Errors while transposing with Rcollate.
Hi everyone,
I am trying to do a transpose with rcollate. My operating system is Windows.
My file contains rgb triplets arranged in a (8760columns x 60rows) matrix. I
either get a "error loading file into memory" or an incorrect transpose.
I found that I got the same results with a simple ASCII file with tab
separated values. My file contains:
1 2 3 4
5 6 7 8
9 10 11 12
The following commands return "error loading file into memory":
rcollate -h -fa1 -t a.txt >d.txt
rcollate -h -fa1 -ic 4 -oc 3-t a.txt >d.txt
I found that the '-t' flag was responsible for the error, so I tried
explicitly stating the values for columns and rows as:
rcollate -h -fa1 -ic 4 -ir 3 -oc 3 -ir 4 a.txt>d.txt
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Am I missing something?
Sarith
Hi Sarith,
This seems related to the broken handling of text versus binary files under Windows. Try reading the file from stdin, instead:
rcollate –h –fa1 –t < a.txt > d.txt
If this works, let me know and I'll see if I can put in a fix.
Subject: [Radiance-general] Errors while transposing with Rcollate.
Date: June 15, 2015 5:09:13 PM PDT
Hi everyone,
I am trying to do a transpose with rcollate. My operating system is Windows. My file contains rgb triplets arranged in a (8760columns x 60rows) matrix. I either get a “error loading file into memory” or an incorrect transpose.
I found that I got the same results with a simple ASCII file with tab separated values. My file contains:
1 2 3 4
5 6 7 8
9 10 11 12
The following commands return “error loading file into memory”:
rcollate –h –fa1 –t a.txt >d.txt
rcollate –h –fa1 –ic 4 –oc 3–t a.txt >d.txt
I found that the ‘-t’ flag was responsible for the error, so I tried explicitly stating the values for columns and rows as:
rcollate –h –fa1 –ic 4 –ir 3 –oc 3 –ir 4 a.txt>d.txt
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
The command that you suggested returns the usage options for rcollate in
windows. (ie. Usage: rcollate [-h[io].....)
Earlier, I had tried feeding the file to rcollate via stdin through using
pipe ( | ) as well as the 'type a.txt' shell command in windows but didn't
get it work either way.
Sarith
Sent: Tuesday, June 16, 2015 12:04 AM
Subject: Re: [Radiance-general] Errors while transposing with Rcollate.
Hi Sarith,
rcollate -h -fa1 -t < a.txt > d.txt
From: "Sarith Subramaniam" <sarith@psu.edu <mailto:sarith@psu.edu> >
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Anyone else have any ideas or suggestions? Honestly, I don't know why redirecting stdin from a file would fail completely. I thought this was supported under Windows.
I'm stumped.
-G
Date: June 15, 2015 9:45:56 PM PDT
The command that you suggested returns the usage options for rcollate in windows. (ie. Usage: rcollate [-h[io]………..)
Earlier, I had tried feeding the file to rcollate via stdin through using pipe ( | ) as well as the ‘type a.txt’ shell command in windows but didn’t get it work either way.
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Hi Sarith,
I just tried both calls (with and w/o redirecting from stdin) with the
latest Windows binaries from NREL(https://github.com/NREL/Radiance/releases)
and both work fine at my side...
rcollate –h –fa1 –t a.txt > d.txt
Which version of rcollate are you using?
David
2015-06-16 6:58 GMT+02:00 Greg Ward <gregoryjward@gmail.com>:
I'm stumped.
-G
*Subject: *Re: [Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 9:45:56 PM PDT
Sarith
*Sent:* Tuesday, June 16, 2015 12:04 AM
*Subject:* Re: [Radiance-general] Errors while transposing with Rcollate.
Hi Sarith,
*Subject: *[Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 5:09:13 PM PDT
Hi everyone,
transpose.
1 2 3 4
5 6 7 8
9 10 11 12
*rcollate –h –fa1 –t a.txt >d.txt*
*rcollate –h –fa1 –ic 4 –oc 3–t a.txt >d.txt*
*rcollate –h –fa1 –ic 4 –ir 3 –oc 3 –ir 4 a.txt>d.txt*
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Dipl.-Ing. Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Austria
Looks like a line endings problem. If I create an input text file on Windows and run rcollate, I get the "error loading file into memory" error. But if I create an input text file on the Mac, copy it to my Windows VM and run rcollate, it works fine with the first invocation David lists below. What I don't know about this crap could fill a book, but I am ASSuming rcollate lacks certain file type handling that other radiance programs have. (?) HTH, YMMV, EIEIO, TTFN
On 6/16/15, 7:50 AM, "David Geisler-Moroder" <david.moroder@gmail.com<mailto:david.moroder@gmail.com>> wrote:
Hi Sarith,
I just tried both calls (with and w/o redirecting from stdin) with the latest Windows binaries from NREL(https://github.com/NREL/Radiance/releases) and both work fine at my side...
rcollate -h -fa1 -t a.txt > d.txt
David
2015-06-16 6:58 GMT+02:00 Greg Ward <gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>>:
I'm stumped.
-G
From: "Sarith Subramaniam" <sarith@psu.edu<mailto:sarith@psu.edu>>
The command that you suggested returns the usage options for rcollate in windows. (ie. Usage: rcollate [-h[io]...........)
Earlier, I had tried feeding the file to rcollate via stdin through using pipe ( | ) as well as the 'type a.txt' shell command in windows but didn't get it work either way.
Sarith
From: Greg Ward [mailto:gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>]
Hi Sarith,
Hi everyone,
I am trying to do a transpose with rcollate. My operating system is Windows. My file contains rgb triplets arranged in a (8760columns x 60rows) matrix. I either get a "error loading file into memory" or an incorrect transpose.
1 2 3 4
5 6 7 8
9 10 11 12
I found that the '-t' flag was responsible for the error, so I tried explicitly stating the values for columns and rows as:
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
Hofwaldweg 14/20
6020 Innsbruck
Austria
Something else that is totally bizarre is that if I type your entry on the command line, rcollate crashes with an MSVCR120.dll error, but if I paste Greg's text into the command line it gives me the usage text - and they appear to be completely identical commands. We are using the NREL compile of Radiance.
Rick
Sent: Tuesday, June 16, 2015 12:59 AM
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Let's take this discussion offline and post again when it's resolved. At this point, it isn't clear if the problem lies with the build, the command-line interpreter or Windows system it's running under, or the rcollate command itself.
If you have some idea and want to help us work this out, write to me and I'll loop you back in.
Date: June 16, 2015 5:50:36 AM PDT
Something else that is totally bizarre is that if I type your entry on the command line, rcollate crashes with an MSVCR120.dll error, but if I paste Greg’s text into the command line it gives me the usage text – and they appear to be completely identical commands. We are using the NREL compile of Radiance.
Rick
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Well, that was quicker than expected. Just after sending this e-mail, Sarith wrote again and the problem seems to be resolved. He had an old version of rcollate that didn't work when stdin was redirected from a file, but the latest works in that mode with -t but not from a file under Windows. This was easy enough to fix, and the next NREL release should behave properly. Meanwhile, Windows folks may have to redirect the input when transposing ASCII files with rcollate.
A tempest in a teacup, really....
Date: June 16, 2015 11:50:02 AM PDT
Rick
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
