Five-Phase Method: invalid results in daylight matrix
At first (quick) glance, my guess is that your window polygon is oriented backwards. Confirm the window normal faces out, toward the exterior environment and sky, by looking at the vertex order (right hand rule!).
On 2/15/16, 12:59 AM, "Alireza Hashemloo" <[email protected]<mailto:[email protected]>> wrote:
I have a question about the Example 2 in the five-phase method tutorial (http://www.radiance-online.org/learning/tutorials/fivephasetutorialfiles/Tutorial-FivePhaseMethod_v2.pdf):
OS: Windows 7 (64-bit)
Command Line Environment: Git Bash
Command:
$ genklemsamp -c 1000 -vd 0 -1 0 objects/glazing_outside_pane.rad | \
rcontrib -c 1000 -ab 2 -ad 1024 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -fa \
model_daylight_matrix.oct > daylight_matrices/daylight_matrix.dmx
Issue: the recorded values in the generated daylight_matirx.dmx are all equal to 0 (0.000000e+000)
I would appreciate if you could help me with possible causes of the invalid results.
Thank you,
Alireza
