evalglare installation on mac
I've downloaded the v.1.04 version of evalglare on my mac os 10.6.8.
I added to the flags the -fnested-functions to the CFLAGS as indicated in the previous emails, unpacked the folder into /radiance/evalgare, and ran "make" from the command line.
It doesn't seem to install properly though, basically what I see in output is:
MacBook-di-Stefano-Moret:evalglare Cinese$ make
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/color.o common/color.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/resolu.o common/resolu.c -I. -Igeometry
common/resolu.c: In function ‘str2resolu’:
common/resolu.c:98: warning: implicit declaration of function ‘atoi’
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/header.o common/header.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/image.o common/image.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/fvect.o common/fvect.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/badarg.o common/badarg.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/words.o common/words.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/fputword.o common/fputword.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/expandarg.o common/expandarg.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/wordfile.o common/wordfile.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/bmalloc.o common/bmalloc.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o common/mat4.o common/mat4.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o pictool.o pictool.c -I. -Igeometry
pictool.c:98: warning: ‘read_exposure’ defined but not used
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o geometry/g3vector.o geometry/g3vector.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o geometry/gbasic.o geometry/gbasic.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o geometry/g3affine.o geometry/g3affine.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o geometry/g3sphere.o geometry/g3sphere.c -I. -Igeometry
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -o geometry/g3flist.o geometry/g3flist.c -I. -Igeometry
gcc -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -fnested-functions -Wall -DEVALGLARE -o evalglare evalglare.c pictool.o geometry/g3vector.o geometry/gbasic.o geometry/g3affine.o geometry/g3sphere.o geometry/g3flist.o \
-I. -Igeometry common/color.o common/resolu.o common/header.o common/image.o common/fvect.o common/badarg.o common/words.o common/fputword.o common/expandarg.o common/wordfile.o common/bmalloc.o common/mat4.o -lm
It does something, but I don't think it's properly installed: for example, it can't find the command evalglare if I'm in another folder, and even in that folder it doesn't run the glare analysis on the picture.
Could anyone enlighten me on what I'm doing wrong?
Many thanks,
Best Regards,
Stefano
Stefano Moret
California Lighting Technology Center<http://cltc.ucdavis.edu/>
University of California, Davis
633 Pena Drive
Davis, CA 95618
530-747-3846
smoret@ucdavis.edu<mailto:smoret@ucdavis.edu>
It seems like you're getting it to compile. I would recommend you place it in the same directory as all your Radiance binaries, so that evalglare will be in a search path target. Also make sure it's been set to be executable. You may need admin privileges to do both of these things. For example, if Radiance is in /usr/local/bin, and you are currently in the directory where you compiled evalglare:
sudo cp evalglare /usr/local/bin (you will be prompted for the admin password)
sudo chmod 755 /usr/local/bin/evalglare
Give that a whirl, and if you still have problems, maybe some more detail about what happens when you try to run evalglare will be needed.
Sent: Thursday, May 31, 2012 6:40 PM
Subject: [Radiance-general] evalglare installation on mac
Many thanks,
Best Regards,
Stefano
Stefano Moret
633 Pena Drive
Davis, CA 95618
530-747-3846
Done, thanks Rob!
Stefano Moret
633 Pena Drive
Davis, CA 95618
530-747-3846
To: radiance-general@radiance-online.org<mailto:radiance-general@radiance-online.org>
Many thanks,
Best Regards,
Stefano
Stefano Moret
633 Pena Drive
Davis, CA 95618
530-747-3846
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
