Error: Rendering with Radiance p. 319 Luminaire Modeling
Hi Randoph,
Could you be more specific? The radius of a sphere whose *projected* area is 1.0 for any distant point is sqrt(1/pi) as Chas derived it. This is in fact what ies2rad needs. This is not the same as a sphere whose total surface area is 1.0, which is the value you derived.
Is there an error in ies2rad.c, somewhere?
Date: February 6, 2012 3:59:10 PM PST
I just had occasion to go through Chas. Ehrlich's luminaire modeling procedure given in *Rendering with Radiance* and there is an error on page 319 of the text. The radius of a unit sphere is 0.282095, not 0.56419. Both the number in the text and the ies2rad command are wrong.
Ouch!
Randolph M. Fritz
Hi Randoph,
Then maybe I've done something else wrong. When I ran a simulation which checks the luminaire model against the IES file by simulating a goniophotometer the numbers lined up. I'll take a closer look at my scripts and see if I can find a factor of two somewhere.
Randolph
On 2012-02-07 00:12:18 +0000, Greg Ward said:
Ouch!
Randolph M. Fritz
Randolph M. Fritz
Hi Randoph,
The same check script worked correctly with an untouched ies2rad output file with both the given geometry and a spherical substitute.
I then ran the procedure with -i 0.56419 and the numbers I am getting back are the same and correct.
I am now thoroughly confused. Does the radius even matter in that procedure? Or do I have a case of a luminaire where it doesn't matter?
Randolph
Randolph
Ouch!
Randolph M. Fritz
Randolph M. Fritz
Hi Randolph,
Whatever radius you give, ies2rad should adjust the brightness to keep the total lumen output the same.
Date: February 6, 2012 4:45:53 PM PST
Hi Randoph,
Randolph
But then, why did Chas say to specify the radius of a projected unit sphere in RwR? The radius of the sphere does not seem to matter, at least in the case of the photometry I am working with. Does it make a difference with other sorts of photometry? Or…?
What am I missing?
Randolph
On 2012-02-07 01:40:29 +0000, Greg Ward said:
Hi Randolph,
Hi Randoph,
Randolph
Randolph M. Fritz
I guess you would have to ask Chas that one. Maybe he wanted the RGB values to come out (close to) 1.0 for some reason.
Date: February 6, 2012 8:57:23 PM PST
What am I missing?
Randolph
Hi Randolph,
I think that is exactly right.
Thank you.
Randolph
