecolor
fieldcomb
findglare
gcomp
genambpos
genblinds
genbox
genclock
gendaylit
genklemsamp
genprism
genrev
genrhgrid
gensky
genskyvec
gensurf
genworm
getbbox
getinfo
glare
glarendx
glaze
glrad
histo
icalc
ies2rad
igraph
lampcolor
lookamb
macbethcal
meta2bmp
meta2tga
mgf2inv
mgf2meta
mgf2rad
mgfilt
mkillum
mksource
neaten
nff2rad
normpat
normtiff
obj2mesh
obj2rad
objline
objpict
objview
oconv
optics2rad
pbilat
pcomb
pcompos
pcond
pcwarp
pdelta
pdfblur
pexpand
pextrem
pfilt
pflip
pgblur
phisto
pinterp
plot4
plotin
pmblur
pmdblur
protate
psign
psmeta
psort
pvalue
ra_bmp
ra_gif
ra_hexbit
ra_pfm
ra_pict
ra_ppm
ra_ps
ra_rgbe
ra_t16
ra_t8
ra_tiff
ra_xyze
rad
rad2mgf
raddepend
ran2tiff
ranimate
ranimove
rcalc
replmarks
rhcopy
rhinfo
rholo
rhoptimize
rhpict
rlam
rlux
rmake
rpict
rpiece
rsensor
rtcontrib
rtrace
rview
rvu
tabfunc
tmesh2rad
total
trad
ttyimage
vinfo
vwrays
vwright
x11meta
xform
xglaresrc
ximage
xshowtrace
xyzimage
Hi Greg:
Thank you.
Jia
On Sat, Mar 27, 2010 at 5:09 PM, Greg Ward <[email protected]> >> wrote:
Hi Jia,
Hello Thomas:
Jia
