Falsecolor and script by csh
I created a pic file with this comand:
rpict -w- view.vf -x 1600 -y 1600 -ab 5 -ad 4096 -as 4096 -ar 256 -
aa 0.2-t 60 oct/gensky_sky_$months[$i].$days[$i].$hours[$i].oct >
pics/lum_gensky_sky_$months[$i].$days[$i].$hours[$i].pic
and everything is fine (I can see the pic and the value are correct)
When I use falsecolor I get a file with 1K size and the tiff comand
gives me "bad picture:
falsecolor pics/lum_gensky_sky_$months[$i].$days[$i].$hours[$i].pic -
m 179 -s 10000 -l cd/m2 -n 10 > pics/lum_gen_sky_$months[$i].$days
[$i].$hours[$i].fc.pic
#ra_tiff -z pics/lum_gen_sky_$months[$i].$days[$i].$hours[$i].fc.pic
tiffs/lum_gensky_sky_$months[$i].$days[$i].$hours[$i].fc.tiff
Another question is about a script and the "if" function; the script
is showen below:
foreach cloud (5 10 3 4 8 9 7 1 0 6 5)
      if ($cloud <= 3) then
               set sky = "+s"
                       else if ($cloud <= 7 && $cloud >= 4) then
               set sky = "+i"
                        else if ($cloud <= 10 && $cloud >= 8) then
              set sky = "-c"
       endif
      echo $sky
end
It works fine, but if I use a data values, by a text file (data
values put by one column), I get sintax error:
set cloud = `cat data_sky/cloud.dat`
set i = 1
while ($i < 10)
echo cloud cover for index $i is $cloud[$i]
set value = `echo $cloud[$1] | cut -d '.' -f 1`
          if ($value <= 3) then
               set sky = "+s"
          else if ($value <= 7 && $value >= 4) then
               set sky = "+i"
          else if ($value <= 10 && $value >= 8) then
               set sky = "-c"
          endif
  echo $sky
    @ i++
end
Maybe the if function is not able to read the data values?
Thanks a lot
Roberto
Supera i limiti: raddoppia la velocità da 10 a 20 Mega! Risparmia con Tutto Incluso: telefono + adsl 20 mega a soli 29,95 € al mese per due anni!SCONTO DI 240 EURO!http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso/?WT.mc_id=01fw
Hi Roberto!
m 179 -s 10000 -l cd/m2 -n 10> pics/lum_gen_sky_$months[$i].$days
You can pass the image data to be used as value input by falsecolor using
"falsecolor -i filename.hdr > output.hdr"
or by sending to to stdin, e.g.
"cat filename.hdr | falsecolor > output.hdr"
So just add a "-i" in front of the input filename in your script.
Besides that, I would recommend not to use the outdated pic-extension, but the officially registred hdr-extension. But that is a side-not.
Does this work up to here?
I have to admit that I do not like bash when working on strings and arrays too much. I usually switch to perl whenever I need to process strings, even if it is just splitting a record.
Hello.
falsecolor works like a UNIX filter: it expects data at stdin and writes
modified data to stdout. If you want to specify a filename as input you have
to use the '-i' option.
Writing programs like filters allows you to combine the output of one
program to connect directly with the input of the next without intermediate
(potentially large) files.
is showen below:
set i = 1
while ($i < 10)
              set sky = "+s"
              set sky = "+i"
              set sky = "-c"
         endif
         echo $sky
   @ i++
end
When you specified your array in the first example the numbers were
interpreted as numbers. When you read from a file they are at first just
strings. The syntax error is raised because CSH recognises the variable as a
string and wants quotes around the left side of the test ( if ( "$value" <=
3 ) ... ). However, that's not your problem. You have to convert the strings
to numbers to compare against another number in the if condition. Here is a
(slightly cleaned up) version. Note the line with the `expr ...` in it.
set cloud = `cat cloud_cover.dat`
set i = 1
while ($i<10)
    echo "cloud cover for index $i is $cloud[$i]"
    set value_s = `echo $cloud[$i] | cut -d '.' -f 1`
    set value = `expr $value_s`
    if ( $value <= 3 ) then
        set sky = "+s"
    else if ( $value <= 7 ) then
        set sky = "+i"
    else
        set sky = "-c"
    endif
    echo "cloud: $cloud[$i] sky: $sky"
    @ i++
end
PS: If you are new to shell scripting you should consider switching to bash.
It's more popular and doesn't have as many syntax oddities as CSH.
On Thu, Feb 10, 2011 at 5:07 AM, [email protected] < [email protected]> wrote:
