I’m working through Axel Jacobs' excellent 'rtcontrib' tutorial and I want to generate a Radiance picture using rtrace instead of rpict. For your information, I'm under Windows 7 with the latest Radiance binaries downloaded from the NREL Openstudio website: http://openstudio.nrel.gov/getting-started-developer/getting-started-radiance
When I try this:
vwrays −ff −vf view1.vf −x 1024 −y 1024 | rtrace ‘vwrays −d −vf view1.vf −x 1024 −y 1024‘ −ffc scene.oct > view1.hdr
I obtain this error message:
rtrace: fatal - command line error at 'vwrays'
Then I use double quotes...
vwrays −ff −vf view1.vf −x 1024 −y 1024 | rtrace "vwrays −d −vf view1.vf −x 1024 −y 1024" −ffc scene.oct > view1.hdr
...and I obtain this error message:
rtrace: fatal - command line error at 'vwrays −d −vf view1.vf −x 1024 −y 1024'
Any advice on how to solve or work around this problem would be greatly appreciated !
Thanks in advance,
François Cantin
stagiaire en architecture, M Arch, MSc Arch
[cid:coarchitecture3-reduit29.jpg]
1175, Lavigerie, bureau 400, Québec, Qc, G1V 4P1
T (418) 653 8484 #224, F (418) 653-6189
E [email protected]<http://[email protected]>
http://www.coarchitecture.com
Ce message électronique de même que tous les fichiers attachés qu'il contient sont confidentiels et destinés exclusivement à l'usage de la personne à laquelle ils sont adressés. Si vous avez reçu ce message par erreur, merci de le retourner à son émetteur. La publication, l'usage, la distribution, l'impression ou la copie non autorisée de ce message et des pièces jointes qu'il contient sont strictement interdits.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual to whom it is addressed. If you have received this email in error please send it back to the person that sent it to you. Unauthorized publication, use, dissemination, forwarding, printing or copying of this email and its associated attachments is strictly prohibited.
