External 'clear' shading
Dear Radiance users,
I am new to Radiance.
An existing building is being renovated in order to reduce its need for primary energy and optimize the building envelope daylight penetration.
I order to reduce the need for cooling an external shading (glass with printing) is used. The data for the shading material is:
Light reflection (for both sides): 30%
Light transmission: 23%
It is important to include the both parameter (transmission + reflection) in the study in order to clarify possible glare and in order to maximize daylight distribution to the room.
My question is: what material would be the best to use for the shading material in order to model this scene correctly and do I need to include skyfunc and illum for this?
Thank you in advance :slight_smile:
Best Regards
Per Haugaard
______________________
Per Haugaard,
Griffenfeldsgade 33, 2.tv
2200 København N
Denmark
mobil: +45 26 39 06 40
E-mail: [email protected]
Trænger du til at se det store billede? Kelkoo giver dig gode tilbud på LCD TV!
Hi Per,
If you knew a few more details, such as the type of frit and percent coverage, you could use the Radiance glaze script to arrive at a more accurate model. Based on the information you have and a reasonable assumption of Rs=0.08, you can use a trans material (also see attached excerpt from RwR):
void trans fritted_glass
7 0.422 0.422 0.422 0.08 0 0.434 0.5
I got this using:
A6 = (Td + Ts) / (Rd + Td + Ts) = 0.23 / (0.23 + 0.30) = 0.434
A5 = Sr = 0
A4 = Rs = 0.08
A3 = A2 = A1 = (Rd - Rs) / ((1-Rs)*(1-A6)) = (0.30 - 0.08)/((1-0.08)*(1-0.434)) = 0.422
The only thing that's really a guess is A7, the fraction of specular transmission. This would require an additional measurement or the percentage frit coverage. I guessed 50% coverage.
I hope this helps!
Excerpted pages 325-326 from "Rendering with Radiance" <http://tinyurl.com/2wn78b>:
5.2.6 Modeling Transmitting Media
Some luminaires use semitransparent surfaces to cover the bright light sources hidden
inside. This can include downlights and other lensed luminaires. In addition,
some daylight control products, such as curtains and fritted glass, are most appropriately
modeled as a semispecularly transmitting medium. In these cases, it is
important to know how to properly specify the trans material type to accurately
model the appearance of the luminaire or other light-transmitting architectural
element.
Specifying a trans material can be intimidating. It is one of the most confusing
material entities in the Radiance repertoire. However, it is the simplest material that
will trace direct source rays through a semispecular surface in order to determine
the diffuse and specular transmitted components.
You will have to measure the following surface properties in preparation for the
creation of a trans material type:
• Diffuse reflectance (RGB): The color will affect both diffusely reflected light (if
there is any surface roughness) and transmitted light. Call the red, green, and
blue components Cr, Cg, and Cb. Calculate the photopic average of the RGB
and call this Rd.
• Reflected specularity: As with glass, this is the fraction of light that is reflected
off the first surface in a mirror-like way. This we’ll call Rs; it is equal to floatingpoint
argument 4, A4.
• Surface roughness (RMS): Facet slope as in plastic. Call this Sr.
• Diffuse transmissivity: Fraction of light that passes all the way through the surface
diffusely. Call this Td.
• Transmitted specularity: Fraction of light transmitted as a beam—that is, the
fraction of light not diffusely scattered. Call this Ts.
The following formulas can be used to calculate the A7 through A1 parameters
for the trans material:
A7=Ts / ( Td+Ts )
A6=( Td+Ts ) / ( Rd+Td+Ts )
A5=Sr
A4=Rs
A3=Cb / ( (1-Rs)*(1-A6) )
A2=Cg / ( (1-Rs)*(1-A6) )
A1=Cr / ( (1-Rs)*(1-A6) )
The behavior of trans is regulated by the -st specular threshold rendering parameter.
The following formula can be used to determine the appropriate -st setting for
rview, rpict, or rtrace to ensure that the transmitted (and reflected) semispecular
component will be rendered. The variables A1 through A7 are the first through seventh
floating-point arguments to the trans primitive as calculated above.
St = A6 * A7 * (1 - grey(A1, A2, A3) * A4)
Unlike most other Radiance material primitives, the trans material is neither
intuitive nor straightforward to apply. It is a good idea to keep ample notes for later
reference when you are creating a trans material. Backing out your assumptions
from an unannotated trans primitive is difficult.
Date: February 11, 2008 11:21:16 AM PST
Best Regards
Per Haugaard
Just in case it is not known yet - Radiance is also integrated into ESP-R, a free building simulation system, which will allow you to calculate also thermal behaviour of your design and, most important, supports lots of analysis needs for finding the critical points by e.g. combining internal and external thermal loads over the year. Might be interesting for this project. Be warned, learning curve is even steeper then for Radiance (yes, I guess because it has a GUI ;-)...
CU, Lars.
