I am getting an error message from oconv "internal - set overflow in addobject <zone02.rad00680>" This results in a error generating the octree.
Can anyone please tell me where to start debugging?
I am running desktop radiance through Ecotect export on WinXP.
Thank you,
Jill Dalglish, LEED AP
Hi Jill,
Older versions of oconv had a lot of problems with really crazy geometry (usually crazy geometry that didn't need to be so crazy, like a zillion polygons defining a doorknob, or lots of coincident polys). You can increase the –r option in oconv which helps, but increases compilation time and octree size. Two better solutions are 1) build the cleanest models you can, and 2) use a newer version of oconv.exe. You can grab a semi-recent version here:
https://openstudio.nrel.gov/getting-started/getting-started-windows
Scroll down to the "Radiance Binaries" section and there's a link there.
1617 Cole Blvd MS:RSF202
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
E. [email protected]
On 1/9/12 3:46 PM, "Jill Dalglish" <[email protected]<mailto:[email protected]>> wrote:
Thank you,
Also, make sure you haven't included your model multiple times -- I've seen this happen with overlapping, identical geometry. Geometry that comes to a point with many polygons sharing the same vertex is the usual source of this error. I think the limit is 510 elements sharing a vertex or an infinitesimal volume of space. Things like Rob's doorknob example can often be represented more simply in Radiance's native surface primitives than they can using triangles if that's an option.
Date: January 9, 2012 2:54:34 PM PST
Hi Jill,
OpenStudio
Thank you,
Thank you! It turns out that there was hidden geometry in SketchUp that was overlapping existing geometry when I exported it to a dxf.
On 1/10/2012 13:00, [email protected] wrote:
Today's Topics:
1. error message: overflow in addobject (Jill Dalglish)
2. Re: error message: overflow in addobject (Guglielmetti, Robert)
3. Re: error message: overflow in addobject (Greg Ward)
Message: 1
Date: Mon, 09 Jan 2012 15:46:39 -0700
To: radiance-general<[email protected]>
Subject: [Radiance-general] error message: overflow in addobject
Message-ID:<[email protected]>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
addobject<zone02.rad00680>" This results in a error generating the octree.
Thank you,
