Well this is a funny little thing... Giulio has found something
strange!
Phil.
[mailto:[email protected]] On Behalf Of
Giulio Antonutto
Sent: 22 November 2006 11:27
Subject: RE: [Radiance-general] FW: Gensky Question
Indeed Phil is right!
oops
but be careful when you use the options -i and -s, without the sun you
need also to say -R 0.
If not the 20% ratio will not work, because the ground will include the
reflected sun component anyway...
Try to compare:
gensky 12 12 12 -i -B 56
and
gensky 12 12 12 -i -B 56 -R 0
The ground is different.... why is it?
Phil, what do you think? Can we call this a bug?
I never noticed it before because I do not model the ground with a
glow...
Ciao,
G.
Phillip Greenup
Sent: 22 November 2006 10:47
Hi Nick, Giulio,
One comment to add to Giulio's message... Just be careful of your
ground definition.
The gensky model includes a default ground reflectance of 0.2. This can
be changed using gensky's -g option. So, the normalised emittance of
Nick's groundglow material should be 1.0, not 0.1 or 0.2 as Giulio
suggested.
Cheers all,
Phil.
Giulio Antonutto
Sent: 22 November 2006 10:25
Nick,
-R -B are supposed to specify direct and diffuse contribute.
a quick and easy check is to create a -s (diffuse only) and a +s
(global) sky with the same -R -B and check illuminances at a point (0 0
0, 0 0 1) Now try without the sky dome and +s (direct only) and see...
you should get diffuse and global and direct values.
Please try it.
About the source primitive, you need it all the time.
Coefficients can be just (1 1 1) for the sky and a reduction like (0.1
0.1 0.1) or (0.2 0.2 0.2) for the ground depending to the model you are
working on.
If you use your coefficients you will be working with colour but you
need to check that the photopic average is correct.
Hope this is +s,
i.e. 'clear'
Ciao
[mailto:[email protected]] On Behalf Of Nick
Devlin
Sent: 22 November 2006 09:56
To: [email protected]
Subject: [Radiance-general] FW: Gensky Question
Hi All,
I have a GENSKY question that I cant find the answer to in the archives.
I
suspect that the answer is straightforward, but I am now challenging all
my old assumptions as I have just switched from old school desktop
radiance to
3R7P2 with photon mapping running under Ubuntu on VMware Workstation.
Daunting, but I like it!
Perhaps first I should state that I am aware from the listings that
perhaps I should be using Gendaylit rather than Gensky, but I have not
managed to compile it yet. Compiling makes me anxious. I used
Francesco's Linux binaries in the end as I couldn't get photon map to
compile properly after 3R7P2. My /bin and /lib files are not in the
standard location, but I have altered PATH & RAYPATH accordingly.
So, to the questions:
Firstly, I have some data for sky brightness from BRE Availability of
Daylight, for diffuse and direct illuminance. If for example, I have
illuminance values of 34 klux diffuse and 26 klux direct can I
explicitly set these in Gensky (assuming 179lux per watt) with
Gensky (location details, azimuth etc) +s -B 189 -R 145.25 > skyfile.rad
My concern is whether -B or -R overrides the other, or will I ultimately
result in approximately total 60klux horizontal illuminance?
Secondly, do I have to manually add the following to the bottom of
skyfile.rad. I presume that I don't need to alter any of the parameters
here for a basic sky and ground plane and that it references the skyfunc
output from the gensky command.
skyfunc glow skyglow
4
.85 1.04 1.2 0
skyglow source sky
4
0 0 1 180
skyfunc glow groundglow
4
.8 1.1 .8 0
groundglow source ground
4
0 0 -1 180
Finally, if I explicitly set -B & -R for an intermediate sky with +i
does the +i setting result in an adjustment to the -B & -R values?
Many thanks in advance
Nick Devlin.
Electronic mail messages entering and leaving Arup business systems are
scanned for acceptability of content and viruses
