evalglare: Bad CPU type in executable
Dear list,
I recently tried using evalglare on my mac (OS X Mavericks 10.9.5) and
received the following feedback from the terminal (when entering
evalglare -v)
/usr/local/ray/bin/evalglare: *Bad CPU type in executable*
A quick google of this kind of error suggests that i need an updated binary
file, or need to compile evalglare from source on my machine
https://discussions.apple.com/thread/6130828
I though it would be problem solved by installing the new Radiance binaries
from NREL
But i get the same error
Any suggestions here?
best,
-Kyle
hi kyle,
did you try to compile radiance as well?
i just did it yesterday (official 5.0 release) for mavericks and yosemite and both installed completely (including evalglare v17) without problems in less than 3min.
(of course you need the xcode and x11 package as well).
Jan
On November 17, 2015 10:26:24 PM CET, Kyle Konis <kskonis@gmail.com> wrote:
Dear list,
evalglare -v)
binary
binaries
from NREL
https://github.com/NREL/Radiance/releases
best,
-Kyle
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
Hey Kyle,
Also, which NREL version did you try? The latest Mac installer on the NREL site was built on my system here, same as yours (Mavericks 10.9.5), and I get:
$ evalglare -v
evalglare 1.17 release 15.07.2015 by EPFL, J.Wienold
On 11/17/15, 2:43 PM, "Jan Wienold" <jan.wienold@epfl.ch<mailto:jan.wienold@epfl.ch>> wrote:
hi kyle,
Jan
On November 17, 2015 10:26:24 PM CET, Kyle Konis <kskonis@gmail.com<mailto:kskonis@gmail.com>> wrote:
Dear list,
I recently tried using evalglare on my mac (OS X Mavericks 10.9.5) and received the following feedback from the terminal (when entering evalglare -v)
/usr/local/ray/bin/evalglare: Bad CPU type in executable
A quick google of this kind of error suggests that i need an updated binary file, or need to compile evalglare from source on my machine
I though it would be problem solved by installing the new Radiance binaries from NREL
best,
-Kyle
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
Hi Jan and Rob,
Thanks for the quick response,
No, i just used the NREL installers . . .
Specifically : *radiance-5.0.0-Darwin.dmg*
<https://github.com/NREL/Radiance/releases/download/5.0/radiance-5.0.0-Darwin.dmg>
from
But here's a clue . . .
Since i have an old version of evalglare (and radiance) on my machine, i
deleted evalglare just to see if the installer would replace it.
I also deleted the radiance program "total"
I opened the radiance installer and followed all the steps, and got the
"Installation was successful" screen.
However no evalglare in /usr/local/ray/bin/evalglare
and no /usr/local/ray/bin/total
So i think my prior issue is probably that i had a very old version of
evalglare on my machine.
And the new issue is that i am expecting the installer to overwrite the
files in /usr/local/ray/bin/ and it seems to not be doing this ( ? )
-Kyle
On Tue, Nov 17, 2015 at 1:43 PM, Jan Wienold <jan.wienold@epfl.ch> wrote:
hi kyle,
less than 3min.
Jan
On November 17, 2015 10:26:24 PM CET, Kyle Konis <kskonis@gmail.com> > wrote:
Dear list,
evalglare -v)
binaries from NREL
best,
-Kyle
gesendet.
By default, the NREL Mac installer puts everything in:
/usr/local/radiance/bin (programs)
/usr/local/radiance/lib (library/cal files)
/usr/local/radiance/man (little green men and manual pages)
So yeah, you need to update your environment ($PATH and $RAYPATH) or change the installation location (which I'm 97% certain you can do with the installer (and that it works)) to match your environment.
You can always check to see what your system is using for executables by typing "which <program_name>" at the cli, which returns the full pathname of the system executable (regardless of how many versions you have scattered about), e.g.:
$ which evalglare
/usr/local/radiance/bin/evalglare
I'd also get the latest installer while you're at it:
HTH!
On 11/17/15, 3:13 PM, "Kyle Konis" <kskonis@gmail.com<mailto:kskonis@gmail.com>> wrote:
Hi Jan and Rob,
Specifically : radiance-5.0.0-Darwin.dmg<https://github.com/NREL/Radiance/releases/download/5.0/radiance-5.0.0-Darwin.dmg>
from
Since i have an old version of evalglare (and radiance) on my machine, i deleted evalglare just to see if the installer would replace it.
I opened the radiance installer and followed all the steps, and got the "Installation was successful" screen.
So i think my prior issue is probably that i had a very old version of evalglare on my machine.
And the new issue is that i am expecting the installer to overwrite the files in /usr/local/ray/bin/ and it seems to not be doing this ( ? )
-Kyle
On Tue, Nov 17, 2015 at 1:43 PM, Jan Wienold <jan.wienold@epfl.ch<mailto:jan.wienold@epfl.ch>> wrote:
hi kyle,
Jan
Dear list,
best,
-Kyle
Also you can try the command "type -a <program_name>" which will output multiple lines listing all instances of a program in order of priority the system will call them - in case you have competing instances in multiple locations and multiple PATHs defined.
From: Guglielmetti, Robert [mailto:Robert.Guglielmetti@nrel.gov]
$ which evalglare
Thanks to all,
In the end it was my own mind that needed an upgrade, as i forgot that the
NREL installers use (as Rob kindly pointed out),
/usr/local/radiance
and not
/usr/local/ray
which is hardwired into my brain for some reason.
Anyways, i am now happily evaluating glare!
-Kyle
On Tue, Nov 17, 2015 at 2:26 PM, Guglielmetti, Robert < Robert.Guglielmetti@nrel.gov> wrote:
$ which evalglare
https://github.com/NREL/Radiance/releases/tag/5.0.a.6
HTH!
On 11/17/15, 3:13 PM, "Kyle Konis" <kskonis@gmail.com<mailto: > kskonis@gmail.com>> wrote:
Hi Jan and Rob,
from
-Kyle
On Tue, Nov 17, 2015 at 1:43 PM, Jan Wienold <jan.wienold@epfl.ch<mailto: > jan.wienold@epfl.ch>> wrote:
hi kyle,
less than 3min.
Jan
On November 17, 2015 10:26:24 PM CET, Kyle Konis <kskonis@gmail.com > <mailto:kskonis@gmail.com>> wrote:
Dear list,
evalglare -v)
binaries from NREL
best,
-Kyle
gesendet.
Thanks to all,
In the end it was my own mind that needed an upgrade, as i forgot that the NREL installers use (as Rob kindly pointed out),
/usr/local/radiance
*** To be clear, only the Mac installer does this. The Windows installer has Windowsy paths, and the Linux installer isn't an installer at all, it's just a tarball of everything. I wish these were more consistent and also were better about modifying the system environments for the user, but, whatever...
On 11/17/15, 4:40 PM, "Kyle Konis" <kskonis@gmail.com<mailto:kskonis@gmail.com>> wrote:
