Dear All,
I am trying to generate a '-5' sky vector from a weather file that contains
just:
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
site_elevation 476.0
weather_data_file_units 1
1 1 9.5 756 189
I am using the command:
g*endaymtx -h -5 0.533 -m 1 Santiago.wea > test*
but I am getting the exact same sky vector as without the '-5' option (i.e.
full sky). Any hints on this? I am trying to implement the 5 phases...
Thanks in advance,
Germán
Dear German,
you need the "-5" option for the last step of the 5-Phase calculation, i.e.
the detailed sun description. For that you need to use it together with the
"-d" option and you need to take a higher sky subdivision with -m 6.
The command should look like:
gendaymtx -5 0.533 -d -m 6 Santiago.wea
Best,
David
2017-03-15 16:29 GMT+01:00 Germán Molina Larrain <[email protected]>:
Dear All,
contains just:
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
1 1 9.5 756 189
(i.e. full sky). Any hints on this? I am trying to implement the 5 phases...
Thanks in advance,
Germán
Radiance-general mailing list
[email protected]
http://www.radiance-online.org/mailman/listinfo/radiance-general
Dipl.-Ing. Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Austria
Oh! I thought the -5 was enough, did not know i had to add also -d. Thanks
very much.
Is it possible to use other MFs rather than 6? I know the higher the
better... I am thinking on warnings for Groundhog
Best
El mié., 15 de mar. de 2017 12:56, David Geisler-Moroder < [email protected]> escribió:
Dear German,
i.e. the detailed sun description. For that you need to use it together
with the "-d" option and you need to take a higher sky subdivision with -m
6.
Best,
David
Dear All,
contains just:
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
1 1 9.5 756 189
Thanks in advance,
Germán
[email protected]
Hofwaldweg 14/20
6020 Innsbruck
Austria
[email protected]
I think it should also work if you use other (lower) MFs, but you need to
take care that with less sun positions the benefits of an accurate direct
sun calculation get lost...
2017-03-15 16:59 GMT+01:00 Germán Molina Larrain <[email protected]>:
very much.
Best
El mié., 15 de mar. de 2017 12:56, David Geisler-Moroder < > [email protected]> escribió:
Dear German,
6.
Best,
David
Dear All,
contains just:
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
1 1 9.5 756 189
Thanks in advance,
Germán
[email protected]
Hofwaldweg 14/20
6020 Innsbruck
Austria
[email protected]
[email protected]
Hofwaldweg 14/20
6020 Innsbruck
Austria
Cool! Thanks very much. I will warn that.
Best!
Thanks very much.
Best
El mié., 15 de mar. de 2017 12:56, David Geisler-Moroder < >> [email protected]> escribió:
Dear German,
6.
Best,
David
Dear All,
contains just:
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
1 1 9.5 756 189
Thanks in advance,
Germán
[email protected]
Hofwaldweg 14/20
6020 Innsbruck
Austria
[email protected]
[email protected]
Hofwaldweg 14/20
6020 Innsbruck
Austria
[email protected]
