Errors in compiling radiance in Ubuntu 8.1
Hi Jack,
I have used ./makeall install for compiling radiance and not scons . The
errors encountered during the compilation process is attached in the
text file. Kindly let me know whether these errors are fatal and how to
rectify these errors.
OS is Ubuntu 8.1
GCC version is 4.3
Ganesh.
compileoutput.txt.gz (17.9 KB)
[mailto:radiance-dev-bounces@radiance-online.org] On Behalf Of Jack de
Valpine
Sent: Wednesday, October 07, 2009 5:32 PM
To: code development
Subject: Re: [Radiance-dev] Errors in testing radiance Ubuntu 8.1
Hi Ganesh,
I have not used the scons tool to compile radiance before. However, it
looks to me like these errors relate to testing compiled radiance
commands rather than actually doing the compile. To assure yourself of a
clean compile it might make more sense to use the " makeall" script to
do a fresh compile:
./makeall clean
./makeall install
then if you get errors you can report those as they will relate to the
actual compile process.
Do people actually use Scons to build radiance? Is this something that
should still be maintained or perhaps removed?
-Jack de Valpine
R Ganesh wrote:
Dear Developers,
I am a new user to radiance. I have compiled the Radiance V3.9 code in
Ubuntu 8.1 and there were some errors during the compilation. I ran the
tests in ray/test directory and the results are attached in text file.
Kindly let me know whether the radiance installation is alright or I
have to reinstall them.
Compiler :gcc 4.3
OS is Ubuntu 8.1
Regards
Ganesh
________________________________________________________________________
Radiance-dev mailing list
# Jack de Valpine
- you're missing some -dev packages. Look which header files are missing, search
which package they're included in and install them
- if you want to install to /usr/local, you might need to run the install part
as root
The better solution for you might be to run
sudo apt-get install radiance radiance-materials radiance-doc
as Ubuntu 8.10 ships with radiance 3R9.
Don't forget to read /usr/share/doc/radiance/README.Debian afterwards.
Bernd
http://bzed.de http://www.debian.org
GPG Fingerprints: 06C8 C9A2 EAAD E37E 5B2C BE93 067A AD04 C93B FF79
                   ECA1 E3F2 8E11 2432 D485 DD95 EB36 171A 6FF9 435F
Ganesh.
One problem is that you don't have X11 development files installed (like
"X11/Xlib.h", "X11/Xutil.h"). Add the package from your repository. That
should deal with most of the problems.
Then you don't have permissions to add or delete files in "/usr/local/"
where Radiance would be installed by default. You have to run "./makeall
install" as a "sudo" command or as root.
On Fri, Oct 9, 2009 at 7:26 AM, R Ganesh <rganesh@bluestarindia.com> wrote:
Hi Jack,
OS is Ubuntu 8.1
GCC version is 4.3
Ganesh.
From:radiance-dev-bounces@radiance-online.org<From%3Aradiance-dev-bounces@radiance-online.org>
[mailto:radiance-dev-bounces@radiance-online.org<radiance-dev-bounces@radiance-online.org>]
Valpine
Hi Ganesh,
do a fresh compile:
./makeall clean
./makeall install
-Jack de Valpine
R Ganesh wrote:
Dear Developers,
Compiler :gcc 4.3
OS is Ubuntu 8.1
Regards
Ganesh
# Jack de Valpine
