genBSDF: illegal variable name
Hi all:
I use Radiance window version and create a simple file to generate BSDF
file:
####################### file: glazingBase.rad
void glass glazingRef_0.2
3
0.218166162012 0.218166162012 0.218166162012
######################## file: bsdf.rad
void plastic blindRef_0.2
5
0.2 0.2 0.2 0 0
glazingRef_0.2 polygon glazing_1
12
2 0.0 3
0.0 0.0 3
0.0 0.0 0.0
2 0.0 0.0
!genblinds blindRef_0.2 blinds_0.2 0.5 2 3 60 60 | xform -rz -90 -rx 90
!xform -rx 90 -t 0 0 -0.6 glazingBase.rad
##################### end ########################
I run "genBSDF.pl bsdf.rad > temp.xml", and got the error here (link:
https://dl.dropbox.com/u/15562376/error.gif) . Do you know how to correct
this error?
Thank you in advance,
Jia
The problem is that genBSDF.pl is not Windows-compatible. We have it on our "to-do" list, but no promises when we'll get to it.
Date: October 12, 2012 11:50:18 AM GMT+02:00
Hi all:
I use Radiance window version and create a simple file to generate BSDF file:
3
5
0.2 0.2 0.2 0 0
12
2 0.0 3
0.0 0.0 3
0.0 0.0 0.0
2 0.0 0.0
I run "genBSDF.pl bsdf.rad > temp.xml", and got the error here (link:https://dl.dropbox.com/u/15562376/error.gif) . Do you know how to correct this error?
Jia
Thanks, Greg. I am not familiar with Perl. Could you point out some reasons
why the code is not compatible? so that I may revise some codes by myself
if there is not too much work...
Jia
> From: Jia Hu <[email protected]>
> Hi all:
file:
> 0
> 0
> 3
> 0
> 0
> 5
> 0.2 0.2 0.2 0 0
> 0
> 0
> 12
> 2 0.0 3
> 0.0 0.0 3
> 0.0 0.0 0.0
> 2 0.0 0.0
this error?
> Jia
