Hi Folks,
I installed the latest HEAD yesterday, and learned in a round about way how -spec has been replaced with -pal spec (or hot or pm3d...)
When I errantly used -spec the error message indicated my mistake was in the -l or -log options. Reading the new man page showed me the way, but I suppose the preferred error message would have called my attention to the misuse of -spec
(Also not sure if reporting these small bugs to the dev list is a best practice, so advanced apologies if this is misplaced...)
Here are the commands I used and the error messages:
$ falsecolor -ip images/6_1_1200.hdr -n 8 -s 8000 -spec -l cd/m2 -log 1 > test.hdr
bad option "cd/m2"
$ falsecolor -ip images/6_1_1200.hdr -n 8 -s 8000 -spec -log 1 > test.hdr
bad option "1"
$ falsecolor -ip images/6_1_1200.hdr -n 8 -s 8000 -spec > test.hdr
Use of uninitialized value $scale in pattern match (m//) at /usr/local/bin/falsecolor line 42.
Use of uninitialized value $scale in pattern match (m//) at /usr/local/bin/falsecolor line 115.
Use of uninitialized value $scale in concatenation (.) or string at /usr/local/bin/falsecolor line 126.
Use of uninitialized value $value in multiplication (*) at /usr/local/bin/falsecolor line 273.
/var/folders/pd/z41h8vkn5ks9d47kx028xvkw0000gn/T/S49kzBYNXL/pc0.cal, line 2:
scale : ;
^ unexpected character
/var/folders/pd/z41h8vkn5ks9d47kx028xvkw0000gn/T/S49kzBYNXL/scol.hdr: bad picture size
scale : ;
Thanks!
Mike
Michael Martinez ~ Associate
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
