Gensky Time format
I am using gensky to know the sunvector.
gensky 10 13 10:27CET +s -a 57.01305 -o -9.988333
does the time format used in the gensky command includes seconds also e.g i want to know the sun vector at 10:27:30 hrs ?
Best Regards,
Brajesh Lal
Hi Brajesh,
Gensky doesn't take HH:MM:SS format, but you can specify any number of digits using the alternative decimal hours. I.e., 10:27:30 translates to:
  10 + 27/60 + 30/3600 => 10.458333
% gensky 10 13 10.458333 +s -a 57.01305 -o -9.988333
Be aware that gensky doesn't have the more sophisticated orbital corrections, etc. that would permit it to predict the solar position with this kind of accuracy.
Date: April 15, 2010 9:31:23 AM PDT
Best Regards,
Brajesh Lal
Thanks Greg,
one more question
is mentioning of CET timezone not required or i use meridian info ? I have previously generated required data using CET
% gensky 10 13 10.458333CET +s -a 57.01305 -o -9.988333 is it correct?
Best Regards, Brajesh Lal
Sent: Thu, April 15, 2010 6:40:41 PM
Subject: Re: [Radiance-general] Gensky Time format
Hi Brajesh,
Best Regards,
Brajesh Lal
Brajesh,
If you want more accurate sun vectors, I would suggest trying out the libnova package:
http://libnova.sourceforge.net/
It's pretty easy to build, and comes with some example code that will help you build a lightweight sun vector program quickly.
I use libnova to compute sun, moon, and star placements for a Radiance tool that I made called "genutahsky" (which works very much like gensky, but creates a more thorough, colorful, but less-flexible sky description). More on that tool here:
http://markjstock.org/radiance/
Mark
On Thu, 15 Apr 2010, Brajesh Lal wrote:
Best Regards,
Brajesh Lal
Good stuff.
On Thu, Apr 15, 2010 at 1:35 PM, Mark Stock <[email protected]> wrote:
Brajesh,
libnova package:
on that tool here:
Mark
Best Regards,
Brajesh Lal
