gensky sky type
I am using gendaylit with input from weather file. During sunrise and
sunset, gendaylit shows "ERROR: Model parameters out of range". so I plan
to use gensky to generate the sky model (-B b -R r), where b and r are
calculated by "illumiance/179". However, I found the illuminance value at
5 pm (calculated using gensky with default sky type) jumps a lot from illum
at 4 pm (calculated using gendaylit). I changed the sky type to +i, which
decreases values. My question is that how I should choose the sky type for
gensky to avoid big change from gendaylit?
Thanks
JH
Dear JH,
at the moment, every feedback for errors of gendaylit is especially
appreciated.
We are currently adding some new features to gendaylit especially to avoid
errors for surise/sunset. All new features of gendaylit will be presented
also during the radiance workshop and we hope to have the new release 2.2
ready before the RADIANCE workshop takes place.
However, the error you have mentioned might be a different one. We are
just working on some bugs of the -L option. Are you using this option?
Please specify the precise command that leads to the error, including the
precise error message and your version of gendaylit (just type gendaylit
in your terminal).
Wendelin
___________________________________
Mag.rer.nat. Wendelin Sprenger
Division Thermal Systems and Buildings
Fraunhofer Institute for Solar Energy Systems ISE
Phone: +49 (0) 7 61/ 45 88-57 45
-------- Original Message --------
Subject:
[Radiance-general] gensky sky type
Resent-To:
Date:
Wed, 31 Jul 2013 00:20:01 -0400
Jia Hu <[email protected]>
Reply-To:
Radiance general discussion <[email protected]>
To:
plan to use gensky to generate the sky model (-B b -R r), where b and r
are calculated by "illumiance/179". However, I found the illuminance
value at 5 pm (calculated using gensky with default sky type) jumps a lot
from illum at 4 pm (calculated using gendaylit). I changed the sky type to
+i, which decreases values. My question is that how I should choose the
sky type for gensky to avoid big change from gendaylit?
Thanks
JH
Dear Wendelin,
I find that the weather data is -L 0 0, which causes the error message. It
is a false alarm. I may simply ignore this error message. I am using
gendaylit 2.0 downloaded from your website. Glad to know there is a new
release!
gendaylit 1 1 8 -a 25 -o 75 -m 75 -L 0 0
On Wed, Jul 31, 2013 at 9:28 AM, <[email protected]>wrote:
Dear JH,
appreciated.
precise error message and your version of gendaylit (just type gendaylit in
your terminal).
Wendelin
http://www.ise.fraunhofer.de
*Subject: *
*Resent-To: *
*[email protected]* <[email protected]>
*Date: *
Jia Hu *<[email protected]>* <[email protected]>
*Reply-To: *
Radiance general discussion *<[email protected]>*<[email protected]>
*To: *
Thanks
JH
