Hi All,
This is the first time i've tried using gendaylit on my Mac with Radiance 3.9 at home and i keep getting a segmentation fault error.
I've tried recompiling several times and can't seem to get around it. Thanks for any suggestions.
For example, issuing the following command:
gendaylit 4 13 7 -a 40.3 -o 79.9 -m 75 -W 401 41
returns:
# gendaylit 4 13 7 -a 40.3 -o 79.9 -m 75 -W 401 41
Segmentation fault
Hi Galen,
Try grabbing the latest HEAD from www.radiance-online.org and compile the modified version of gendaylit included there. It doesn't seem to have this problem. I get:
% gendaylit 4 13 7 -a 40.3 -o 79.9 -m 75 -W 401 41
# Ground ambient level: 4.8
void light solar
3 2.605e+06 2.605e+06 2.605e+06
solar source sun
4 0.973844 0.003467 0.227192 0.533000
void brightfunc skyfunc
2 skybright perezlum.cal
10 1.781e+01 3.513e+00 -1.131043 -0.338979 13.047373 -3.410216 0.426223 0.973844 0.003467 0.227192
Date: February 20, 2010 9:16:04 PM PST
Hi All,
returns:
Segmentation fault
Hi Galen.
Which version of OS X are you using. I updated to Snow Leopard on a
32-bit system and since then most of the applications I compiled
myself end in a segfault. I think the new Xcode is not set up properly
for a 32-bit system or the usual (auto)config rules do not work
correctly for this configuration.
Exception: I downloaded the Radiance HEAD snapshot last weekend and it
compiled and worked fine, including gendaylit. Greg's Makefiles seem
to work just fine.
On Sun, Feb 21, 2010 at 5:16 AM, Galen Burrell <Galen.Burrell@arup.com.au> wrote:
Hi All,
returns:
Segmentation fault
