Faulty fisheye HDR, DGP always 1.0
Hi All,
I am trying to asses visual discomfort using fisheye HDR images. We generated HDR image from a set of 360 degree LDRs and then converted to fisheye HDR ( using a custom made tools). The intension was to use these Fisheye HDRs as input to Evalglare and get DGP value. The Camera used is Ricoh Theta V 360 degree camera.
The problem I am facing is, the DGP calculated from the generated fisheye HDR with Evalglare is always 1.0. We did the calibration but I would like to have expert opinion from you people, what is going wrong with these set of images. Here is the link <https://seafile.rlp.net/f/0212995d110648d38032/?dl=1> to the pictures.
It would be great if anyone could identify the issue.
Best Regards,
Raghu
Hi Raghu,
It looks like your HDR image header is missing the necessary view information. Typically, this might be something like:
VIEW= -vta -vh 180 -vv 180
for a perspective such as yours. You should be sure that your fisheye mapping corresponds to one of the standard Radiance types.
Date: February 6, 2018 5:21:59 AM PST
Hi All,
The problem I am facing is, the DGP calculated from the generated fisheye HDR with Evalglare is always 1.0. We did the calibration but I would like to have expert opinion from you people, what is going wrong with these set of images. Here is the link to the pictures.
Best Regards,
Raghu
I added these options while passing to evalglare like below.
evalglare -vta -vh 180 -vv 180 <hdr file>, and it worked but it always gives 1.0 as DGP (even other parameters are out of bounds).
With out those options evalglare throws an error.
Apart from that
Are all the LDR’s provided, valid to combine into HDR?
I doubt if one or more of the LDR’s is the culprit (especially something to do with over or under exposure).
Best Regards,
Raghu
On Feb 6, 2018, at 5:05 PM, Greg Ward <[email protected]> wrote:
Hi Raghu,
From: raghuram kalyanam <[email protected] <mailto:[email protected]>>
Hi All,
Best Regards,
Raghu
Hi Raghu,
it is very simple: your HDR image is simply not correct...
The luminance of your blue sky is more than 400000 cd/m2 and the floor has more than 200000 cd/m2� you really have a problem in your hdr generation or calibration... maybe you have used an additional factor 179� in the image???
Of course with these high values DGP gets 1...
good luck
Jan
On 06.02.18 14:21, raghuram kalyanam wrote:
Hi All,
I am trying to asses visual discomfort �using fisheye HDR images. We generated HDR image from a set of 360 degree LDRs and then converted to fisheye HDR ( using a custom made tools). The intension was to use these Fisheye HDRs as input to Evalglare and get DGP value. The Camera used is Ricoh Theta V 360 degree camera.
The problem I am facing is, the DGP calculated from the generated fisheye HDR with Evalglare is always 1.0. We did the calibration but I would like to have expert opinion from you people, what is going wrong with these set of images. Here is the link <https://seafile.rlp.net/f/0212995d110648d38032/?dl=1>�to the pictures.
Best Regards,
Raghu
Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
LE 1 111 (Office)
Phone +41 21 69 30849
Hi Raghu,
We may need to wait to hear from Jan or someone who understands evalglare better than I do. I don't think there is a problem with your HDR image as you generated it.
Date: February 6, 2018 9:05:41 AM PST
Apart from that
Best Regards,
Raghu
Hi Raghu,
Hi All,
Best Regards,
Raghu
was it taken on mercury ? :wink:
the luminances are far off... it sums up to more than 600000 lux
Jan
On 06.02.18 18:18, Greg Ward wrote:
Hi Raghu,
We may need to wait to hear from Jan or someone who understands evalglare better than I do. �I don't think there is a problem with your HDR image as you generated it.
*From: *raghuram kalyanam <[email protected] <mailto:[email protected]>>
*Date: *February 6, 2018 9:05:41 AM PST
Apart from that
Are all the LDR�s provided, valid to combine into HDR?
I doubt if one or more of the LDR�s is the culprit (especially something to do with over or under exposure).
Best Regards,
Raghu
On Feb 6, 2018, at 5:05 PM, Greg Ward <[email protected] >>> <mailto:[email protected]>> wrote:
Hi Raghu,
It looks like your HDR image header is missing the necessary view information. �Typically, this might be something like:
for a perspective such as yours. �You should be sure that your fisheye mapping corresponds to one of the standard Radiance types.
*Date: *February 6, 2018 5:21:59 AM PST
Hi All,
Best Regards,
Raghu
EPFL ENAC IA LIPID
LE 1 111 (Office)
Ha. Jan is right -- the HDR values are way off. I should have looked at the result more closely and noticed that everything was too bright.
I can take your JPEGs and give them to Photosphere or hdrgen, combining them using a generic response function. I cannot solve for the camera response with these inputs, which likely means that the camera is playing around with the tone curve on the different exposures. This is a no-no, and indicates that the camera is probably not suitable for HDR capture. Nevertheless, hdrgen can create something usable that does not agree at all with your result.
By the way, your shortest exposure is still clipping the sun, which means that your DGP won't be accurate for this scene, even if you can get your HDR builder to work unless you can get a shorter exposure.
Date: February 6, 2018 9:24:54 AM PST
Jan
Hi Raghu,
Apart from that
Best Regards,
Raghu
Hi Raghu,
Hi All,
Best Regards,
Raghu
EPFL ENAC IA LIPID
LE 1 111 (Office)
P.S. We should move this discussion to the HDRI mailing list, since it is not a problem with evalglare or any Radiance tools.
Date: February 6, 2018 9:45:19 AM PST
Jan
Hi Raghu,
Apart from that
Best Regards,
Raghu
Hi Raghu,
Hi All,
Best Regards,
Raghu
Hi Jan,
We did the calibration and the results of spot luminance measured and calculated from HDR for the light source (calculated with custom made tool ) is very close.
I want to compare the measured Vertical eye illuminance with the one calculated with evalglare, but the results are out of bounds from evalglare, so i couldn’t even compare.
Could you suggest me anything else i should be taking care of? Any ideas.
Best Regards,
Raghu
the luminances are far off… it sums up to more than 600000 lux
Jan
Hi Raghu,
understands evalglare better than I do. I don’t think there is
9:05:41 AM PST
like below.
Apart from that
HDR?
Best Regards,
Raghu
On Feb 6, 2018, at 5:05 PM, Greg Ward <[email protected] > > > > > wrote:
Hi Raghu,
kalyanam [email protected]
Date: February
Hi All,
is the link to the
pictures.
identify the issue.
Best Regards,
Raghu
[https://www.radiance-online.org/mailman/listinfo/radiance-general](https://www.radiance-online.org/mailman/listinfo/radiance-general)
-- Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
[http://people.epfl.ch/jan.wienold](http://people.epfl.ch/jan.wienold)
LE 1 111 (Office)
Hi Raghu,
What you say does not jibe with what ximage or Photosphere report when probing your HDR image. The values are all quite high for an interior space. What program are you using to look at your result?
Date: February 6, 2018 9:57:53 AM PST
Hi Jan,
I want to compare the measured Vertical eye illuminance with the one calculated with evalglare, but the results are out of bounds from evalglare, so i couldn't even compare.
Best Regards,
Raghu
Jan
Hi Raghu,
Apart from that
Best Regards,
Raghu
Hi Raghu,
Hi All,
Best Regards,
Raghu
Hi Raghu,
The spot luminance measurements should ideally be done for several ranges for each HDR capturing (e.g. one reference area with 100cd/m2, another one with several thousands) and finally you compare the illuminance of the image with the measured one and you should reject any image with a deviation larger than 25% deviation of the illuminance. With a proper calibration you can be also within 10%.
Definitely the luminances of your image are totally off (=physically impossible, at least factor 50 for the blue sky) - it has nothing to do with evalglare.
BTW. evalglare calculates the illuminance also for that image (617414.88 lux) - there is no limit or "out of bounds". Just that your image has much too high luminances, so you get also an unrealistic illuminance...
It is hard to tell where the problem lies exactly, but definitely it is caused by your applied hdr generation process.
Cheers
Jan
On 06.02.18 18:57, Raghuram Kalyanam wrote:
Hi Jan,
Best Regards,
Raghu
    Jan
        Hi Raghu,
            out of bounds).
            Apart from that
            Best Regards,
            Raghu
                On Feb 6, 2018, at 5:05 PM, Greg Ward > <[email protected] > <mailto:[email protected]>> wrote:
                Hi Raghu,
                something like:
                    Hi All,
                    the link
                    the pictures.
                    Best Regards,
                    Raghu
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jan and Greg,
Thank you very much for your suggestions. Finally the issue seems to be solved. It is true that the problem is in HDR generation process. We divided each of the pixel values by 179, then HDR seems to be in radiance compatible format. Now the results of these HDR images from Evalglare are more meaningful.
Once again I thank you for your effort.
Best Regards,
Raghu
On Feb 6, 2018, at 7:31 PM, Jan Wienold <[email protected]> wrote:
Hi Raghu,
Cheers
Jan
Hi Jan,
Best Regards,
Raghu
On Feb 6, 2018 6:24 PM, Jan Wienold <[email protected]> <mailto:[email protected]> wrote:
Jan
Hi Raghu,
Apart from that
Best Regards,
Raghu
On Feb 6, 2018, at 5:05 PM, Greg Ward <[email protected] <mailto:[email protected]>> wrote:
Hi Raghu,
Hi All,
Best Regards,
Raghu
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jan and Greg,
Best Regards,
Raghu
Hi Raghu,
Cheers
Jan
Hi Jan,
Best Regards,
Raghu
Jan
Hi Raghu,
Apart from that
Best Regards,
Raghu
Hi Raghu,
Hi All,
Best Regards,
Raghu
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
