gensky: what's the unit of the value specified for the "-b" option?
Dear Radiance experts,
May I ask what is the unit for the value specified after the "-b" option of
the "gensky" command?
According to Axel Jacob's "Radiance Tutorial" p. 24 and "Radiance Cookbook"
p.35, if we want to define an overcast sky with the horizontal illumination
level being 10,000 lx, we need to specify the zenith brightness with an
irradiance value of 22.86(W/m2) for the "-b" option in gensky command.
However, according to the gensky menu, what we need to specify for the "-b"
option is the zenith brightness as an "radiance" value of which the unit
should be watts/steradian/m2.
I assume that the term "radiance" and "irradiance" should not be used
interchangeably as they are different concepts, am I right?
So, which one is correct? Axel's tutorial or the gensky menu?
Or more specifically, for "Formula 4" in Axel Jacob's "Radiance Tutorial" p.
24 that specify the relationship between zenith brightness and horizontal
illuminance: R_zenith = (9/7)*(E_horiz/179/PI)
What are the units for "R_zenith" and "E_horiz" exactly?
If the unit for "R_zenith" is watts/steradian/m2, then it's a "radiance"
value.
But if the unit for "R_zenith" is watts/m2, then it's a "irradiance" value.
Correct me if I'm wrong.
Thanks!
Ji
Hi Ji,
Axel's tutorial is correct, but it is slightly simpler to use the gensky -B option (rather than "-b") if you are starting from the horizontal illuminance. First, apply the 179 lumens/watt conversion factor:
  10,000 lumens/m^2 * 1 watt / 179 lumens => 55.87 watts/m^2
Using this in your gensky command:
  gensky 12 4 +12:00 -a 51 -o 0 -m 0 -c -B 55.87
You should get the output below. (I'm not sure why the tutorial has "21" as the month for the first argument -- I'm assuming this is a typo.)
# gensky 12 4 +12:00 -a 51 -o 0 -m 0 -c -B 55.87
# Local solar time: 12.00
# Solar altitude and azimuth: 16.8 -0.0
# Ground ambient level: 17.8
void brightfunc skyfunc
2 skybr skybright.cal
3 2 2.29e+01 3.56e+00
The reported "Ground ambient level" is actually the diffuse horizontal illumination in disguise. If you multiply 17.8 by pi and 179, you should get what you started with as your horizontal illuminance. This is one way to check. Another method is to run rtrace with just the sky and compute the horizontal irradiance using the -I option.
I hope this clears things up.
Date: June 30, 2010 10:22:08 PM PDT
May I ask what is the unit for the value specified after the "-b" option of the "gensky" command?
According to Axel Jacob's "Radiance Tutorial" p. 24 and "Radiance Cookbook" p.35, if we want to define an overcast sky with the horizontal illumination level being 10,000 lx, we need to specify the zenith brightness with an irradiance value of 22.86(W/m2) for the "-b" option in gensky command.
However, according to the gensky menu, what we need to specify for the "-b" option is the zenith brightness as an "radiance" value of which the unit should be watts/steradian/m2.
I assume that the term "radiance" and "irradiance" should not be used interchangeably as they are different concepts, am I right?
Or more specifically, for "Formula 4" in Axel Jacob's "Radiance Tutorial" p. 24 that specify the relationship between zenith brightness and horizontal illuminance: R_zenith = (9/7)*(E_horiz/179/PI)
If the unit for "R_zenith" is watts/steradian/m2, then it's a "radiance" value.
Thanks!
Ji
Ok, got it, Greg, thank you very much!
Ji
On Fri, Jul 2, 2010 at 12:43 AM, Greg Ward <[email protected]> wrote:
Hi Ji,
command.
value.
value.
Thanks!
Ji
ZHANG Ji 张冀 (PhD) :: Research Fellow :: Centre for Sustainable Asian Cities
:: School of Design and Environment :: National University of Singapore :: 4
Architecture Drive, Singapore, 117566 :: Contact: 65-6516 5046 :: Email:
